Here are the two axles before (Tesla is the beefy long one)
Shipment back from Dutchman after just a week and a half and $175
And here are two of the beefy re-splined Tesla axles next to the Rx7 axle
Ya it really would be a good option. I hadn't looked into the Lexus transmission before but for some cars it is such a cool option.sfk wrote: ↑Fri Dec 18, 2020 5:22 am I didn't realize you were so far into your project already and committed to the Tesla LDU or I wouldn't have suggested going with the GS450h transmission.
If Tesla drive units were so available here in New Zealand as they are in USA or Europe I'd totally use them.
I don't know the specific technology they are using but they are pouch cells. Their literature says they will do 960 Amps in a 16 module configuration and they build them to order which makes it possible to max out the space.
Thanks for the input. I'm going to order up my cabling and get a bigger battery source for more testing after Christmas. I have to admit, it was exciting to hear it turn for the first time, despite the flash and smoke from my battery. I'm going to probably redo the encoder wiring again. I'm ditching that 23pin ampseal and buying the connector that comes with wiring pre-pinned as most have suggested. I had a terrible time getting the pins properly placed so they were contacting the Tesla connector.Boxster EV wrote: ↑Mon Dec 21, 2020 3:56 pm Couple of observations:
Those wires still look very thin
Is 38VDC enough? Damien always suggested about 60vdc for testing
I presume your drive unit has no lubricant inside? They do sound slightly clunky when run dry - although it's difficult to tell from the video.
Here's a video of my LDU spinning dry. Sounds rough but was fine once I'd put fluid in.
Nice build by the way.
