Lear Coda Charger Help
Been thanked: 1139 times
Folks, anyone have any info or experience in running the Lear charger from a coda? Seems the one I have in the deranged rover is a coda variant and seems to not like Arber's CAN messaging. Any help much appreciated as its the last piece of the deranged rover puzzle:)
Using this data :
https://leafdriveblog.wordpress.com/201 ... a-charger/
Attached a few can captures.
Is there any sequence required like ac on , dc on then send can etc?
run1_nocurrent.csv
(126.03 KiB) Downloaded 138 times
powerup_nohv_noac1.csv
(61.32 KiB) Downloaded 156 times
mdrobnak
Re: Lear Coda Charger Help
Post by mdrobnak »
Tom added code to simpbs for the volt version..take a look at that. Messages and such are way different.
https://github.com/tomdebree/AmperaBatt ... .ino#L3578
-Matt
Has thanked: 330 times
Been thanked: 848 times
mdrobnak wrote: Thu Jul 09, 2020 2:48 pm Tom added code to simpbs for the volt version..take a look at that. Messages and such are way different.
-Matt
Shit you beat me to it. Yes I have added the coding and this is verified by one user, so it should be right for the CODA lear charger.
Thanks guys will give that a shot. What frequency does that message have to go at?
Been thanked: 413 times
Jack Bauer wrote: Thu Jul 09, 2020 3:09 pm Thanks guys will give that a shot. What frequency does that message have to go at?
Yeah... Coda version uses totally different CAN IDs. I remember i saw EVTV had some info on them...
Yup! See files attached. I never tried one since i havent got the charger though...
Lear_Coda_Charger_Documentation_12_12_2014.pdf
(927.63 KiB) Downloaded 231 times
Single_Lear_Charger_wiring_9_15_2014.pdf
(32.48 KiB) Downloaded 163 times
Lear_Charger_Documentation_10_23_2014.pdf
(131.5 KiB) Downloaded 185 times
Thanks Arber:)
Up and running. Thanks for the help guys.
