Guys,
I'm panning using a custom digital dash board to display info such as speed, temperature and all that kind of things....can I get all that data from the OI inverter board or do I need a shunt resistor?
Shunt needed with OI board?
ardillolambo
- Has thanked: 4 times
- Been thanked: 5 times
- Has thanked: 166 times
- Been thanked: 413 times
Re: Shunt needed with OI board?
Hm... OI can output CAN data stream. But i dont know if you can directly use the DC current data. Maybe not really accurate...ardillolambo wrote: ↑Wed Dec 07, 2022 2:14 pm Guys,
Speed and temp info is there and can be slaved to CAN.
- Been thanked: 1918 times
The DC current figure is as accurate as the current sensors are calibrated, That said it doesn't include miscellaneous currents like DC/DC, heater etc. Better source current from the BMS (or a shunt)
ardillolambo
Johu
Any particular shunt that you will recommend for a dual motor set up?
