Wanted Lexus rx400h inverter
Bit of a long shot this one but if anyone has one for reasonable money I want to do some comparisons with the ipm in these and the gen2 Prius… they appear to be a beefed up version of the Prius but I’d like to find out but how much…
- Has thanked: 430 times
- Been thanked: 124 times
Re: Wanted Lexus rx400h inverter
Did you get anywhere with this? I'm wondering about using the rx400h in my conversion and would be interested in the inverter performance.
I never managed to get my hands on one to find out, from what I can tell though they should be a beefed up Prius gen 2 design, look to have more igbts per inverter that the Prius, I would guess similar to gen3 prius inverter performance but using the same intelligent power module design as the gen2 prius, even the connector and pin out are the same
- Has thanked: 17 times
- Been thanked: 22 times
Im in the UK, Here are some pics of it, I was going to use it to drive a Remy HVH because of its high voltage capability, but ended up going a different route.
Awesome, drop me a message about what you want for it ect, while you’re at it the dimensions would be handy
