Electric Golf IV
eee291
Electric Golf IV
Post by eee291 »
I've decided to finally start building my own electric car.
I was going to convert my Passat in 2019 but just as I was about to start buying parts COVID happened and I was laid off amongst other things. :cry:
The Passat is my only mode of transportation for now, so I got this Golf instead for just 200€ with a broken Conrod.
I've got brakes figured out, don't know if I should go with electric power steering or hydraulic. Hydraulic seems way easier.
Inverter is a Gen2 Prius with the brain board from Johannes.
Motor is a 33kg asynchronous forklift motor rated at 5kw cont. It has plenty of cooling holes so I'm hoping it'll handle 20kw peaks, maybe more with higher voltage.
I think I got the battery figured out.
This will be a tight budget conversion since I don't have a stable income.
Alibro
Has thanked: 376 times
Been thanked: 224 times
Re: Electric Golf IV
Post by Alibro »
If a power steering system is designed to run with hydraulic assistance will it harm the rack to use electric power steering thereby effectively forcing the steering from the column?
I ask because I don't know but suspect it might. I decided to use a motor to drive the oem power steering pump but most go for an electric /hydraulic pump from a GM or Volvo car.
Has thanked: 83 times
Been thanked: 430 times
I think people just loop the oil lines in that case. The hydraulic pumps are cheap but noisy. Check my Beetle build thread, same platform as the mk 4 golf, also did on a tight budget.
thatwildman
Post by thatwildman »
Alibro wrote: Tue Dec 27, 2022 12:14 am If a power steering system is designed to run with hydraulic assistance will it harm the rack to use electric power steering thereby effectively forcing the steering from the column?
Id say yes, i have tested it my self and the rack was gone withen a month of driving.
its better to use electric hydrolic steering pump. :mrgreen:
