Toyota Prius Gen2 Board
Revision as of 05:33, 15 August 2020 by RetroZero (talk | contribs) (Added first 4 steps of et up.)
Prius Gen 2 Inverter Montage
  • Large part availability, Prii have been made in large numbers for 20 years and spares are inexpensive.
  • Respectable performance. Rated for 50kW output, but tested to handle 600v, and 350+A for MG2 inverter, 250+A for MG1 inverter, 360kW total (480hp).
1 vacant
2 GIVA MG1 Phase Current V Example
3 GIVB MG1 Phase Current V Example
4 GUU MG1 PWM U - Speed Signal Wave Example
5 GVU MG1 PWM V - Speed Signal Wave Example
6 GWU MG1 PWM W - Speed Signal Wave Example
7 MIVA MG2 Phase Current V Example
8 MIVB MG2 Phase Current V Example
9 MUU MG2 PWM U - Speed Signal Wave Example
10 MVU MG2 PWM V - Speed SIgnal Wave Example
11 MWU MG2 PWM W - Speed Signal Wave Example
12 VH Inverter Capacitor Voltage Example
13 CPWM Boost converter PWM switch signal Example
14 GSDN MG1 Shutdown Example
15 VL Boost converter input voltage Example
16 GINV Inverter Ground Example
17 vacant
18 GIWA MG1 Phase Current W Example
19 GIWB MG1 Phase Current W Example
20 CT Boost converter temperature sensor Example
21 GIVT MG1 Inverter Temperature Example
22 GFIV MG1 Inverter Fail Example
23 MIWA MG2 Phase Current W Example
24 MIWB MG2 Phase Current W Example
25 MSDN MG2 Shutdown Example
26 MIVT MG2 Inverter Temperature Example
27 MFIV MG2 Inverter Fail Example
28 OVH Overvoltage Example
29 CSDN Boost converter shutdown signal Example
30 FCV Boost converter fail signal Example
31 OVL Boost converter over voltage signal Example
32 GCNV Boost converter ground Example
DC-DC Converter
Prius Gen2 DC-DC connections.
The onboard DC-DC Converter is powered by the high voltage traction battery to supply 12v and up to 100A for low-voltage automotive components and 12 battery maintenance (plays the role of a traditional alternator). Direct control of the converter is simple as only 1 wire is necessary to activate it, but a second can be added in order to enhance control.
The 6-pin "C5" connector on the inverter needs to be wired as thus:
1 IGCT 12v+ Blue
2 ID1 Not Needed Purple
3 S B+ (opt) White
4 NODD 0-5v+ Ppl/Gld
5 VLO Not Needed Blue
6 Vacant
The case of the inverter must be vehicle ground (12v battery negative terminal).
This will produce 13.2-15.2 VDC on the large C6 single-conductor connector nearby (equivalent to a car's 12v battery positive terminal), depending on voltage applied to pin 4 (if used). No base load is required to produce voltage. Pin 4, when grounded, will act as a "KILL" input and DC-DC output will drop to zero.
Note that this output is unfused and uncontrolled, and not disabled when the main inverter ignition is off (it will be on all the time unless pin 1 of the C5 connector or the HV inputs are off). It could be tied directly to the ignition switch same as the control board ignition receives (TB1-8 on the control board ... Or should that be TB1-1/TB1-2 which is controlled by ignition???), or it could have separate power-on control if desired.
Note on Limitations - As the signal to turn on the 12v converter (which converts the HV traction battery voltage down to 12v) requires some 12v power to turn itself on. The DC-DC system is not designed to charge up a low 12v battery and certainly not one that's completely dead. Doing so can damage the inverter/converter.
Inverter Cooling
Through Hole Control Board
Prius Board v1
How To Use
Wire Connections
Prius Control Board - Wiring Map (click to see fullsize details)
Control Board Pin mapping:
TB1-1 12v-in Primary 12v supply from ignition on
TB1-2 GND Primary ground connection to 12v negative. All grounds are common
TB1-3 5v VCC 5V supply from board for use with throttle pot or hall pedal
TB1-4 Throttle In 0-5v variable voltage input from throttle pedal or pot
TB1-5 Regen In 0-5v variable voltage input. Can be used as second throttle channel or control regen from a brake pressure sensor
TB1-6 GND
TB1-7 Brake In 12v digital input from brake light switch.
TB1-8 Start In 12v digital input from "Start" position on a traditional ignition switch. Momentary action push button can be used.
TB1-9 For In 12v digital input commands motor to run in forward direction
TB1-10 Rev In 12v digital input commands motor to run in reverse direction
TB3-1 +12v VCC 12v output to inverter IGCT terminal (Not on the 32-pin connector, the red wire on the 2-pin connector next to it).
TB3-2 GND Common ground, but used to connect to inverter GND terminal (Not on the 32-pin connector, the black wire on 2-pin connector next to it).
TB3-3 Phase U
Phase U output. Connect to Inverter MUU terminal for MG2 inverter drive or GUU for MG1 inverter drive
TB3-4 Phase Y Phase V output. Connect to Inverter MVU terminal for MG2 inverter drive or GVU for MG1 inverter drive
TB3-5 Phase W Phase W output. Connect to Inverter MWU terminal for MG2 inverter drive or GWU for MG1 inverter drive
TB3-6 Current U Phase currents from inverter. Requires external divider circuit. Not required to run motor or inverter.
TB3-7 Current Y Phase currents from inverter. Requires external divider circuit. Not required to run motor or inverter.
TB3-8 MG2 Enable Connect to Inverter MSDN to run MG2 inverter or GSDN to run MG1 inverter
TB3-9 MG2 Fault Connect to MFIV for MG2 or GFIV for MG1
TB3-10 DC Bus Connect to inverter VH to measure DC link voltage
TB2-1 +5V VCC 5v output to encoder for induction motor
TB2-2 ENCA In Encoder input A
TB2-3 ENCB In Encoder input B
TB2-4 GND Encoder ground
TB2-5 HS Temp Heatsink temp sensor input
TB2-6 MOT Temp Motor temp sensor input
TB4-1 GND Common ground
TB4-2 Main Con Main HV contactor control low side switch
TB4-3 Precharge HV precharge contactor control low side switch
TB4-4 +12 V VCC Spare 12v output
TB4-5 CAN L Can bus low signal
TB4-6 CAN H Can bus high signal
New SMT control board with enclosure and designated pinouts
Please add pictures and description.
Pin Mapping - Note : Smaller 12-pin socket is the interface to the inverter & 20-pin to the motor
20 - Pin socket
Pin#01 - ENC_B/S3
Pin#02 - S1S4
Pin#03 - ENC_A/S2
Pin#04 - R1
Pin#05 - R2
Pin#06 - 5V
Pin#07 - THROTTLE 1
Pin#08 - THROTTLE 2
Pin#09 - START_IN (12V)
Pin#10 - BRAKE_IN (12V)
Pin#11 - FORWARD_IN (12V) (3 way switch)
Pin#12 - REVERSE_IN (12V) (3 way switch)
Pin#13 - MTEMP -
Pin#14 - MTEMP +
Pin#15 - DCSW_OUT (Ground signal)
Pin#16 - PRECARGE_OUT (Ground signal)
Pin#17 - CAN L
Pin#18 - CAN H
Pin#19 - GND
Pin#20 - 12V
12 - Pin socket ( starts at pin number #21) - Corresponding pin on Main White 32 pin Inverter connecter is in brackets.
Pin#21 - GIVA (2)
Pin#22 - MIVA (7)
Pin#23 - GIWA (18)
Pin#24 - MIWA (23)
Pin#25 - VH (12)
Pin#26 - MIVT (26)
Pin#27 - MFIV (27)
Pin#28 - MUU (9)
Pin#29 - MVU (10)
Pin#30 - MWU (11)
Pin#31 - CPWM (13)
Pin#32 - GINV/GCNV (16/32)
Connect MSDN Pin#25 in inverter (not 25 on controller) permanently to 12V to enable the MG2 Inverter
Connect CPWM to 12V via a 470 Ohm resistor for charge mode.
Connect the 2-pole white power connector (inside inveretr) to 12V and Ground to power up inverter electronics.
Step 1 : Solder relevant (and included) connector pins to the Adapter Board
Step 2 : Plug in Wifi Adapter and connect ONLY Pin#19 - GROUND and Pin#20 - 12 Volts power supply
Confirm PWR LED lights up along with WIFI LED. Confirm ALIVE LED flashes.
Step 3 : Connect computer/laptop to the wifi network (Example - Inverter 7)
Step 4 : Go to search enginge (Google/Firefox etc) toolbar and type in 192.168.4.1 + Enter. (allow pop ups/Trusted site). Confirm Web based Interface appears and list of parameters appear.
If parameters appear, you are now connected to the Adapter board and the Web based Interface - Congratulations - You are now in the Matrix !
Software
The Control Board runs Open Inverter software. A set of known-good default inverter parameters can be found here: https://openinverter.org/wiki/Configuration_Files#Toyota_Prius_Gen2_Inverter
Do NOT program a deadtime value for the Gen2 inverter. It only uses 1 PWM per phase and the inverter itself generates a low-side and high-side signal WITH deadtime.
