Shunt needed with OI board?
ardillolambo
Has thanked: 4 times
Post by ardillolambo »
Guys,
I'm panning using a custom digital dash board to display info such as speed, temperature and all that kind of things....can I get all that data from the OI inverter board or do I need a shunt resistor?
Has thanked: 134 times
Been thanked: 342 times
Re: Shunt needed with OI board?
ardillolambo wrote: Wed Dec 07, 2022 2:14 pm Guys,
Hm... OI can output CAN data stream. But i dont know if you can directly use the DC current data. Maybe not really accurate...
Speed and temp info is there and can be slaved to CAN.
Has thanked: 383 times
Been thanked: 1589 times
The DC current figure is as accurate as the current sensors are calibrated, That said it doesn't include miscellaneous currents like DC/DC, heater etc. Better source current from the BMS (or a shunt)
ardillolambo
johu wrote: Wed Dec 07, 2022 4:42 pm The DC current figure is as accurate as the current sensors are calibrated, That said it doesn't include miscellaneous currents like DC/DC, heater etc. Better source current from the BMS (or a shunt)
Johu
Any particular shunt that you will recommend for a dual motor set up?
