Toyota Prius Gen3 Board
Revision as of 23:15, 5 January 2021 by Thomas (talk | contribs) (Added Power Board No to G9200-47190)
Prius Gen3 Control Board v2
Prius Inverter
Control Board
Prius Gen3 Partial
Development History
Vendors
EVBMW Webshop
Support
Inverter Model Numbers
G9200-47141 Auris 2012, RHD
G9200-47190 Auris F1759-52010 04 F1789-52010 ? Forum Thread openinverter.com
G9200-52010 Yaris
Prius C
Soldering The Breakout Board
Soldering the Main Board
And Conn8, again easy.
[add photo]
Powering up
Checking voltages
Check for ~3.3v here on C32
Finally the 26v
Firmware
Wifi Module Firmware
  3. Write code to ESP8266
Programming Firmware
For Windows
Atmega328p Firmware
Inverter Parameters
udcofs 0 DC link 0V offset
Parameters Details
First Run (PWM verify)
Navigate to the Web Interface
Stop the inverter
DC-DC Converter
12v Battery Connection
Motor Connection
IDC Connector
Connections are as follows:
Pin Number Label Description
23 MG2_STATOR_T1 5V analogue input from motor temperature sensor. These are typically variable resistance devices. Connect the other side of the sensor to +5V.
24 MG2_STATOR_T2 5V analogue input from motor temperature sensor. These are typically variable resistance devices. Connect the other side of the sensor to +5V.
28 HV_CON ?
31 EVSE_PROX
32 CONTROL_PILOT
Ampseal Socket & Plug
AMPSeal socket (male) in 3D printed surround with pins marked
22 MOTOR TEMP SENSOR A 5V analogue input from motor temperature sensor. These are typically variable resistance devices. Connect the other side of the sensor to +5V.
23 MOTOR TEMP SENSOR B 5V analogue input from motor temperature sensor. These are typically variable resistance devices. Connect the other side of the sensor to +5V.
27 CHARGER HV DC REQUEST
30 EVSE PROXIMITY SIGNAL
31 EVSE CONTROL PILOT SIGNAL
34 NOT USED
35 NOT USED
Connecting Resolver
Inverter as charger
Buck Mode Charging.
https://github.com/celeron55/prius3charger_buck
#define AC_PRECHARGE_MINIMUM_VOLTAGE 550  // European 3-phase rectifies to 600V, Single Phase 240v rectifies to 340V
#define PRECHARGE_BOOST_VOLTAGE 550  // European 3-phase rectifies to 600V, Single Phase 240v rectifies to 340V
Damien's Prius Gen3 v2 Github
Bill of Materials (Github)
