Toyota Prius Gen3 Board
Prius Inverter
- Respectable performance. Rated for 50kW output, but tested (Gen2, Gen3 suspected to be similar) to handle 600v, and 350+A for MG2 inverter, 250+A for MG1 inverter, 360kW total (480hp).
Control Board
Development History
Vendors
Support
Inverter Model Numbers
| G9200-47141 | Auris 2012, RHD | ||||||
| G9200-47190 | Auris | F1759-52010 04 | ? | Forum Thread openinverter.com | |||
| G9200-52010 | Yaris | F1759-52010 04 | F1789-52010 | 154x143mm | https://openinverter.org/forum/viewtopic.php?f=14&t=257&p=5828#p5828 | ||
| G9201-52012 | Prius C | F1759-52010 | F1789-52010 | YES (presumably) | Forum Thread openinverter.com |
Assembly Notes
The Prius Gen3 Board is suitable to control any (please add: motor types here) motors.
Note: Early versions of the board have a few mistakes. (Add details)
Source Documentation:
