This is my first car conversion project. I took my old german car wich was already quite rusty and its 1.8 Liter petrol engine was also in a need of a rebuild because of the oil leak and loss of coolant so I asked myself is it worth spending thousands euros and half a year in that engine rebuilt.
Well you see already what I decided, otherwise I wouldn't be writing that story here.
2016 I got from wrecked car auction unrepairable Mitsubishi i-MiEV then it took me a few years to restore the electric system and make it run again. When that was done I decided to install all this mitsubishi electric drive system to the Mercedes. Motor unit was placed to the rear axle where the differential was. Battery is installed in front where the engine use to be. Then it took many years to install all the i-MiEV wiring and control units to the mercedes. Nothing fitted, almost all wiring needed to be lenghtened. I think I chose the right car to convert because in 1996 Mercedes C180 had almost like analog electrical system there's no CAN or even OBD port. Now it has Mitsubishi OBD port. Some Mercedes actuators are driven by hoses
