another benefit of doing an extender: any capacity i add this way will stay with the car even if i later upgrade the pack. so i could potentially have a 79 kWh leaf if i really got lucky
I believe I posted a full pinout schematics earlier.starpancake wrote: ↑Thu Jul 16, 2020 10:47 am do you have any links describing this? i have a grey/black LBC and a white cable, but i don't really know what would cause that kind of burn out. what is the interconnecting cable you mentioned?
i only have this one LBC so if i burn it out my project is toast :/ thanks![]()
I'm afraid this will going to be a mess...starpancake wrote: ↑Thu Jul 16, 2020 10:39 am i have contactors, 150A fuse hardware, 3-port can bridge, a cabin 12V switch for enabling the aux pack connection, the BMS and the wiring harness. only thing that i'm missing is a current sensor. i'm seeing them on ebay for around $130; does anyone know of a cheaper source? are they just a fat resistor or is there some amplification going on? ultimately i do want current sensing but i'm not sure it's critical just yet.
yeah, i agree. sorry to disappoint, i have decided not to pursue the project since i can buy an older liquid-cooled battery electric car with almost 400 km range for very little here in the US. and i would also not be able to sell the leaf if i modified it substantially. safety is also a concern.prensel wrote: ↑Sun Jul 19, 2020 10:27 amI'm afraid this will going to be a mess...starpancake wrote: ↑Thu Jul 16, 2020 10:39 am i have contactors, 150A fuse hardware, 3-port can bridge, a cabin 12V switch for enabling the aux pack connection, the BMS and the wiring harness. only thing that i'm missing is a current sensor. i'm seeing them on ebay for around $130; does anyone know of a cheaper source? are they just a fat resistor or is there some amplification going on? ultimately i do want current sensing but i'm not sure it's critical just yet.
First of all the LBC needs more then just the hardware you have. Better try to get hold of the original Leaf contactorbox which is/was located in the batterybox. Did you think about how to handle pre-charge ? The current sensor is also some Leaf specific thingy, not sure if the LBC would accept/read any other current sensor since its not CANbus related. In the other post you mention something about a current sensor between 12V and high voltage battery. Not sure what you mean with that..
Just some words of caution:
Remember you are messing with 380V and that any DC voltage over 100V is DEATHLY and will KILL you instantly when thouching and never release it before you DIE !!
This is not something you want to 'try' and peek or poke and wire everything together like its a 9V block battery.
Please do share sourcesstarpancake wrote: ↑Fri Jul 24, 2020 12:01 am yeah, i agree. sorry to disappoint, i have decided not to pursue the project since i can buy an older liquid-cooled battery electric car with almost 400 km range for very little here in the US. and i would also not be able to sell the leaf if i modified it substantially. safety is also a concern.
This is important, please do share the source if possible so that we can break the cycle of abandoned EV developmentmdrobnak wrote: ↑Fri Jul 24, 2020 6:25 amPlease do share sourcesstarpancake wrote: ↑Fri Jul 24, 2020 12:01 am yeah, i agree. sorry to disappoint, i have decided not to pursue the project since i can buy an older liquid-cooled battery electric car with almost 400 km range for very little here in the US. and i would also not be able to sell the leaf if i modified it substantially. safety is also a concern.![]()
the chevrolet bolt EV is selling for under $15,000 in the US and does 400km rather easily. that's what i'm referring toKevin Sharpe wrote: ↑Fri Jul 24, 2020 9:13 amThis is important, please do share the source if possible so that we can break the cycle of abandoned EV developmentmdrobnak wrote: ↑Fri Jul 24, 2020 6:25 amPlease do share sourcesstarpancake wrote: ↑Fri Jul 24, 2020 12:01 am yeah, i agree. sorry to disappoint, i have decided not to pursue the project since i can buy an older liquid-cooled battery electric car with almost 400 km range for very little here in the US. and i would also not be able to sell the leaf if i modified it substantially. safety is also a concern.![]()
Okay, on average of 2600mV per cell.johu wrote: ↑Thu Oct 29, 2020 4:54 pm The LBC power limit is very dynamic, pretty much a voltage control loop. So it may say 40 kW at standstill but as soon as you pull current and the lowest cell approaches 2.5 V the limit will drop rapidly.
I set my inverter limit to 250V and rely on the LBC limit (it is translated to throtmax)
Or 48 cells and connect the two strings of the Leaf BMS in parallel.
I haven't monitored the serial on mine but have found that limp mode kicks in as soon as the first cell drops below 3.2V - so the above fits with my experience.
Can't explain that - that's strange.
This is normal and correct behaviour - are you familiar with Li charging strategies?prensel wrote: ↑Mon Nov 09, 2020 11:29 am - Around 85% SOC it tapers the kW charging power from 55kW down and finally to zero kW, so my charger stops.
At that point the lowest cell is about 4080mV and the highest cell is about 4135mV.
I can restart and it will charge but very quickly it tapers again to 0kW.
