CHAdeMO EVSE side information?
mdrobnak
Post by mdrobnak »
So this is what I have from the JLD505 github and Collin's EVTV video:
pub fn params108(hv_can: &HVCAN) {
    let id: u16 = 0x108;
    let size: u8 = 8;
    let mut params108_frame = DataFrame::new(ID::BaseID(BaseID::new(id)));
    params108_frame.set_data_length(size.into());
    let params108 = params108_frame.data_as_mut();
    params108[0] = 0x00; // Weld check not supported.
    params108[1] = 60; // Max voltage frame.data.byte[1] + frame.data.byte[2] * 256;
    params108[2] = 0x00;
    params108[3] = 0x20; // Max Amps current available (not really...)
    params108[4] = 50; // Threshold voltage frame.data.byte[4] + frame.data.byte[5] * 256;
    params108[5] = 0x00;
    params108[6] = 0x00;
    params108[7] = 0x00;
    hv_can.transmit(&params108_frame.into()).ok();
pub fn status109(hv_can: &HVCAN) {
    let id: u16 = 0x109;
    let size: u8 = 8;
    let mut status109_frame = DataFrame::new(ID::BaseID(BaseID::new(id)));
    status109_frame.set_data_length(size.into());
    let status109 = status109_frame.data_as_mut();
    /* STATUS
     * define EVSE_STATUS_CHARGE        1 //charger is active
     * #define EVSE_STATUS_ERR          2 //something went wrong
     * #define EVSE_STATUS_CONNLOCK 4 //connector is currently locked
     * #define EVSE_STATUS_INCOMPAT 8 //params btwn vehicle and charger not compatible
     * #define EVSE_STATUS_BATTERR      16 //something wrong with battery?!
     * #define EVSE_STATUS_STOPPED      32 //charger is stopped
    status109[0] = 0x02; // Protocol > 1 = 1.0
    status109[1] = 0x00; // Present voltage byte1 + 256*byte2
    status109[2] = 0x00;
    status109[3] = 0x00; // Current
    status109[4] = 0x00; // Reserved?
    status109[5] = 0x05; // Status
    status109[6] = 0xFF; // If < 0xFF then chgSecondsRemain = byte6 * 10;
    status109[7] = 0x10; // else chgSecondsRemain = byte7 * 60;
    hv_can.transmit(&status109_frame.into()).ok();
Anyone have the a description of the state machine? Or, more importantly, the analog connections?
I currently have 12 V on pin 2 and 0 V on pin 1, and CAN...and that's it. I feel like I'm missing something, and that's why the adapter isn't sending the 0x100, 0x101, and 0x102 frames. I only get the power-on bootup frame from Tesla.
It's unclear what to do with pins 4 and 10.
Any insight would be greatly appreciated.
-Matt
collin80
Been thanked: 15 times
Re: CHAdeMO EVSE side information?
Post by collin80 »
Did you look at the documentation here?
https://github.com/collin80/JLD505/blob ... Manual.pdf
It does at least have a picture of the pins and where they go. It kind of talks about the process too but maybe not in enough detail for what you want. I vaguely remember about the chademo stuff but it's been a long time.
mdrobnak
Post by mdrobnak »
collin80 wrote: Tue Nov 24, 2020 8:56 pm Did you look at the documentation here?
I imagine! That video was from like 2015 or 2017.
Yes I looked over it once, I'll give it another pass and see what I can make out of it.
-Matt
mdrobnak
Post by mdrobnak »
Ok, looks like:
Pin 7 is always grounded.
Pin 4 should be set high by the Tesla CHAdeMO adapter
Pin 10 should be grounded..just not sure when.
I'll see if pulling stuff to ground wakes up the adapter.
-Matt
mdrobnak
Post by mdrobnak »
Pin 7 is no connection on the adapter.
Pin 10 didn't do anything.
Good news: Behavior is consistent on my car with test set up.
Bad news: It doesn't work! :D
collin80
Post by collin80 »
I PM'd you.
mdrobnak
Post by mdrobnak »
If anyone reads Slovak here's a pretty good paper:
https://dspace.vsb.cz/handle/10084/142040?show=full - Includes a PCB and code!
mdrobnak
Post by mdrobnak »
*Ordering is important*
I had the 12V going before I even connected it to the charge port, and that was the wrong thing to do. I've at least gotten it to go into standby in SWCAN mode. Gonna review what I captured on the CHAdeMO side.
larsrengersen
Has thanked: 16 times
Been thanked: 36 times
Post by larsrengersen »
I've documented the pinout and sequence in this blogpost
https://www.evcreate.nl/chademo-fast-charging-in-diy/
Please send me an e-mail if you want any further details.
I have bought the IEC 61851-24 standard (Electric vehicle conductive charging system – Part 24: Digital communication between a d.c. EV charging station and an electric vehicle for control of d.c. charging) and that had useful information.
mdrobnak
Post by mdrobnak »
Awesome. That paper has similar detail (although muddied by google translate :D).
I have a 8 relay module board fitted and working:
Now I just need to throw some logic around what I've got.
I'll put together a DBC for the CAN data as well when I'm done.
Hopefully I'll be able to get closer to where it wants voltage... I hope to have something to show by tomorrow night. But I'm done for now. :)
-Matt
mdrobnak
Post by mdrobnak »
Current software is here:
https://github.com/mdrobnak/can-dc-fc-rs
Good enough to get my Model 3 to ask for current - aka start charging.
-Matt
Been thanked: 1139 times
Well, I have a chademo cable , my wife's nissan leaf and a volt charger ..........hmmmm:)
New Electric Ireland
Post by New Electric Ireland »
Jack Bauer wrote: Sun Dec 13, 2020 10:20 am Well, I have a chademo cable , my wife's nissan leaf and a volt charger ..........hmmmm:)
We could arrange to plug an Outlander into that setup if you need more vehicle data
In Ireland we undertake training & open source RND for the New Electric group, 5 companies converting boats, buses, cars and trucks to electric drive since 2008.
