I got the motor to spin in open loop mode using gen3 inverter. I would like to proceed and try to test if it is possible to use the encoder to run the motor with FOC firmware. I don't really know how to proceed, but I would appreciate the help and guidance and I am ready to follow instructions. Johannes has already mentioned that ABZ encoders are untested to say the least. But is there any chance that this might work?
Other thoughts I am having - is it possible to use some sort of conversion board to convert ABZ to more suitable signal for open inverter?
If all the above fails I will try to use RLS encoder as kindly suggested by arber333. However due to precise mounting tolerances I am a touch frightened if I will be able to achieve those.
First uncertainty regarding the use of ABZ encoder that I have - openinverter firmware allows to choose ABZ as encoder type but there only seems to be 2 encoder inputs. Let's say I find which wires are A, B and Z, which ones I actually need to wire into gen 3 Prius inverter?
