Toyota Prius Gen3 Board
Revision as of 15:54, 24 January 2020 by Mouse (talk | contribs)
Prius Gen3 Control Board v2
Prius Inverter
  • Respectable performance. Rated for 50kW output, but tests indicate they can tolerate as much as 300kW
  • 2 high power inverters, for the 2 motors MG1 (starter) capable of handling X(?) amps, and MG2 (drive motor) capable of handling Y(?) amps.
Control Board
Prius Gen3 Partial
Development History
Vendors
- ?? List of known vendors with support?
Support
Inverter Model Numbers
Inverter No Car model(s) Logic Board No Power Board No Compatible 50 pin connector PCB size Link
G9200-47141 Auris 2012, RHD
G9200-47190 Auris F1759-52010 04 ? Forum Thread openinverter.com
Assembly Notes
The Prius Gen3 Board is suitable to control any (please add: motor types here) motors.
Note: Early versions of the board have a few mistakes. (Add details)
Source Documentation:
Damien's Prius Gen3 v2 Github
