Prius Gen3 Inverter Hacking
kalebludlow
Re: Prius Gen3 Inverter Hacking
Post by kalebludlow »
Bigpie wrote: Thu May 07, 2020 10:23 am I've scored an inverted from ebay for £90 but it doesn't come with the ampseal connector. Any one got any leads on a supplier?
I'm gonna go down to my local parts supplier next week and see what they say, hopefully they can give me some idea of where I can go
Has thanked: 75 times
Been thanked: 696 times
If you intend on using my logic board you don't need the toyota connector just a standard ampseal 35 way which I will supply with the full kit option.
Has thanked: 89 times
Been thanked: 481 times
Ahh excellent. I have one of your boards on order :D
It's worth noting, there's a lot of inverters on eBay at a high price, but have been listed for months and ripe for negotiations.
Taking a look at the Gen 3 prius dcdc today. Based on the work By Mouse it seems to share the same hv voltage detection circuit as the Yaris albeit the logic board is mounted on a ribbon cable to the power board instead of all on one. Anyway , found the two networks of 4x 120k in series with a 5k1. Based on Mouse's calcs that would put a voltage of 2.47v on the 5k1 at 235vdc input. Changing these to 210k would give 2.44v on the 5k1 at 405vdc on the input.
Also seems the prius uses 1uF 400v poly caps for smoothing so decided to order some 450v replacements. Will do the mods and report back once the parts arrive.
kalebludlow
So at home I have access to 415v 3PH 60A service, will the charging circuitry in the Prius inverters (Auris specifically) be able to handle levels like this?
Alexstarex
Post by Alexstarex »
Recently,
the inverter from aqua burned out.
I have a question -
how to dispose of it? Just throw it away? or hand over to a processing plant?.
I mean, does it have the right parts?
Well folks the numbers are in and the internet was wrong!!
Prius Gen 3 MG2 power stage shuts down at 500amps. Yes 500amps.
Kevin Sharpe
Been thanked: 9 times
Post by Kevin Sharpe »
Jack Bauer wrote: Mon Jun 01, 2020 3:30 pm Prius Gen 3 MG2 power stage shuts down at 500amps. Yes 500amps.
Fabulous :D
Yeah. Had a guy on instagram yesterday tell me its only good for 100amps. He just knew this for fact of course. No need to test.
Has thanked: 427 times
Been thanked: 267 times
Post by MattsAwesomeStuff »
Jack Bauer wrote: Mon Jun 01, 2020 3:30 pmPrius Gen 3 MG2 power stage shuts down at 500amps. Yes 500amps.
Good lord.
Gen2 MG2 shut down at 350A.
Whelp, there's a big feather in the cap of the Gen 3.
400hp. Out of half of a Prius inverter.
Wiki updated.
You should keep a whiteboard in the shop, of Damien vs. The World.
You can be like the lie-detector episodes of daytime trash TV, Maury. "You said you were faithful to your wife when she was away on a trip, the lie detector determined THAT was a lie. You said you didn't get her sister pregnant, the lie detector determined THAT was a lie. You said you've never stolen her underwear and worn it out to the bar, the lie detector determined THAT was a lie."
Eflyers
Post by Eflyers »
Jack Bauer wrote: Mon Jun 01, 2020 3:30 pm Well folks the numbers are in and the internet was wrong!!
Are you sure this isn't a graph of how much overwork stress, answering repeated stupid questions, and trying NOT turn this into a business before you shut down?
Its been amazing reading some comments on line after I posted about this. Its like the Borg, they just adapt to keep pushing the same crap in the face of evidence to the contrary. I really don't understand why. Is it ignorance, general prius hate or something else?
Kevin Sharpe
Jack Bauer wrote: Tue Jun 02, 2020 10:09 am Its been amazing reading some comments on line after I posted about this. Its like the Borg, they just adapt to keep pushing the same crap in the face of evidence to the contrary. I really don't understand why. Is it ignorance, general prius hate or something else?
Got to factor in vested interests... ultra low cost conversions are 'dangerous' to anyone selling expensive new or converted electric cars :shock:
jnsaff
Been thanked: 8 times
Post by jnsaff »
I guess the reason number one is that these questions have for the most part been answered in the forum before and although the threads are long and the info might be buried the person has not bothered to find it. Wikis help with that but someone needs to do it.
kalebludlow
Kevin Sharpe wrote: Tue Jun 02, 2020 10:13 am ultra low cost conversions
All we are missing now is a motor that can take advantage of all this power that is also cheap :P
Board arrived today, cheers Damien. I've been soldering it up and taking close up photos as I go. I'll write up and add to the wiki to augment the video. The 50 way connector was a pain. I understand why you've jacked in the fully assembled boards :D
invokeperformance
Post by invokeperformance »
Bigpie wrote: Fri Jun 05, 2020 6:36 pm Board arrived today, cheers Damien. I've been soldering it up and taking close up photos as I go. I'll write up and add to the wiki to augment the video. The 50 way connector was a pain. I understand why you've jacked in the fully assembled boards :D
Bigpie thanks for sharing. I plan to order my gen 3 board very soon also so I would love to see your findings!! Cheers
Has thanked: 145 times
Been thanked: 369 times
kalebludlow wrote: Thu Jun 04, 2020 11:53 pm
I have Outlander rear motor here waiting to be fitted into some vehicle. Preferably Audi A2. If we can get CAN torque control with original inverter then ok, if not Auris inverter is the way to go.
Dilbert, did you do any more on the prius inverter control signals? Looks like I might finally get a test bench going.
vin
Post by vin »
Jack Bauer wrote: Thu Apr 25, 2019 1:22 pm It requires a duty. If you look at the circuit diagram on the github for the logic board it should make sense. It defaults to 14v with no control signal.
also see here for gen 2 : http://nicjam.es/how-to-turn-on-the-gen ... converter/
Hi Damien,
It seams that this link is broken, any chance of replacing it please? Basically I'm trying to find operation voltage for the Gen 2 DC to DC, not sure if my wiring is wrong or it's protecting itself. I'm testing the bear inverter without VCU and starting from scratch again on this.
zilion
Post by zilion »
vin wrote: Wed Mar 24, 2021 1:25 pm It seams that this link is broken, any chance of replacing it please?
https://nicjam.es/projects/how-to-turn- ... er-module/
celeron55
Has thanked: 38 times
Been thanked: 136 times
Post by celeron55 »
Has anyone noted what the maximum voltage of the Auris inverter battery side capacitor is? Prius is 400V, Yaris is 350V(?), but what does the Auris have?
kalebludlow
celeron55 wrote: Sun Sep 05, 2021 7:54 am Has anyone noted what the maximum voltage of the Auris inverter battery side capacitor is? Prius is 400V, Yaris is 350V(?), but what does the Auris have?
My understanding was that Auris and Yaris are identical in terms of actual components
NiHaoMike
Post by NiHaoMike »
What's the mapping of the power board temperature signal voltages to temperature?
