I thought it would be helpful to start a place holder for useful information. I'll start with a link to a 30 page thread on the Model 3 Owners Club which has lots useful information including a DBC file for the car
Diagnostic Port and Data Access
I’m on mobile and can’t post links but Wikipedia says that they are using PM assisted switched reluctance motors. Adding PMs to the rotor increases the torque capability and the power factor since there’s no current excitation in the rotors of the regular SRMs. My guess is that thanks to the PM assistance the motor control (and overcoming the issues with torque ripple) becomes easier.johu wrote: ↑Sun Mar 17, 2019 11:05 pm Where does the switched reluctance info come from?
In a recent German magazine "elektro auto mobil" they stated that the rumors about a switched reluctance motor in Model 3 were false and that it uses a regular IPM motor. Like Leaf, Golf and all the others. That also has a reluctance component in its torque equation.
The control of the SRM is extremely important. The coil must be turned off right before the teeth are aligned to avoid the holding perpendicular torque. Not only is the position monitored for smooth operation, but the current within the winding must also be controlled. The current within the winding must be completely drained in order for the torque to go to zero. The time constant for the coil is measured and fed back into the controls to ensure the current is dissipated before the tooth is aligned.
Torque in a switched reluctance motor is produced by pulses of phase current synchronized with the rotor position[23]. A pulse of the phase current is sometimes also called a stroke. Torque is controlled by controlling the current shape and timing of these phase current pulses. At low speed the torque can be controlled by chopping, at higher speeds torque is controlled by changing the timing for when to turn on and turn off phase current. Ideally the torque would be controlled with a simple linear relationship between torque and current. This may not always be the case for the switched reluctance motor, where the torque may also be influenced by rotor speed, and a non-linear relationship exist between torque and current.
Jack Bauer wrote: ↑Thu Mar 21, 2019 7:17 pm So started laying out a simple pcb today for what I call my Model 3 simulator. Just a little 4 inch square board with the C2000 footprint with power and grounds and some leds and switches to simulate I/O. I'll get this pro built by my board builder to as closely simulate the drive unit pcb. Lead free solder, conformal coating (aka Musk Goo) the works. Then we'll see how I get on removing the C2000 and fitting the V1 logic board. Might take a few goes to find the best way but better to mess up a few 5 euro boards than a M3 drive unit:)
