BMW F-Series Gear Lever
Revision as of 10:06, 11 October 2023 by Kraln (talk | contribs) (Add information on slightly older gear shifts with different connectors, add backlight information, correct misinformation (wrong CRC final-xor).)
General Information
Much of this information is based on articles by Project Gus [1] and a forum post from Bimmerwelt[2]. Thank you for reverse engineering!
Pinout and Connector
The BMW supply number of the connector is 9132576-02, the TE part number is 2-929423-2 but the connector is not freely available from TE [3]. The BMW Part number for the 10-position socket housing is widely available as 61-13-9-132-577.
10-Pin Pinout
Pin Type Wire Colour Function
1 NC
2 NC
3 E/A Red PT-CAN Low
4 E/A Blue/Red PT-CAN High
5 E/A White/Blue PT-CAN2 Low
6 E/A White/Yellow PT-CAN2 High
7 E Green/Brown Wakeup[2]
8 M Brown Ground
9 NC
10 E Red/Blue +12V
Earlier versions of the shifter have a different, 8-pin connector (7 pins fitted)[2] with the following pinout, but nevertheless communicate with the same CAN protocol as the newer shifters. The 8-pin version has a 2.54 (0.1") spacing.
8-Pin Pinout
Pin Type Wire Color Function
1 E Red/Green +12V
2 E Green/Red Wakeup
5 M Brown Ground
6 E/A White/Blue PT-CAN2 Low
7 E/A White/Yellow PT-CAN2 High
8 NC
CAN Bus
The Powertrain CAN Bus has a baud rate of 500kBaud.
GWS sends a "heartbeat" to CAN ID 0x55e[4], Diagnostic Errors to CAN ID 0x65e, and more frequent 4-byte GWS status message to CAN ID 0x197. When an impossible action is requested (for instance, shifting from neutral to reverse without also pressing "unlock"), an additional CAN message is sent.
Status message Byte Meaning
0 CRC8 of bytes 1-3 (poly=0x1D, init=0x0, xor=0x53)
1 Counter value, 4 bits wide, should change each message, never 0x0F
2 Lever position
3 Park button (0xC0 normally, 0xD5 if Park is pressed)
Lever position byte values include:
Value Meaning
0x0E Centre middle
0x1E Pushed "up" (towards front of car)
0x2E Pushed "up" two notches
0x3E Pushed "down" (towards back of car)
0x4E Pushed "down" two notches
0x7E Centre side
0x5E Pushed "side and up"
0x6E Pushed "side and down"
To update the GWS appearance, message ID 0x3FD has to be sent every 50-100ms:
Byte Meaning
0 CRC8 of bytes 1-4 (init=0x00, poly=0x1D, xor=0x70)
1 4-bit counter (must increment each message), not 0x0F
2 Payload byte 0
3 Payload byte 1
4 Payload byte 2
Payload byte 0 controls the GWS appearance:
Payload byte 0 Display
0x00 Blank gear selection (appears off)
0x20 P
0x80 D
0x81 D, can move to M/S
0x81 M/S (if lever moved to side)
0x40 R
0x60 N
+ 0x08 To flash the selected gear light
Payload bytes 1 & 2 are ignored by the GWS.
To set the backlight of the GWS, message ID 0x202 should be sent as follows:
Byte Meaning
0 Backlight Level (0x00 - 0xFF)
1 Unknown (0 works)
CAN Diagnostics
BMW UDS uses "extended 11-bit ISO-TP addressing", and the GWS responds to at least some standard UDS requests sent to ID 0x5e (first byte of CAN messages).[5]
Part Numbers
BMW F-Series Gear Selector (LHD Version) [6]
Normal Version
No LHD/RHD Description Part Number Vehicles Used Status Tested
1 RHD Gear Selector Switch 61 31 9296897 F20, F21, F22, F23
F30, F31, F32, F33, F34, F36
Active
1 RHD Gear Selector Switch 61 31 9291519 Until 06/2013
1 RHD Gear Selector Switch 61 31 9260969 Until 08/2012
1 RHD Gear Selector Switch 61 31 9253652 Until 01/2011
1 LHD Gear Selector Switch 61 31 9296896 F20, F21, F22, F23
Active
1 LHD Gear Selector Switch 61 31 9291517 Until 11/2012
1 LHD Gear Selector Switch 61 31 9260968 Until 06/2013
1 LHD Gear Selector Switch 61 31 9253651 Until 01/2011
Sport Version
2 RHD Gear Selector Switch, Sport 61 31 7950385 Active
2 RHD Gear Selector Switch, Sport 61 31 9296899 F20, F21, F22, F23
Until 05/2018 X
2 RHD Gear Selector Switch, Sport 61 31 9291521 Until 11/2012
2 RHD Gear Selector Switch, Sport 61 31 9260971 Until 07/2012
2 RHD Gear Selector Switch, Sport 61 31 9253654 Until 01/2011
2 LHD Gear Selector Switch, Sport 61 31 7950384 Active
2 LHD Gear Selector Switch, Sport 61 31 9296898 F20, F21, F22, F23
Until 01/2019
2 LHD Gear Selector Switch, Sport 61 31 9291520 Until 06/2013
2 LHD Gear Selector Switch, Sport 61 31 9260970 Until 06/2013
2 LHD Gear Selector Switch, Sport 61 31 9253653 Until 01/2011
