Tesla LDU on a 300hp boat donor motor
Costin J
Post by Costin J »
Hello from Romania!
I have build two electric boats with Tesla modules but now i am close to powering up the Tesla LDU that i cut and modify in order to install it on a proper boat donor motor.
So what do you think about this LDU on a boat? :) 350 Volts. I have a lot of photos with the modified drive unit but the project has to be public only after an event, in about 2 weeks.
Thank you for all your work!
J.
joromy
Re: Tesla LDU on a 300hp boat donor motor
Post by joromy »
Great, pictures please!! :)
Costin J
Post by Costin J »
it had a simple test at 306 V, does not allow power even with full throttle, plot ok for temp, direction, throttle (nissan leaf), it just slowly turns fwd/reverse ok, one error of overcurrent, but that was just precaution (50 amp), so i guess i have an encoder problem? thanks! i just love how it turned out, curious to see if interference because i cut the inverter bell, but i guess not :) It has plexiglass. I have to test again tommorow
Been thanked: 1913 times
What on earth :D never seen the LDU look that small
Yes encoder problem. A/B swapped or not connected at all
Igor
Has thanked: 20 times
Post by Igor »
This is great. Any updates?
JaniK
Has thanked: 101 times
Been thanked: 15 times
Post by JaniK »
Just AWESOME !
That just shows how easy it is to mod electric motors to other uses. Try doing that with a ICE car motor.
Very cool project and idea!
AlexD
Post by AlexD »
Please give us an update :)
nesto1972
Post by nesto1972 »
Hi Costin!
Not afraid from overheating the motor?
Boatapplication is by far not a car!!!how much S1 power the LDU have????60kw?
EV_Builder
Post by EV_Builder »
Well he does has allot of cooling medium in his design...
ted.walsh
Has thanked: 33 times
Been thanked: 23 times
Post by ted.walsh »
Hi, Any update on your project? please let us know!
