General wiring question to screen or not to screen.
EV_Builder
Post by EV_Builder »
Which wire between motor and inverter?
I assume thick and screened..
Which wire between battery blocks?
I assume solid strip or core well isolated ..
Which wire between battery pack and inverter?
Which wire between CCS2 DC and pack?
Can some people shed some light on this? :roll:
Has thanked: 383 times
Been thanked: 1583 times
Re: General wiring question to screen or not to screen.
EV_Builder wrote: Mon Jun 14, 2021 2:41 pm Which wire between motor and inverter?
Yes, this is where I'd consider screening most important
EV_Builder wrote: Mon Jun 14, 2021 2:41 pm Which wire between battery pack and inverter?
All OEMs use screened cable, I don't, and most DIY builders rather use welding cable. Passed EMC test with Polo without screened DC cable.
EV_Builder wrote: Mon Jun 14, 2021 2:41 pm Which wire between CCS2 DC and pack?
Nissan uses unscreened cable, only charger EMI to be expected here which is probably already below the limits.
vwbrady
Has thanked: 5 times
Been thanked: 18 times
Post by vwbrady »
I was wondering this myself. In my professional life, we screen (shield) everything HV, and even now run shielded CAN cables throughout due to such high EMI. I won't be running shielded cable anywhere on my conversion as my inverter is integrated with the motor (gen 2 leaf.) I also don't have much DC cable to run, and my DCDC & Charger are PWM controlled (Gen 2 Volt) so i don't expect sensitivity with those control wires.
celeron55
Has thanked: 38 times
Been thanked: 136 times
Post by celeron55 »
I think one reason to shield the DC cables is damage detection. If something slices a shielded cable, a ground fault detector easily and automatically detects the fault. Of course in a conversion with no ground fault detector it's not useful, unless you add checking HV insulation resistance to your yearly maintenance schedule or so.
vwbrady
Post by vwbrady »
the difference in safety measures between our conversions and the systems I design for public use is ridiculous - HVIL and Iso Detection being the main pieces.
as an example we are using 120mm² single pole cables x3 (pos & neg) in parallel to carry the current we need.
