Control of the two inverters at the same time
- Has thanked: 14 times
- Been thanked: 5 times
Hi! Сan connect two control units via the can bus to control both units synchronously, connect the accelerator pedal to one control unit, and transmit the position of the gas pedal to the second control unit via the can bus ?
- Has thanked: 383 times
- Been thanked: 1580 times
Re: Control of the two inverters at the same time
Absolutely.
Map "pot" to can bus on inverter 1, e.g.
can tx pot 1 0 16 1
And on inverter 2 (set potmode to CAN)
can rx pot 1 0 16 32
Configure the same throttle ranges etc. Done
can tx pot 1 0 16 1
- Has thanked: 406 times
- Been thanked: 260 times
You sure?
Because I don't see any pictures of video...
"I slept with Scarlett Johansson"
... not very convincing, is it?
Any update on controlling two motors, would love to hear about the build!
