I tried to configure a new motor with firmware 5.25.R.foc and received messages that it is not available for her. sending the "start 2" command or pressing the "start manual mode" button gives the answer "not available".
how do I set up current and voltage sensors now, as well as search for the offset angle?
problems configuring new motors with the latest foc firmware
- Been thanked: 1918 times
Re: problems configuring new motors with the latest foc firmware
- Romale
- Has thanked: 346 times
- Been thanked: 101 times
Thanks a lot, I didn't notice it. from the name of the topic, it was not clear what problem was being solved in it.johu wrote: ↑Mon Nov 28, 2022 12:36 pm One topic below yours
https://openinverter.org/forum/viewtopic.php?t=2809
now there is an understanding of how to set up syncoffs. but how to set up the amplification of current sensors and voltage measurement?
evil neodymium
- Romale
Johu, I respect your time spent on answers. I am well aware of the description from the link and I would not dare to distract you for nothing without using the search. However, when I enter "start 2" I get the same system response as in my first post: not available for foc.
evil neodymium
Think, Romale, think
So I will repeat my carefully chosen words
Manual mode is gone, use normal run mode, however you trigger itI was kind of sick of the manual mode not working so now I have replaced it with something different: manualstart
