ZombieVerter VCU
Revision as of 22:49, 13 December 2024 by Steve16 (talk | contribs) (Deleted a word in note 2)
KINDLY NOTE:
  • A fully tested V1a kit is now (Nov2022) available for general sale here. The boards are now shipping with the Wemos wifi module and all parts will be included in the kit. The Olimex header is still there for those who may prefer that option. See this post for the Wemos wifi module mounting location.
Support is available via this section on the forum
There is a growing supply of OEM inverters, chargers, dc/dc converters, heaters, etc, requiring some control method in order to use them in a EV conversion. Instead of replacing the original logic board in these devices (with some devices it is physically impossible to do so), a vehicle control unit (vcu) which talks in its native communication protocol is a much more elegant solution. With a vcu, we can simply tell these logic boards what we want in a language they can understand, and they will do it. As far as they are concerned, they are still installed in the OEM vehicle they left the factory in.
What is not elegant is having a series of bespoke vcu boards for each device. Instead, a master vcu which can handle a variety of different communication protocols(thus a variety of devices) was born; the zombiVerter !
The zombieVerter is available via evbmw's web shop https://www.evbmw.com/index.php/evbmw-webshop/vcu-boards/zombie-vcu
Based around the original design of the open inverter platform, the zombieVerter consists of 2 main parts:
  • a web interface
  • a communication protocol
With onboard wifi, you can access the open inverter web interface (http://192.168.4.1/) to:
  • set up/calibrate the different devices(inverter, charger, etc) connected to the vcu.
  • tune control parameters (throttle, regen, charge speed, charge time, BMS limits, etc)
  • log info
  • graph and plot live data (rpm, amps, charge rate, etc)
  • update firmware
  • pwm
  • canbus
  • linbus
  • sync serial
  • etc
features of the zombiverter offers:
  • Throttle mapping
  • Precharge and contactor control
  • coolant pump control
  • Temp derating
  • BMS limits
  • for/rev/neutral control
  • Graphing and monitoring
  • Firmware updates via the web interface
  • Cruise control
    • traction control*
  • Fuel gauge driver
  • heater controller
  • charge timer
  • custom pwm out puts
  • etc
Location of remaining parts
Parts to be fitted to ZombieVerter VCU
Name Part Numer Alternative Part Number
CONN1
IC10 MCP25625T
IC14 TJA1020 MCP2004
IC19 NCV7356
IC20 TJA1055T
IC21, IC22 AD5160
IC27, IC28, IC29 FAN3122 MIC4422YM (according to https://openinverter.org/forum/viewtopic.php?p=72827#p72827)
NOTE : R50 will need to be changed to 1k and C45 to 1n in order for LIN to work properly. This will be amended on further builds. So if you have a board ordered before 14/03/24 this change is required.
The enclosure kit links
ZombieVerter VCU V1 Part 3
Installation
Pin Out Diagrams
GS450H with zombieverter
VCU pinout diagram
List of connections to system components (GS450 application)
Leaf stack with zombiverter
leaf stack to zombie
Tesla SDU with Zombieverter
Zombieverter Can Bus Control of SDU
Notes:
  • This drawing is intended to show the minimum components and connections needed for Zombieverter control of an OI SDU via Can bus.  Adapting power and Can bus connections for other OI inverters should function in the same manner, but this needs verification.
  • All power connections must be fuse protected.  Fuses are not shown for simplification.
  • The following observations were made using Zombieverter firmware 2.20A and SDU firmware 5.35R:
  1. The Zombieverter does not enable inverter power prior to entering PreCharge mode.  An external device other than the inverter is required to supply the udc measurement for switch to Run mode.  This function is supported by the shunt and BMS options available in the Zombieverter parameters.
  2. A third device must be on the Can bus with the Zombieverter and Inverter.
  3. Requirements 1. and 2. are satisfied in the drawing by the IVT shunt.
  4. All devices except the Zombieverter are shown as powered by the ignition switch.  Some devices may need to move to permanent 12V supply to support other functions, such as charging.
  5. An inverter power relay is required for Zombieverter control.
  6. Can mapping to pass data and commands from the Zombieverter to the inverter is hard coded in the firmware for both devices.  Manual mapping is required for the inverter to transmit data to the Zombieverter.  The Zombieverter is hard coded to receive this data.  The following values need to be manually mapped in the inverter. Note: mapping uses hex address values, multipliers may need to change to provide correct values (confirm in Zombieverter spot values), inverter udc gets mapped to inv udc in the Zombieverter.
Spot Value Hex Address Offset # Bits Multiplier Map
speed 400 0 16 1 Tx
tmphs 410 0 16 10 Tx
udc 420 0 16 10 Tx
opmode 430 0 8 1 Tx
Initial start-up and testing
Wifi Setup
Configuration Setup
  • Apply the Ignition T15 in 12V signal. The relay supplying 12V to the inverter should now be on.
  • Check the accelerator by applying it gradually and watching / refreshing the interface. You should see values at pot change as the pedal is pressed. potmin should be set just above where your off-throttle position is, and potmax just below the value seen at maximum travel [note this is the opposite for versions 1.06A to 1.11A ). Same for pot2min and pot2max, if they are electrically connected. The resulting value as a 0-100 value can be seen at potnom.
  • Once the contactors are on, select forwards direction. For example if dirmode is set to "Switch" then a 12V signal applied to the Forward input will work.
  • Carefully apply the accelerator and the motor should begin to turn. Do not spin the motor up to any speed if you are using a test power supply.
    • Note: Leaf inverter requires minimum of 180v to operate, it is also sensible to test with rev limit set to 1000 RPM.
leaf stack with zombiverter
Software
GD variant:
Status as of November 20 2021
UPDATE November 23 2021
68 - // adc_start_conversion_regular(ADC1); // Comment out for GD MCUIn the file "stm32_can.cpp" @ starting at line 305 modify as follows :
That recursively pulls in copies of libopeninv, etc and tracks them...   Hence your file-path should look like
./Stm32-vcu/libopeninv/src/
Software update
Initializing an ISA Shunt
Under Comms in the web interface, there is now an ISAMode option. By default its in "Normal" (Off on Rev 2). If you want to initialize a new shunt, connect it up, power on the shunt and vcu, select "Init" (On on Rev 2), hit save parameters to flash. Power cycle the vcu and shunt at same time (they should be on same 12v feed anyway). The shunt will initialize. Select ISAMode "normal" (Off on Rev 2), save to flash again and reboot again. The shunt should now be up and running. If the shunt doesn't initialise correctly, separate the shunt and VCU supplies and power cycle the VCU two or three seconds after the shunt power is cycled. This has fixed an initialise issue for a number of ISA shunts and possibly requires a VCU code fix that delays the initialising for a few seconds to allow the shunt to power up.
Low side Outputs.
  • GP Out 3
  • GP Out 2
  • TransSL2- (If not using the GS450H)
High side PWM.
  • PWM 3
  • PWM 2
  • PWM 1
Ground Input pins
PB1
PB2
PB3
Pin functions:
  • ChaDemoAIw - OUTPUT - used as part of the Chademo charging protocol for the charge allow output to the charger.
  • OBCEnable - OUTPUT: activates as part of the ExtCharger module
  • HeaterEnable - OUTPUT: activates only in run mode and when coolant pump is on
  • RunIndication - OUTPUT: activates when zombie is in run mode
  • WarnIndication - OUTPUT
  • CoolantPump - OUTPUT: activates during precharge, usually used for coolant pumps
  • NegContactor - OUTPUT: activates during precharge for negative contactor
  • BrakeLight - OUTPUT: activates when brake input is detected
  • ReverseLight - OUTPUT: activates when direction is reverse
  • BrakeVacPump DIGITAL OUTPUT: when BrakeVacSensor below threshold this is turned on.
  • HeatReq - DIGITAL INPUT
  • HVRequest - DIGITAL INPUT - when used with ext charger setting will start precharge cycle and put VCU into charge mode.
  • ProxPilot - ANALOGUE INPUT - detect a charging cable plug in, requires external resistors, values depend on type 1 or type 2
  • BrakeVacSensor - ANALOGUE INPUT - read a vacuum sensor and turn on the BrakeVacPump DIGITAL OUTPUT
  • CoolingFan - OUTPUT: activates when FanTemp setpoint is reached
  • HVActive - OUTPUT: activates when contactors are closed and VCU is in run or charge mode
  • PWMTim3 -
  • CpSpoof - PWM OUTPUT: used to spoof CP signal to OBC if also using a charging interface such as FOCCCI or I3LIM
  • GS450Hpump - PWM OUTPUT: used to run GS450H oil pump
Proximity Pilot
Firmware
[Note2: To keep this in mind too, there is a page with zombieverter parameters and their value ranges, ZV pinmap etc. This was created in October for version 2.17.A as indicated in spot values table.]
Parameter Explanation
General Setup
Inverter OEM Inverter being repurposed.
Leaf_Gen1 is not only for first gen leafs, it works with others.
Vehicle Selection of vehicles supported by CAN
GearLvr Various gear levers supported by CAN
Transmission
interface Charging Interface
Is there a system between the charging port and the onboard charger, various supported fast-charging interfaces.
chargemodes What type of battery charger is in the vehicle.
BMS_Mode Types of supported BMSs. Works with ShuntType parameter (?how?)
ShuntType Type of current measuring shunts. Effects the list of BMS_Mode parameter.
InverterCan
VehicleCan
ShuntCan
LimCan
ChargerCan
BMSCan
ODB2CDan
CanMapCan
DCDCCan
HeaterCan
MotActive Selects how to use the two-motor setups (MG1 and MG2) inside Toyota drivetrains.
Mg1and2 - Uses MG1 and MG2 (in what way? how?)
Mg1 - Just MG1
Mg2 - Just MG2
BlendingMG2and1 - For low speed driving, only MG2 is used, but when higher throttle demanded, also engages MG1 to help
Throttle
revRegen On/Off, sets if vehicle uses regenerative braking when in reverse.
throtmaxRev Sets what percentage of throttle is available in reverse (is this scaled, or just capped?)
Charger Control
ChgACVolt AC voltage of charger.
ChgEff Sets expected charger efficiency (to help software accommodate for losses? perhaps for timing predictions?)
ConfigFocci On/Off one-click setup if using the open-source FOCCI (link?) DC Fast Charging hardware, communicates with the FOCCI module
General Purpose I/O
PumpPWM Selects between gear oil pump or repurposes as a tachometer signal.
GS450hOut - If using GS450h transmission oil pump drive.
TachoOut - If wanting to drive an analog tachometer from transmission pulses. Works with TachoPPR parameter.
PWM1Funct General use PWM (?).
CpSpoof - Allows spoofing signals between different charging hardware to allow communication across CAN & PWM expectations. Works with CP_PWM parameter.
PB1InFunc General use pin functions. I.E. Gear positions.
ONLY leave open/floating or connect to ground. No 12v, 5v anything ese. Do not have current or voltage driven into them, do not drive any signals with these, it will destroy the hardware.
ppthresh Proximity Pilot (plug present) Threshold. Detects the presence of charge plug to enable charging.
DigiPot1Step Sets resistance of digital potentiometer.
FanTemp Allows fan control by setting temperature fans would turn on.
TachoPPR Calibrates how many Pulses Per Revolution to give an analog tachometer, depending on what the OEM expectation was. Works with PumpPWM parameter.
PWM Control
CP_PWM This is effectively a spot value as the code that would use it is commented out. It shows the spoofed CP value if using i3LIM, CPC or Focci interface.
Troubleshooting
Serial Connection
