Lexus Inverter Hacking
- Has thanked: 12 times
- Been thanked: 356 times
Next up on the bench for hacking is the Lexus IS300h inverter. I believe this one is also fitted to the new model GS450h and LS hybrids also. Have another few Lexus inverters on the way including a few 2009 GS450h units that are available quite cheaply. Should work out nice for people who need more power than the Prius and /or rear wheel drive solutions.
Today managed to get the IGBT driver woken up and running in the IS inverter.
Re: Lexus Inverter Hacking
First look inside the GS450H inverter. Uses the same connector for the igbt driver board as the Gen 3 Prius.
Released a development board design for the Lexus IS300H inverter :
https://github.com/damienmaguire/Lexus-IS300H-Inverter
Uses the Hübner brain board and a jumper to select between running the MG1 or MG2 inverter.
I'll be honest and say I didn't even know about the longitudinal layout of the Lexus GS hybrid drivetrain. It seems a better approach to the RWD conversion I am trying to do, rather than grafting a Leaf motor onto the driveshaft or trying to fit the motor and reduction gear into the rear subframe.
So I'm watching your progress with the GS450H integrated drive gearbox with great interest on YouTube.
Do you think that gearbox alone will be good enough to drive a medium weight car without an engine inputting power? Possibly if you can get both electric motors to contribute by locking up the front input shaft...
Oh it's very much possible :
Naturally this guy decided not to share (probably planning to be the next Elon) so I'll just have to go do it.
Wow. That's pretty impressive. I'm not so sure about using Leaf drive components now....
I'm using a GS450h gearbox in my E65 conversion. At 2640kg it should prove the system:)
Most definitely. I'll be approx 1 ton lighter.
If I was to assemble a shopping list of components, what should I be looking for?
You would need the gearbox with the aux oil pump (beware many ebay sellers remove this as it is a common failure part on the gs450h), inverter, hv cables and if possible the lv harness as of course all the connector plugs are custom.
Started in on the GS450h inverter today. Our friends in Toyota are being extra sneaky with this one ...
Development board for the is300h inverter arrived and it fits:)
- Has thanked: 385 times
- Been thanked: 1594 times
Beauty
Nice logo, too
Nice logo, too
That is great , but did you see what voltage does he use ? it is about 650V nominal ..Jack Bauer wrote: ↑Wed Mar 13, 2019 8:06 am Oh it's very much possible :
650v is not needed. Don't worry I'll prove it:)
What voltage are you thinking and what top speed does that translate to?
- steveknox
- Has thanked: 16 times
- Been thanked: 14 times
I've got a gs450h gearbox in my garage waiting to go into an rx-8. Been building my own inverter but this is a far more realistic proposition. I better start hitting up my local breakers for inverters!
Mazda RX-8
GS450h Running Gear
Outlander Charger
Renault Kangoo 36kwh pack
GS450h Running Gear
Outlander Charger
Well the boost converter in the GS450h inverter is playing hard to get. Identified quite a few signals but still not firing the igbts.
Gets rather frustrating when you realise this has been done before but not shared. That said the Toyota stuff continues amaze. It's just been designed to be totally fail safe.
- Has thanked: 217 times
- Been thanked: 608 times
You have not managed to blow one up yet? That is quite impressive.
Does each component/section look like it could be a standalone part? I would believe they share quite a lot amongst their various models.
Can't kill them. They seem to use asics for the igbt drive that simply will not allow anything destructive to happen. They even have their own temp sense so if you let the heatsink hit 90c they ignore the pwm. The prius gen3 inverter is very integrated although the dc dc can run standalone. These older Lexus inverters are modular.
And the booster is boosting!
- Has thanked: 135 times
- Been thanked: 344 times
Nice work JB! Now i can get one for my 406c!
What do you think IGBTs have in term of power?
Can you try to run Aux circuit with 380Vdc too?
tnx
Arber
Boosting from 20v to 250v. The gs450h inverter does not have a dc dc built in. Its just a dual inverter and boost converter. Rated at 37kw from what I can find online.
Nice work!
So much effort to turn on a light bulb. But hats off to you, another one in the bag.
