Toyota Prius Gen3 Board
Revision as of 00:45, 22 January 2020 by MattsAwesomeStuff (talk | contribs)
Prius Inverter
  • Respectable performance. Rated for 50kW output, but tests indicate they can tolerate as much as 300kW
  • 2 high power inverters, for the 2 motors MG1 (starter) capable of handling X(?) amps, and MG2 (drive motor) capable of handling Y(?) amps.
Control Board
Prius Gen3 Partial
Development History
Vendors
- ?? List of known vendors with support?
Support
How To Use
The Prius Gen3 Board is suitable to control any (please add: motor types here) motors.
Note: Early versions of the board have a few mistakes. (Add details)
Schematics, Bill of Materials, and other documentation are available on Damien's Project Github
(Note: This is the V2, which replaces the V1 board)
(note: flesh out bill of materials here, or post changes to Damien to update his documentation directly?)
The control board takes advantage of the OpenInverter.org software (link?) for control.
Assembly notes?
