Stumbled on this browsing ebay- https://www.ebay.co.uk/itm/BMW-i3-Rapid ... ontroller , part number 6135-9380352
Looking at the Munro i3 report, starting page 2093, it looks like another possible candidate for a CCS controller with suitable reversing
- Has thanked: 11 times
- Been thanked: 346 times
ohhh, those are cheap and less Elon-y.
- mdrobnak
- Been thanked: 5 times
Well, crap.
https://www.ebay.com/itm/Power-Supply-C ... fresh=true buying that now
I'll let Damien poke and prod at the connections first though.
-Matt
-Matt
Seem to be a few of these around :
Ebay US:
https://www.ebay.com/itm/2014-2019-BMW- ... SwmNFfRS-V
https://www.ebay.com/itm/2014-2017-BMW- ... SwA3tfSmz0
Ebay UK :
https://www.ebay.co.uk/c/2232045392
https://www.ebay.co.uk/c/2239314984
Ebay US:
Ebay UK :
Some basic info to get things started.
LIM.pdf
- (66.14 KiB) Downloaded 1851 times
- jalovick
- Has thanked: 10 times
- Been thanked: 7 times
I think there is also a version of this controller in the new BMW Mini Cooper S E.
The parts you've listed with ebay ads are PN: 6135-6828052 And the one at the start of the thread is PN: 6135-9380352
I've also spotted a third module on ebay with PN: 6135-6805847
Is there likely to be any difference between them?
I'm quite interested in this concept as I have a BMW i3 battery.
Who knows... Could be different generations,different regions, LHD/RHD, different firmware for different models/battery sizes perhaps.
Cross-referencing with car variants may give some clues.
Realoem.com for pn to model references.
- mdrobnak
I got a package!
Ooh a 'chassis brain box'
To me it seems held together by those small tabs on the base. Haven't tried to open it yet. Will come back to this later.
-Matt
-Matt
- muehlpower
- Has thanked: 14 times
- Been thanked: 141 times
Are you sure it's a DC (fast charge) version? Part numbers up to 2016!
- mdrobnak
Some shots:
https://en.wikipedia.org/wiki/V850
S/W float.
Dual instruction executing.
7-stage pipeline.
2.56 Dhrystone MIPS/MHz
1.5 mW/MIPS
Multi CPU core support.
Memory Protection.
https://www.renesas.com/sg/en/doc/Docum ... 00_FG4.pdf
Rear door actuator driver is the L9951XP chip.
Edit: Duh, this is all in the block diagram on the top. :: headdesk ::
And that's all I wrote for the moment.
-Matt
A search for the CPU part number yields "NEC uPD70F3550 GCA V850E2/FG4 V850 Microcontroller"https://en.wikipedia.org/wiki/V850
S/W float.
7-stage pipeline.
1.5 mW/MIPS
Memory Protection.
-Matt
- muehlpower
I was looking for plugs that could fit according to the photos.
16 pin: Hirschmann 805-587-545
12 pin: BMW 61138373632, Audi 4E0 972 713, TE 1534152-1
8 pin: BMW 61138364624, Audi 4F0 972 708, TE 1-1534229-1 (only on Chademo models)
6 pin: BMW 61138383300, Audi 7M0 973 119, TE 1-967616-1
All available at Auto-Click UK.
I am planning a stand-alone solution based on the LIM module. It seems that it controls the cunductors for DC, the locking and the LED for the CP. And of course control pilot, proximity and PLC.
I just grabbed one for 65.00 USD.
Need to find the CCS port on the cheap now.
I don't suppose anyone has done anything further on this module?
So did a little research. Our i3 charge port (X994a) dc lines go to A290 which is the kle module or onboard charger. By a stroke of luck I had one in my parts pile so pulled out a boatload of threadlocked fastners and roughly figured out it acts as a dc distribution block and has the fast charge contactors and what looks like a 3.3kw ac charger. Now in the diagram you will see the lim (charge controller) A250*4B pin 5 is called U_HV_DC which seems to be the measured hv on the charge port via that little extra board on the back cover. Anyhow, now that I have a ccs port in the grey goose it needs something to talk to so why not this.
i3_lim.pdf
- (35.28 KiB) Downloaded 1293 times
- mdrobnak
Nice! Maybe we can get some useful data out of that now...just need a i3 to compare to, but I have a feeling our useful control messages will come from there. But do we know how to control _that_ thing?
-Matt
-Matt
- muehlpower
Yes that's right. I thought of a small circuit that takes over this voltage measurement. Maybe you can see if that works. It should make at 0V battery voltage 1.42V and at 500V 4.8V.Jack Bauer wrote: ↑Sun Feb 28, 2021 1:58 pm Now in the diagram you will see the lim (charge controller) A250*4B pin 5 is called U_HV_DC which seems to be the measured hv on the charge port via that little extra board on the back cover.
And the plugs that I specified in my previous post all fit.
Cool. I'll try the bmw circuit first as I have it here. Yeah, we need an i3 pt can capture while ccs charging as a bare minimum.
So it doesnt look like the little board needs anything other than 12v then it outputs a voltage proportional to the hvdc on the charge port. I'll do some investigation to confirm. It also has some hvil pins that can be just shorted.
KLE_board_pinout.pdf
- (25.99 KiB) Downloaded 1225 times
I suppose it's pointless asking if anyone has an i3 capture to share?
- muehlpower
I just called a friend who confirmed that his i3 has a fast charge function. He agrees to give me the car to watch the CAN bus while it is charging. What is the easiest way to create a log file from the CAN bus? What format does such a file have to have?
that would be fantastic! Savvycan is my tool of choice for can logging : https://savvycan.com/
Latest version : https://github.com/collin80/SavvyCAN/re ... continuous
