Toyota Prius Gen2 Board
Revision as of 06:33, 18 April 2020 by Konstantin8818 (talk | contribs) (updated picture of c5 connector)
Prius Board v1
Prius Inverter
Prius Gen 2 Inverter Montage
  • Respectable performance. Rated for 50kW output, but tested to handle 600v, and 350+A for MG2 inverter, 250+A for MG1 inverter, 360kW total (480hp).
Control Board
How To Use
The control board utilizes the Blue Pill (link?) microcontroller, and takes advantage of the OpenInverter.org software (link?) for control. It is also connected from the outside via the main (32 pin white) OEM connecter - try to retrieve this connecter and part of wiring loom when sourcing your inverter. Picture of connecter further down in wiki.
Functionality of the existing resolver is intergrated as well.
Wire Connections
Prius Control Board - Wiring Map (click to see fullsize details)
Control Board Pinout:
Pin # Designation Description
TB1-1 12v-in Primary 12v supply from ignition on
TB1-2 GND Primary ground connection to 12v negative. All grounds are common
TB1-3 5v VCC 5V supply from board for use with throttle pot or hall pedal
TB1-4 Throttle In 0-5v variable voltage input from throttle pedal or pot
TB1-5 Regen In 0-5v variable voltage input. Can be used as second throttle channel or control regen from a brake pressure sensor
TB1-6 GND
TB1-7 Brake In 12v digital input from brake light switch.
TB1-8 Start In 12v digital input from "Start" position on a traditional ignition switch. Momentary action push button can be used.
TB1-9 For In 12v digital input commands motor to run in forward direction
TB1-10 Rev In 12v digital input commands motor to run in reverse direction
TB3-1 +12v VCC 12v output to inverter IGCT terminal (Not on the 32-pin connector, the red wire on the 2-pin connector next to it).
TB3-2 GND Common ground, but used to connect to inverter GND terminal (Not on the 32-pin connector, the black wire on 2-pin connector next to it).
TB3-3 Phase U
Phase U output. Connect to Inverter MUU terminal for MG2 inverter drive or GUU for MG1 inverter drive
TB3-4 Phase Y Phase V output. Connect to Inverter MVU terminal for MG2 inverter drive or GVU for MG1 inverter drive
TB3-5 Phase W Phase W output. Connect to Inverter MWU terminal for MG2 inverter drive or GWU for MG1 inverter drive
TB3-6 Current U Phase currents from inverter. Requires external divider circuit. Not required to run motor or inverter.
TB3-7 Current Y Phase currents from inverter. Requires external divider circuit. Not required to run motor or inverter.
TB3-8 MG2 Enable Connect to Inverter MSDN to run MG2 inverter or GSDN to run MG1 inverter
TB3-9 MG2 Fault Connect to MFIV for MG2 or GFIV for MG1
TB3-10 DC Bus Connect to inverter VH to measure DC link voltage
TB2-1 +5V VCC 5v output to encoder for induction motor
TB2-2 ENCA In Encoder input A
TB2-3 ENCB In Encoder input B
TB2-4 GND Encoder ground
TB2-5 HS Temp Heatsink temp sensor input
TB2-6 MOT Temp Motor temp sensor input
TB4-1 GND Common ground
TB4-2 Main Con Main HV contactor control low side switch
TB4-3 Precharge HV precharge contactor control low side switch
TB4-4 +12 V VCC Spare 12v output
TB4-5 CAN L Can bus low signal
TB4-6 CAN H Can bus high signal
32-pin Prius Inverter Pinout:
1 NC Not connected
2 GIVA MG1 Phase Current V Example
3 GIVB MG1 Phase Current V Example
4 GUU MG1 PWM U - Speed Signal Wave Example
5 GVU MG1 PWM V - Speed Signal Wave Example
6 GWU MG1 PWM W - Speed Signal Wave Example
7 MIVA MG2 Phase Current V Example
8 MIVB MG2 Phase Current V Example
9 MUU MG2 PWM U - Speed Signal Wave Example
10 MVU MG2 PWM V - Speed SIgnal Wave Example
11 MWU MG2 PWM W - Speed Signal Wave Example
12 VH Inverter Capacitor Voltage Example
13 CPWM Boost converter PWM switch signal Example
14 GSDN MG1 Shutdown Example
15 VL Boost converter input voltage Example
16 GINV Inverter Ground Example
17 NC Not connected
18 GIWA MG1 Phase Current W Example
19 GIWB MG1 Phase Current W Example
20 CT Boost converter temperature sensor Example
21 GIVT MG1 Inverter Temperature Example
22 GFIV MG1 Inverter Fail Example
23 MIWA MG2 Phase Current W Example
24 MIWB MG2 Phase Current W Example
25 MSDN MG2 Shutdown Example
26 MIVT MG2 Inverter Temperature Example
27 MFIV MG2 Inverter Fail Example
28 OVH Overvoltage Example
29 CSDN Boost converter shutdown signal Example
30 FCV Boost converter fail signal Example
31 OVL Boost converter over voltage signal Example
32 GCNV Boost converter ground Example
DC-DC Converter
Prius Gen2 DC-DC connections.
The onboard DC-DC Converter is powered by the high voltage traction battery to supply 12v and up to 100A for low-voltage automotive components and 12 battery charging (plays the role of a traditional alternator). Control is not currently supported by the v1 control board, however, direct control of the converter is simple.
Only 2 wires are necessary to activate it. The 6-pin "C5" connector on the inverter needs to be wired as thus:
1 ?? 12v+ ??
2 Unused? Unused? ??
3 Unused? Unused? ??
4 NODD 0-5v+ ??
5 VLO Unused? ??
6 Unused? Unused? ??
The case of the inverter must be vehicle ground (12v battery negative terminal).
This will produce 13.2-15.2 VDC on the large C6 single-conductor connector nearby (equivalent to a car's 12v battery positive terminal), depending on voltage applied to pin 4. No base load is required to produce voltage.
Note that this output is unfused and uncontrolled, and not disabled when the main inverter ignition is off (it will be on all the time unless pin 1 of the C5 connector is off). It could be tied directly to the ignition switch same as the control board ignition receives (TB1-8 on the control board ... Or should that be TB1-1/TB1-2 which is controlled by ignition???), or it could have separate power-on control if desired.
Inverter Cooling
