muehlpower
Has thanked: 14 times
Been thanked: 141 times
Post by muehlpower »
This is a very cheap CAN analizer. But I don't know if the format is compatible with savvy.
https://www.seeedstudio.com/USB-CAN-Ana ... -2888.html
The CAN BUS Analyzer Tool APGDT002 from Micrichip is more expensive but probably compatible. About 100€/$
Has thanked: 12 times
Been thanked: 350 times
I'm thinking more along the lines of something non pc based. just connect two wires and press a button. logs to an sd card.
paaa
Been thanked: 13 times
Post by paaa »
I have one of these for exactly that , and its just a reprogrammed olimax board
https://www.ebay.co.uk/itm/CAN-Bus-Data ... SwuOZeAQA6
Its great for quick on the fly logging, quick sniffing. I normally just import it I to excel sheet I have so it can convert hex and work out values that are made up of multiple bytes. Admittedly I do prefer the kvaser leaf light and savvy now though.
Scott166
Post by Scott166 »
I wasn't sure how to put a video on so I have put a link to a vid of me trying to find the can cables.
https://photos.app.goo.gl/KksgtRfJR3v1NPRV7
Hope it works
Restoring and converting a Classic Mini, I have mad ideas, semi sensible ideas and NO idea if I’ll ever get it done :lol:
Look me up on YouTube https://youtube.com/channel/UCxmP1hLys6Z5tHZpK5mn6eg to see my progress
muehlpower
since it is an RHD the BDC will be on the left. The CAN BUS is also on the RND switch and instrument cluster. Twisted red and red / blue wire!
Scott166
Post by Scott166 »
Thanks 👍
Any progress folks?
paaa
Post by paaa »
Im sending a usb can device to Scott with an inductive pickup so he can do some logging with savvy can on his car when charging.
Excellent. Much appreciated.
EV_Builder
Post by EV_Builder »
paaa wrote: Wed Mar 24, 2021 6:15 pm Im sending a usb can device to Scott with an inductive pickup so he can do some logging with savvy can on his car when charging.
Any news here?
I'm able to buy the device but offcourse i only want todo that if it makes sense :D
paaa
Post by paaa »
Im hoping to test my setup on a few cars on work tomorrow, and then ship the unit to Scott on Thursday morning.
EV_Builder
paaa wrote: Tue Apr 13, 2021 6:47 pm Im hoping to test my setup on a few cars on work tomorrow, and then ship the unit to Scott on Thursday morning.
Owkidoki! Go Go Go Go! :D :D :D
Hans Gustafsson
Post by Hans Gustafsson »
Here is a general Design_Guide of what needs to be done by a CCS port. I do not know if it is of any help to you, but here it is.
http://tesla.o.auroraobjects.eu/Design_ ... V3_1_1.pdf
Scott166
Post by Scott166 »
How's the Can gizmo going? Any luck yet?
paaa
Post by paaa »
I shipped it last week , it should be arriving soon.The joys of Brexit
Scott166
Post by Scott166 »
Excellent news, thanks
I hope it's not in the Suez 😅
Scott166
Post by Scott166 »
Scott166
Post by Scott166 »
i think ive found it in the centre console
Scott166
Post by Scott166 »
Is this going to be enough access?
Bryson
Post by Bryson »
The trick I’ve used in tight spots like that is to push a pin or needle into the wiring, then attach a clip to the bare needle sticking out. This should get you a signal without needing more than 10-20mm of wire access. Good luck and thank you!
vwbrady
Has thanked: 5 times
Been thanked: 18 times
Post by vwbrady »
teach me how to run savvy can, i'll pull apart my i3 and go take some logs. I'm serious.
mdrobnak
Post by mdrobnak »
vwbrady wrote: Fri Apr 23, 2021 9:57 pm teach me how to run savvy can, i'll pull apart my i3 and go take some logs. I'm serious.
Windows, Mac, or Linux? What interface are you using?
-Matt
Has thanked: 177 times
Been thanked: 369 times
If you have a arduino due:
viewtopic.php?t=1425
that gets your can interface out of the way!
vwbrady
Post by vwbrady »
mdrobnak wrote: Fri Apr 23, 2021 10:54 pm
-Matt
Windows
jon volk
Post by jon volk »
vwbrady wrote: Sat Apr 24, 2021 2:11 pm
-Matt
Windows
Just search YouTube for Savvycan. Collin has two or three tutorials
