BMW i3 11kW KLE onboard charger multi-phase
- FJ3422
- Has thanked: 6 times
- Been thanked: 3 times
Looking for a lighter alternative for the bulky Tesla 11kW on-board charger, I came across the i3 charger.
- Half the weight
- CCS Fast-charge contactors integrated
Scored one and took it apart yesterday. First remarkable thing I did not know; the KLE for the 3-phase chargeable i3 is just a 2-phase charger ! Charger for the third phase seems to be integrated in the EME.
Anyone already did some reverse-engineering om this thing ? I do have access to a 2019 i3 (with exactly this KLE inside) since a couple of days, so will make some CAN-logs one of these days.
Some pictures:
- Half the weight
Some pictures:
- Has thanked: 134 times
- Been thanked: 336 times
Re: BMW i3 11kW KLE onboard charger multi-phase
Can you take a photo of charger stickers and P/Ns in detail?
tnx
- FJ3422
This is the 6144 8482639 / produced in 2019.
https://www.realoem.com/bmw/enUS/showpa ... 1449845423
- Has thanked: 11 times
- Been thanked: 345 times
Some CCS logs from the 2019 i3 would be very helpful also:)
You will find some logs and a dbc on my github :
https://github.com/damienmaguire/BMW-i3-CCS
- FJ3422
Sure, no problem ! Handling an electric car that just 'works' is new to me, so still have to arrange some charge cards, look for a quiet CCS-station around here, find a place to tap the CAN-wiring and kindly ask her not to plug the thing into the wall after every short trip so there is something to chargeJack Bauer wrote: ↑Thu Jun 24, 2021 12:33 pm Some CCS logs from the 2019 i3 would be very helpful also:)
- steveknox
- Has thanked: 16 times
- Been thanked: 14 times
Just a prod -- I'm keen on using one of these as it looks like a really neat package for CCS as well as AC charging. Have you managed to get any can logs?
Mazda RX-8
GS450h Running Gear
Outlander Charger
Renault Kangoo 36kwh pack
GS450h Running Gear
Outlander Charger
Anyone done any investigation on this unit, also on non CCS AC only onboard charger.
- Bratitude
- Has thanked: 175 times
- Been thanked: 359 times
I friend has a i3 now, the charger throttles to 3.3kw because of crappy cooling. BMW has recals for older revisions of Kle units. Not sure the dates, but Might be worth checking when buying second hand
- FJ3422
Not yet. I hoped to find a 3-phase 11kW charger in this thing. Unfortunately it is just a 2-phase (6,6kW) charger, the third phase (3,3kW) is integrated in de EME, so the charger is less interesting for my build. Will figure CAN-control out somewhen, but it currently has no priority for me.
Anyone had any luck getting one of these to fire up?
