Just an FYI for anyone playing with the Outlander motors. I noticed Fiesta clutches had the same bore and spline count so grabbed one out of the recycling bin at my local garage today. Sure enough, it's a very good fit with very little play.
I've added this to the wiki here along with the model number: https://openinverter.org/wiki/Mitsubish ... put_Shafts
FYI: Fiesta clutch fits front motor splines
- bobby_come_lately
- Has thanked: 41 times
- Been thanked: 40 times
- Kevin Sharpe
- Been thanked: 8 times
Re: FYI: Fiesta clutch fits front motor splines
very cool, thanks for sharing
- Has thanked: 58 times
- Been thanked: 14 times
Great information!
- bexander
- Has thanked: 71 times
- Been thanked: 97 times
If you wan't to find out which other cars clutches might fit as well you can search on the number here:
https://aftermarket.zf.com/go/en/sachs/catalogs/#/
Then you will find that the following part numbers should also fit:
FORD
1518195
1529952
1576249
1678827
1708209
1804545
1805271
1826509
1852056
2115219
2245763
8V21-7540-DA
8V21-7540-DB
8V21-7540-DC
8V21-7540-DD
8V21-7540-DE
8V21-7540-DF
8V21-7540-DG
8V21-7540-FA
8V21-7550-DE
8V21-7563-DD
RM8V21-7540-DF
RM8V21-7540-DG
RM8V21-7540-FA
MAZDA
Y604-16-490
Y604-16-490A
Y604-16-490B
Y604-16-490C
Y604-16-490D
Y604-16-490E
FORD
1518195
1529952
1576249
1678827
1708209
1804545
1805271
1826509
1852056
2115219
2245763
8V21-7540-DA
8V21-7540-DB
8V21-7540-DC
8V21-7540-DD
8V21-7540-DE
8V21-7540-DF
8V21-7540-DG
8V21-7540-FA
8V21-7550-DE
8V21-7563-DD
RM8V21-7540-DF
RM8V21-7540-DG
RM8V21-7540-FA
MAZDA
Y604-16-490
Y604-16-490A
Y604-16-490B
Y604-16-490C
Y604-16-490D
Y604-16-490E
- bobby_come_lately
That's brilliant! So, plenty of options in short. Shall add these to the wiki later.
- bobby_come_lately
I cut down the Ford clutch today. The centre piece actually drops out - it isn't welded to any of the arms as it is on my BMW clutch plate. Should make it a little easier to weld into a coupler. In the photo below it is partially in/partially out of a 37mm i/d tube.
