I assume thick and screened..
Which wire between battery blocks?
I assume solid strip or core well isolated ..
Which wire between battery pack and inverter?
Which wire between CCS2 DC and pack?
Can some people shed some light on this?
Yes, this is where I'd consider screening most importantEV_Builder wrote: ↑Mon Jun 14, 2021 2:41 pm Which wire between motor and inverter?
All OEMs use screened cable, I don't, and most DIY builders rather use welding cable. Passed EMC test with Polo without screened DC cable.
Nissan uses unscreened cable, only charger EMI to be expected here which is probably already below the limits.
