SimpBMS Reading from Chevy Volt Gen 1
bobbyj_408
Post by bobbyj_408 »
Hi All,
I believe I got the SimpBMS software running on a Teensy 3.2, so I plugged it into my gen 1 Chevy Volt battery to read the cell voltages and I got the following (shown below). Now, the pack voltage from SimpBMS is 279.5 V, but I measured the voltage with a multimeter myself to be at around 339 V. There does seem to be an error readout from SimpBMS that says "!!! Series Cells Fault !!!", but how can I diagnose this? What do I need to do to fix this?
Thanks!
BMS Status : 1 Ready     80
Out:0000 Cont:0000 In:0000
Modules: 11 Cells: 80 Strings: 1  Voltage: 279.559V   Avg Cell Voltage: 3.499V  Low Cell Voltage: 3.056V   High Cell Voltage: 3.543V Delta Voltage: 486mV   Avg Temp: 13.066C
Module #1   21.24V   Cell-1: 3.54V   Cell-2: 3.54V   Cell-3: 3.54V   Cell-4: 3.54V   Cell-5: 3.54V   Cell-6: 3.54V
 Temp 1: 9.09
Module #2   28.33V   Cell-7: 3.54V   Cell-8: 3.54V   Cell-9: 3.54V   Cell-10: 3.54V  Cell-11: 3.54V  Cell-12: 3.54V  Cell-13: 3.54V  Cell-14: 3.54V
 Temp 1: 11.72
Module #3   28.31V  Cell-15: 3.54V  Cell-16: 3.54V  Cell-17: 3.54V  Cell-18: 3.54V  Cell-19: 3.54V  Cell-20: 3.54V  Cell-21: 3.54V  Cell-22: 3.54V
 Temp 1: 10.52
Module #4   28.33V  Cell-23: 3.54V  Cell-24: 3.54V  Cell-25: 3.54V  Cell-26: 3.54V  Cell-27: 3.54V  Cell-28: 3.54V  Cell-29: 3.54V  Cell-30: 3.54V
 Temp 1: 17.19
Module #6   24.72V  Cell-31: 3.06V  Cell-32: 3.09V  Cell-33: 3.09V  Cell-34: 3.08V  Cell-35: 3.10V  Cell-36: 3.12V  Cell-37: 3.09V  Cell-38: 3.11V
 Temp 1: 11.49
Module #9   28.29V  Cell-39: 3.53V  Cell-40: 3.53V  Cell-41: 3.54V  Cell-42: 3.54V  Cell-43: 3.54V  Cell-44: 3.54V  Cell-45: 3.54V  Cell-46: 3.54V
 Temp 1: 11.07
Module #10  28.30V  Cell-47: 3.54V  Cell-48: 3.54V  Cell-49: 3.54V  Cell-50: 3.54V  Cell-51: 3.54V  Cell-52: 3.54V  Cell-53: 3.54V  Cell-54: 3.54V
 Temp 1: 10.16
Module #11  28.32V  Cell-55: 3.54V  Cell-56: 3.54V  Cell-57: 3.54V  Cell-58: 3.54V  Cell-59: 3.54V  Cell-60: 3.54V  Cell-61: 3.54V  Cell-62: 3.54V
 Temp 1: 16.97
Module #13  21.23V  Cell-63: 3.54V  Cell-64: 3.54V  Cell-65: 3.54V  Cell-66: 3.54V  Cell-67: 3.54V  Cell-68: 3.54V
 Temp 1: 11.46
Module #14  21.23V  Cell-69: 3.54V  Cell-70: 3.54V  Cell-71: 3.54V  Cell-72: 3.54V  Cell-73: 3.54V  Cell-74: 3.54V
 Temp 1: 17.22
Module #15  21.24V  Cell-75: 3.54V  Cell-76: 3.54V  Cell-77: 3.54V  Cell-78: 3.54V  Cell-79: 3.54V  Cell-80: 3.54V
 Temp 1: 16.84
CANbus   0.00mA  42% SOC 42000.00mAh
Has thanked: 264 times
Been thanked: 717 times
Re: SimpBMS Reading from Chevy Volt Gen 1
As you can see from the read out it shows only 80 cells instead of 96, so issues with the cabus slaves. To get series cells fault to be removed you need to input the right series cell settings.
bobbyj_408
Wow, thanks for the quick response. So it's possible that this is a configuration problem? That would be great. How do I set it to check 96?
The displayed read out shows all the found Slaves, it would seem to me one of the slaves is not reading properly.
How have you wired it up? Did you retain the OEM loom?
bobbyj_408
Dang... I was worried about that. I noticed that one of the slaves has a dirt ring on it as if some water was on there at some point... I'm worried that I may have gotten damaged while it was sitting at the junk yard. Is there a way where I can individually check each BMS? Something like compare the battery section voltage with the voltage reported from the individual BMS slave?
Yup, OEM loom connected as specified in the SimpBMS manual.
I would say unplug each slave on the LV side one by one to identify the reported modules.
You need to find the one reporting module 6 as 5 7 8 are missing.
bobbyj_408
tom91 wrote: Mon Mar 29, 2021 8:19 am I would say unplug each slave on the LV side one by one to identify the reported modules.
Thanks Tom.
Did this and had some strange results. Still not quite sure which one would be defective...
Per the attached image, when I disconnected pack 1, I got the following
BMS Status : 1 Ready     0
Modules: 0 Cells: 0 Strings: 1  Voltage: 0.000V   Avg Cell Voltage: nanV  Low Cell Voltage: 5.000V   High Cell Voltage: 0.000V Delta Voltage: -5000mV   Avg Temp: nanC
CANbus   0.00mA  0% SOC -240000.00mAh
pack 2
BMS Status : 1 Ready     30
Modules: 4 Cells: 30 Strings: 1  Voltage: 106.226V   Avg Cell Voltage: 3.541V  Low Cell Voltage: 3.536V   High Cell Voltage: 3.544V Delta Voltage: 7mV   Avg Temp: 14.114C
Module #1   21.25V   Cell-1: 3.54V   Cell-2: 3.54V   Cell-3: 3.54V   Cell-4: 3.54V   Cell-5: 3.54V   Cell-6: 3.54V
 Temp 1: 15.51
Module #2   28.34V   Cell-7: 3.54V   Cell-8: 3.54V   Cell-9: 3.54V   Cell-10: 3.54V  Cell-11: 3.54V  Cell-12: 3.54V  Cell-13: 3.54V  Cell-14: 3.54V
 Temp 1: 12.07
Module #3   28.33V  Cell-15: 3.54V  Cell-16: 3.54V  Cell-17: 3.54V  Cell-18: 3.54V  Cell-19: 3.54V  Cell-20: 3.54V  Cell-21: 3.54V  Cell-22: 3.54V
 Temp 1: 11.68
Module #4   28.31V  Cell-23: 3.54V  Cell-24: 3.54V  Cell-25: 3.54V  Cell-26: 3.54V  Cell-27: 3.54V  Cell-28: 3.54V  Cell-29: 3.54V  Cell-30: 3.54V
 Temp 1: 17.19
CANbus   0.00mA  45% SOC 45000.00mAh
pack 3
Modules: 0 Cells: 0 Strings: 1  Voltage: 185.462V   Avg Cell Voltage: infV  Low Cell Voltage: 0.004V   High Cell Voltage: 3.545V Delta Voltage: 3541mV   Avg Temp: 14.216C
Module #1   15.48V   Cell-1: 3.06V   Cell-2: 3.09V   Cell-3: 3.10V   Cell-4: 0.00V   Cell-5: 3.11V   Cell-6: 3.12V
 Temp 1: 15.44
 Temp 1: 12.14
 Temp 1: 11.72
 Temp 1: 17.19
Module #9   28.31V  Cell-31: 3.54V  Cell-32: 3.54V  Cell-33: 3.54V  Cell-34: 3.54V  Cell-35: 3.54V  Cell-36: 3.54V  Cell-37: 3.54V  Cell-38: 3.54V
 Temp 1: 13.73
Module #10  28.33V  Cell-39: 3.54V  Cell-40: 3.54V  Cell-41: 3.54V  Cell-42: 3.54V  Cell-43: 3.54V  Cell-44: 3.54V  Cell-45: 3.54V  Cell-46: 3.54V
 Temp 1: 12.33
Module #11  28.34V  Cell-47: 3.54V  Cell-48: 3.54V  Cell-49: 3.54V  Cell-50: 3.54V  Cell-51: 3.54V  Cell-52: 3.54V  Cell-53: 3.54V  Cell-54: 3.54V
 Temp 1: 16.97
CANbus   0.00mA  0% SOC 0.00mAh
pack 4
BMS Status : 1 Ready     38
Modules: 5 Cells: 38 Strings: 1  Voltage: 131.006V   Avg Cell Voltage: 3.452V  Low Cell Voltage: 3.060V   High Cell Voltage: 3.544V Delta Voltage: 484mV   Avg Temp: 14.050C
 Temp 1: 15.70
 Temp 1: 12.40
 Temp 1: 11.94
Module #4   28.34V  Cell-23: 3.54V  Cell-24: 3.54V  Cell-25: 3.54V  Cell-26: 3.54V  Cell-27: 3.54V  Cell-28: 3.54V  Cell-29: 3.54V  Cell-30: 3.54V
 Temp 1: 17.19
Module #6   24.76V  Cell-31: 3.06V  Cell-32: 3.09V  Cell-33: 3.10V  Cell-34: 3.08V  Cell-35: 3.11V  Cell-36: 3.12V  Cell-37: 3.09V  Cell-38: 3.11V
 Temp 1: 13.01
CANbus   0.00mA  38% SOC 38000.00mAh
Pack 3 as it only shows 8 cells but the module is monitoring more.
bobbyj_408
tom91 wrote: Tue Mar 30, 2021 8:12 am Pack 3 as it only shows 8 cells but the module is monitoring more.
Nice! Now the question is how to fix it? I suppose I could try finding a bms slave somewhere? I found one on ebay, but its part number is 22911432 and mine is 22880273. I highly doubt it's a good idea to mix and match like that...
I suspect opening up that BMS to see if anything is obviously broken is also a lost cause.
Mind doing the following, unplug the HV sense wires one at a time till you find one that causes no change.
bobbyj_408
tom91 wrote: Tue Mar 30, 2021 5:02 pm Mind doing the following, unplug the HV sense wires one at a time till you find one that causes no change.
Thanks Tom. I did this, and although there wasn't a connection that had no change, pack 2 did drop out module 6, which is the one we were looking for. I pulled out that bms, opened it up, and, well, I think the attachment speaks for itself. Note that this is the one that I mentioned that had the water stain on it.
Anyone out there have a replacement?
jon volk
Post by jon volk »
I had to replace 2 slave modules with similar corrosion. One of these days I plan on potting a set.
Has thanked: 455 times
Been thanked: 1771 times
Seen that a lot in BMS context. I left one test system in the shed and there was a bit of water ingress. Looked similar. Water + high voltage + PCB.
bobbyj_408
jon volk wrote: Mon Apr 05, 2021 4:49 pm I had to replace 2 slave modules with similar corrosion. One of these days I plan on potting a set.
Oh man.. Where were you able to locate one of these? I assume they would be difficult to track down.
bobbyj_408
johu wrote: Mon Apr 05, 2021 5:19 pm Seen that a lot in BMS context. I left one test system in the shed and there was a bit of water ingress. Looked similar. Water + high voltage + PCB.
Yeah... Looks like that's what happened here. Bummer.
jon volk
Post by jon volk »
bobbyj_408 wrote: Mon Apr 05, 2021 6:19 pm
They pop up on eBay all the time. Got a full set for $30.
bobbyj_408
jon volk wrote: Mon Apr 05, 2021 11:01 pm
Oh nice! Ok, I'll keep an eye out for that. I found a set that has 3 of the 4 boards available, but they have a different part number of 22911432, and mine is 22880273. I assume it wouldn't be a great idea to mix and match, right?
bobbyj_408
Actually, the seller did have all four of the 2291 part numbers. Should I just go for it?
bobbyj_408
For those keeping tabs, I managed to find the BMS modules listed on Ebay. I got them in, installed them, and things look good! Reads all 96 cells, and output the same voltage that I read with a multimeter. The only thing is that the print out skips module 8, which I am guessing is why it says "series faul"? Any advice?
BMS Status : 1 Ready     96
Modules: 13 Cells: 96 Strings: 1  Voltage: 336.352V   Avg Cell Voltage: 3.507V  Low Cell Voltage: 3.076V   High Cell Voltage: 3.546V Delta Voltage: 470mV   Avg Temp: 13.890C
Module #1   21.23V   Cell-1: 3.54V   Cell-2: 3.54V   Cell-3: 3.54V   Cell-4: 3.54V   Cell-5: 3.54V   Cell-6: 3.54V
 Temp 1: 9.32
Module #2   28.30V   Cell-7: 3.54V   Cell-8: 3.54V   Cell-9: 3.54V   Cell-10: 3.54V  Cell-11: 3.54V  Cell-12: 3.54V  Cell-13: 3.54V  Cell-14: 3.53V
 Temp 1: 12.46
 Temp 1: 12.56
Module #4   28.29V  Cell-23: 3.53V  Cell-24: 3.54V  Cell-25: 3.54V  Cell-26: 3.54V  Cell-27: 3.54V  Cell-28: 3.53V  Cell-29: 3.54V  Cell-30: 3.54V
 Temp 1: 17.19
Module #5   28.32V  Cell-31: 3.54V  Cell-32: 3.54V  Cell-33: 3.54V  Cell-34: 3.54V  Cell-35: 3.54V  Cell-36: 3.54V  Cell-37: 3.54V  Cell-38: 3.54V
 Temp 1: 10.49
Module #6   24.83V  Cell-39: 3.08V  Cell-40: 3.10V  Cell-41: 3.11V  Cell-42: 3.09V  Cell-43: 3.12V  Cell-44: 3.13V  Cell-45: 3.10V  Cell-46: 3.12V
 Temp 1: 13.79
Module #7   28.29V  Cell-47: 3.54V  Cell-48: 3.54V  Cell-49: 3.53V  Cell-50: 3.54V  Cell-51: 3.54V  Cell-52: 3.53V  Cell-53: 3.54V  Cell-54: 3.54V
 Temp 1: 17.10
Module #9   28.32V  Cell-55: 3.54V  Cell-56: 3.54V  Cell-57: 3.54V  Cell-58: 3.54V  Cell-59: 3.54V  Cell-60: 3.54V  Cell-61: 3.54V  Cell-62: 3.54V
 Temp 1: 16.74
Module #10  28.34V  Cell-63: 3.54V  Cell-64: 3.54V  Cell-65: 3.54V  Cell-66: 3.54V  Cell-67: 3.54V  Cell-68: 3.54V  Cell-69: 3.54V  Cell-70: 3.54V
 Temp 1: 12.20
Module #11  28.33V  Cell-71: 3.54V  Cell-72: 3.54V  Cell-73: 3.54V  Cell-74: 3.54V  Cell-75: 3.54V  Cell-76: 3.54V  Cell-77: 3.54V  Cell-78: 3.55V
 Temp 1: 16.97
Module #13  21.23V  Cell-79: 3.54V  Cell-80: 3.54V  Cell-81: 3.54V  Cell-82: 3.54V  Cell-83: 3.54V  Cell-84: 3.54V
 Temp 1: 13.30
Module #14  21.27V  Cell-85: 3.55V  Cell-86: 3.54V  Cell-87: 3.55V  Cell-88: 3.55V  Cell-89: 3.54V  Cell-90: 3.54V
 Temp 1: 11.65
Module #15  21.26V  Cell-91: 3.54V  Cell-92: 3.54V  Cell-93: 3.54V  Cell-94: 3.54V  Cell-95: 3.54V  Cell-96: 3.55V
 Temp 1: 16.80
Check your settings in the battery settings, is it set to 96 cells in series and 1 parallel string?
bobbyj_408
tom91 wrote: Sun Apr 18, 2021 12:10 pm Check your settings in the battery settings, is it set to 96 cells in series and 1 parallel string?
Ahh, looks like it wasn't! Below is what I have. I'll update this and let you know how it goes.
settings.Pstrings = 1; // strings in parallel used to divide voltage of pack
settings.Scells = 12;//Cells in series
dimonlipko
Has thanked: 7 times
Been thanked: 11 times
Post by dimonlipko »
Someone check, is temp sensor measure true? I have big diference by temp in one battery. I think, Simp have problem in code for mach temp.
