Several times I have been asked for Leaf motor wire colour.
This is my old post from when i tried to get data on my Leaf motor.
It shows resolver wire colour and their application.
To be clear this is valid for EM61 motor. The round one...
https://leafdriveblog.wordpress.com/201 ... /resolver/
COSINE NEGATIVE: YELLOW
COSINE POSITIVE: BLUE
SINE NEGATIVE: BLACK
SINE POSITIVE: RED
EXCITE:POSITIVE (EX): WHITE
EXCITE NEGATIVE (!EX): GREEN
Wires in pair should be twisted to cancel out EMI.
Nissan Leaf EM61 resolver wiring
invokeperformance
Re: Nissan Leaf EM61 resolver wiring
Hello I have a GEN 3 Prius inverter with the EM61. My question is does , Sin - and Cos - twist 'together' to a single ground potential as seen in the FOC tuning video? Or does sin- go to encoder A and Cos - go to encoder b as stated in on WIKI for the GEN3 Ampseal conn pinout guide. I tried both ways and I am unable to get a resolver angle reading on the plot. Thank you in advance.
MY current resolver wiring is as follow (According to Ampseal pinout for GEN 3 Prius inverter)
PIN 17 (ground)- Connects to EM61 SIN- (BLK) and COS-(yellow)
PIN 18 (resolver SIN) - connects to EM61 Sine + (RED)
PIN 19(resolver COS) - connects to EM61 COS + (BLUE)
PIN20(resolver EXC) - connects to EM61 Excite + (white)
PIN21 (ground) - connects to EM61 Excite - (green)
I also tired
PIN15 (encoder chan A) - Connects to EM61 SIN- (BLK)
PIN16 (encoder chan B)- Connects to EM61 COS- (Yellow)
Neither produced a angle plot am i missing something?
I also tired
- Been thanked: 1918 times
Was sent another picture today.
Please check with a simple multimeter in AC mode: exciter voltage about 5V AC, return voltages between 0 and 1V depending on rotor position.
invokeperformance
- janosch
- Has thanked: 98 times
- Been thanked: 106 times
Does someone have a part number for the connector that goes in the socket?
It looks like this on the EM57.
It looks similar to some Yazaki plugs that they also use for A/C and various other peripherals
https://www.auto-click.co.uk/6-way/yaza ... 83-8850-30
kiwifiat
- Been thanked: 12 times
Thanks johu, I have looked high and low to find that plug and I believe this is the correct part:
https://www.auto-click.co.uk/7283-8855- ... 83-8855-30
I had to bodge something up using molex connectors so these will be a huge improvement.
I have ordered a few and will report back once they arrive.
kiwifiat
Plugs arrived from the UK today and I can confirm this part is correct for the EM57 motor and certainly looks identical to the EM61 part.
