Tool to manage openinverter via CAN
- Been thanked: 1918 times
Re: Tool to manage openinverter via CAN
That looks sane.
I'd go for delete & recreate because then you can map the same item multiple times.
I have now settled for this:
index 0x3000 is map TX
- subindex 0 sets COB Id
- subindex 1 sets item ID (2 bytes) bit position and bit length (1 byte each)
- subindex 2 sets gain (3 bytes, gain * 1000) and offset (1 byte signed) and commits the addition
index 0x3001 is map RX
index 0x3100-0x317F lets you read all TX maps
- subindex 0 gets COB Id
- subindex 2i+1 gets ID, position, length as above where i is the item index on that COB id
- subindex 2i+2 gets gain and offset as above
index 0x3180-0x31FF lets you read all RX maps
writing to 0x31zz (subindex - 1)*i deletes the item, addressing as above
davefiddes
- Has thanked: 206 times
- Been thanked: 257 times
Seems workable. If you let me know when you've got some code I can work against I'll update the tool.
Cool
You can use this one: https://github.com/jsphuebner/stm32-sin ... safer_can2
I've recently found that the json stream contains random 0-bytes. It occurs both with the candownload.py script and the ESP32 so the culprit is probably the STM firmware.
I think I know why: PutChar() runs in the lowest priority main loop and the CAN RX IRQ can interrupt it before it fills up the buffer. That leaves some zeros in there.
davefiddes
It's been well behaved for me. I mostly have been testing in opmode off which might account for that.
Slow progress on my side as summer has arrived here at long last. Hope to make more progress next week.
I've been thinking this over and it is easy to reproduce but hard to fix. Put a bit of interrupt load on the system and the download fails or at least contains 0 bytes. That's because the main loop does not manage to put enough bytes into the buffer before the next segment request fires.
Waiting for all bytes in the ISR is no solution either as that would result in classic priority inversion.
Also I don't want to disable the RX IRQ while printing as that would distract normal CAN operation and I totally don't want comms to get in the way of more important things.
So for now it means json download is only possible with low load. Could also filter the 0 bytes in reception...
davefiddes
Managed to get my "inverter" (an STM32 Bluepill on a breadboard) into Run mode and can now replicate this reliably. Should definitely filter it client side even if you are able to fix the problem. I need to be a bit cleverer in processing the incoming data stream as binary and remove the NUL bytes. Should be straight forward.
I have now increased the buffer for printing to 64 bytes. Once the queue runs dry the transfer is terminated. I've tested with the inverter software in run mode and the spurious chars are gone.
UPDATE: code committed
davefiddes
I've pushed a fix to the tool which filters out any erroneous bytes anyway. I found it harder to replicate than I first thought so had to rely on unit tests which is not a bad outcome.
Ah good. Did you test with the code mentioned above or previous version?davefiddes wrote: ↑Thu Sep 14, 2023 10:42 am I've pushed a fix to the tool which filters out any erroneous bytes anyway. I found it harder to replicate than I first thought so had to rely on unit tests which is not a bad outcome.
davefiddes
It was the 5.27.R-sine release version. I don't have a reliable way to update the firmware on my board at the moment.
- celeron55
- Has thanked: 39 times
- Been thanked: 136 times
I'm trying to use this to communicate
- with my focci board (https://github.com/uhi22/foccci)
- running the ccs32clara firmware (https://github.com/uhi22/ccs32clara)
- using a Lawicel CANUSB adapter (https://www.canusb.com/products/canusb/)
- on Fedora Linux 38
This is not going exactly swimmingly.
I first tried this type of configuration when running oic:
One problem is that in this mode, the CANUSB adapter does not ACK any messages on the bus unless someone has the device open. As a result, the target board ends up flooding the bus with re-send attempts right until the point where oic opens the device, after which the CANUSB adapter starts to respond to ACKs, and right when oic closes the device, the adapter appears to stop responding to ACKs again. To be exact, I don't have a CAN analyzer that would prove me it's the ack bit, but the behavior exactly matches that which in my experience results from the missing ACK bit.
Anyway, given this gotcha, I still could attempt using oic. Here is the result:
Ok. Well, it's clearly not working. We have another method to try, though: We can use slcand to turn this into a socketcan interface. Let's try:
We'll leave that running on the foreground.
We can immediately see on the scope that CANUSB starts to respond to ACKs as the target board stops flooding the bus.
Now, the interface still needs to be brought up first.
And then we'll configure python-can to use socketcan:
Now it'll surely work, right? Right? There's nothing we can do but try to call oic again:
Oh no! What does this even mean?
Then the rest of it:
No luck at all.
Looking on the scope, the target board appears to be sending stuff with a bit length of about 2us which matches the 500kbaud we are setting.
Disconnecting the target board from the bus lets us notice the CANUSB adapter is also sending frames with a 2us bit length, which matches. We can also see the bus is being flooded by retransmitted frames from the PC side, as nobody is ACKing them now.
Now in this socketcan mode, I can also use to look at the data sent by the target board. There doesn't seem to be any obvious problem with the data.
So, it looks like the basic CAN communication is working (I haven't for example swapped H and L, and the bitrate is correct), yet oic fails to get any useful results.
One problem is, I don't know what this protocol is supposed to look like when it's working, so I can't determine any problems at the frame level. The board is very talkative, and I don't know whether this protocol is supposed to be hidden within the same frame ids, or whether new frame ids should pop up. I have attached the "candump -tz can0" output of running the previously listed three oic commands. The vast majority of the data is not related to oic, though.
Anyone got any ideas?
interface = slcan
channel = /dev/ttyUSB0
bitrate = 500000
$ oic scan
Scanning for devices. Please wait...
No nodes found
$ oic -n 22 serialno
Transfer aborted by client with code 0x05040000
SDO communication error: No SDO response received
$ oic -n 22 listparams
Traceback (most recent call last):
File "/home/celeron55/programs/openinverter_can_tool/openinverter-can-tool/venv/lib/python3.11/site-packages/canopen/sdo/client.py", line 65, in read_response
response = self.responses.get(
File "/usr/lib64/python3.11/queue.py", line 179, in get
raise Empty
_queue.Empty
During handling of the above exception, another exception occurred:
File "/home/celeron55/programs/openinverter_can_tool/openinverter-can-tool/venv/bin/oic", line 8, in <module>
sys.exit(cli())
... (long traceback cut out)
File "/home/celeron55/programs/openinverter_can_tool/openinverter-can-tool/venv/lib/python3.11/site-packages/canopen/sdo/client.py", line 68, in read_response
raise SdoCommunicationError("No SDO response received")
canopen.sdo.exceptions.SdoCommunicationError: No SDO response received
$ sudo slcand -F -o -c -f -s6 /dev/ttyUSB0 can0 # Speed 6 = 500kbpsps
$ sudo ip link set can0 up
interface = socketcan
channel = can0
bitrate = 500000
]$ oic scan
CAN error: Failed to transmit: No buffer space available [Error Code 105]
raise Empty
_queue.Empty
sys.exit(cli())
candump -tz can0So, it looks like the basic CAN communication is working (I haven't for example swapped H and L, and the bitrate is correct), yet oic fails to get any useful results.
- 2024-02-16_01_oic_clara.candump.txt
- (27.89 KiB) Downloaded 1322 times
Those frames are from uhis first test implementation
You need to run the recent OI style firmware to be able to use oic
EDIT: apart from that I also found slcand more reliable
- uhi22
- Has thanked: 245 times
- Been thanked: 684 times
Easy Story
You are using the old Clara, before Johannes integrated all the Openinverter features. It sends on hard-coded CAN IDs starting with 0x567. No CANopen support at all. So the tool is perfectly right in saying "no response".
Just pull and compile the latest Clara.
- celeron55
Wait what? I thought I pulled, compiled and flashed the latest clara!
This is supposed to be 0cb9745a3bea0e8171c03f190f38181dfb1a5f1c, and I built it on 9th February, just a week ago. The hex file I used has that date on it.
I'll go continue in the clara thread as this is off-topic here. viewtopic.php?p=67386#p67386
- celeron55
It all worked out, now to the point that I need to access the CAN mappings on the board, by using OIC. What's the status on that?
EDIT: I started working on it now
davefiddes
Glad you got things working. The setup of CAN sessions on Linux can be a bit of a pain though it's good when you get it running.
Happy to accept PRs. I built the tool in python so it would be approachable to more people than typical OI projects. I've been away from OI and car related projects for a bit.
In addition to adding commands to allow basic editing of individual of CAN mappings I had intended to add loading and saving of all board mappings for backup purposes. My original idea was to read and write CAN mappings in DBC files using one of the common python DBC libraries. When I dug into it this got quite complicated. Perhaps simple custom JSON files would be useful as an intermediate step. DBC files would be very useful to allow other tools like SavvyCAN to interpret the CAN stream in terms that OI users might understand.
- celeron55
It sure is fairly approachable to me at least. Just another Python tool!
CAN map listing and manipulation works now:
https://github.com/celeron55/openinvert ... ree/canmap
I'll submit a PR when I finish tweaking this.
$ oic -n 22 can list
CAN mappings:
(empty)
$ oic -n 22 can add tx 0x101 5 0 1 0 0
CAN mapping added succesfully
CAN mappings:
* 0x3100 tx param_id=5 pos=0 len=0 gain=0 offset=0
$ oic -n 22 can add tx 0x102 5 0 1 0 2
CAN mappings:
* 0x3101 tx param_id=5 pos=0 len=0 gain=0 offset=0
$ oic -n 22 can add rx 0x201 5 0 1 0 0
CAN mappings:
* 0x3181 rx param_id=5 pos=0 len=0 gain=0 offset=0
$ oic -n 22 can remove 0x3101
0x3101
CAN mapping removed succesfully
CAN mappings:
davefiddes
Good progress! Can you look up param_id in the json to be able to use the friendly name both when mapping and listing? Was trying to conceal those IDs is much as possible (viewtopic.php?p=52550#p52550)
BTW here is the intermediate json format I use on the ESP32
[{"isrx":false,"id":264,"paramid":2009,"position":8,"length":16,"gain":1,"offset":0,"index":12544,"subindex":2},
{"isrx":false,"id":264,"paramid":2008,"position":24,"length":8,"gain":1,"offset":0,"index":12544,"subindex":4},
{"isrx":false,"id":265,"paramid":1,"position":0,"length":8,"gain":0,"offset":10,"index":12545,"subindex":2},
{"isrx":false,"id":265,"paramid":2006,"position":8,"length":16,"gain":1,"offset":0,"index":12545,"subindex":4},
{"isrx":false,"id":265,"paramid":2010,"position":24,"length":8,"gain":1,"offset":0,"index":12545,"subindex":6},
{"isrx":false,"id":265,"paramid":2000,"position":40,"length":8,"gain":0.289000005,"offset":0,"index":12545,"subindex":8},
{"isrx":true,"id":256,"paramid":6,"position":0,"length":16,"gain":1,"offset":0,"index":12672,"subindex":2},
{"isrx":true,"id":258,"paramid":3,"position":8,"length":16,"gain":1,"offset":0,"index":12673,"subindex":2},
{"isrx":true,"id":258,"paramid":4,"position":24,"length":8,"gain":1,"offset":0,"index":12673,"subindex":4},
{"isrx":true,"id":258,"paramid":5,"position":48,"length":8,"gain":0.5,"offset":0,"index":12673,"subindex":6},
{"isrx":true,"id":258,"paramid":23,"position":40,"length":1,"gain":1,"offset":0,"index":12673,"subindex":8},
{"isrx":true,"id":258,"paramid":2016,"position":0,"length":1,"gain":0,"offset":0,"index":12673,"subindex":10}]Support R/D and forum on Patreon: https://patreon.com/openinverter - Subscribe on odysee: https://odysee.com/@openinverter:9
- uhi22
What is index and subindex?
Thats helper info in case you want to delete a mapping.
See here: viewtopic.php?p=60996#p60996
- celeron55
I don't quite get the protocol used to list the mappings. Somehow multiple mappings appear or disappear on the listing when I add or delete one. The index/subindex thing where sometimes they're used as a pair that can be translated to something, sometimes index is a command and sometimes subindex means something on its own is very confusing without a protocol spec.
Also, getting an abort response means various things at various points in the listing protocol. It doesn't seem to be a very good design from my standpoint.
EDIT:
EDIT:
Already did that. It was the easiest part in all of this. The difficult part is in the listing protocol of the mappings.johu wrote: ↑Sat Feb 17, 2024 1:16 pm Good progress! Can you look up param_id in the json to be able to use the friendly name both when mapping and listing? Was trying to conceal those IDs is much as possible (viewtopic.php?p=52550#p52550)
- celeron55
Maybe this is correct?
EDIT: Made it even longer with more mappings
Listing TX mappings
SDO 0x3100.0: can_id=0x101
SDO 0x3100.1: dataposlen=0x80007d3
SDO 0x3100.2: gainofs=0x3e8
-> Decoded mapping: tx 0 2 can_id=0x101 param='temp1'(id=2003) pos=0 len=8 gain=1.0 offset=0
SDO 0x3100.3: dataposlen=0x82007d5
SDO 0x3100.4: gainofs=0x3e8
-> Decoded mapping: tx 0 4 can_id=0x101 param='temp3'(id=2005) pos=32 len=8 gain=1.0 offset=0
SDO 0x3100.5: not found
SDO 0x3101.0: can_id=0x102
SDO 0x3101.1: dataposlen=0x81007d5
SDO 0x3101.2: gainofs=0x3e8
-> Decoded mapping: tx 1 2 can_id=0x102 param='temp3'(id=2005) pos=16 len=8 gain=1.0 offset=0
SDO 0x3101.3: not found
SDO 0x3102.0: not found
Listing RX mappings
SDO 0x3180.0: can_id=0x202
SDO 0x3180.1: dataposlen=0x8100005
SDO 0x3180.2: gainofs=0x3e8
-> Decoded mapping: rx 0 2 can_id=0x202 param='soc'(id=5) pos=16 len=8 gain=1.0 offset=0
SDO 0x3180.3: dataposlen=0x8100005
SDO 0x3180.4: gainofs=0x3e8
-> Decoded mapping: rx 0 4 can_id=0x202 param='soc'(id=5) pos=16 len=8 gain=1.0 offset=0
SDO 0x3180.5: not found
SDO 0x3181.0: can_id=0x203
SDO 0x3181.1: dataposlen=0x10100013
SDO 0x3181.2: gainofs=0x3e8
-> Decoded mapping: rx 1 2 can_id=0x203 param='maxcur'(id=19) pos=16 len=16 gain=1.0 offset=0
SDO 0x3181.3: dataposlen=0x10200011
SDO 0x3181.4: gainofs=0x3e8
-> Decoded mapping: rx 1 4 can_id=0x203 param='maxpower'(id=17) pos=32 len=16 gain=1.0 offset=0
SDO 0x3181.5: dataposlen=0x830000e
SDO 0x3181.6: gainofs=0x3e8
-> Decoded mapping: rx 1 6 can_id=0x203 param='lockpwm'(id=14) pos=48 len=8 gain=1.0 offset=0
SDO 0x3181.7: not found
SDO 0x3182.0: can_id=0x201
SDO 0x3182.1: dataposlen=0x8300006
SDO 0x3182.2: gainofs=0x3e8
-> Decoded mapping: rx 2 2 can_id=0x201 param='batvtg'(id=6) pos=48 len=8 gain=1.0 offset=0
SDO 0x3182.3: not found
SDO 0x3183.0: not found
CAN mappings:
* SDO 0x3100.2: tx 0 2 can_id=0x101 param='temp1'(id=2003) pos=0 len=8 gain=1.0 offset=0
* SDO 0x3100.4: tx 0 4 can_id=0x101 param='temp3'(id=2005) pos=32 len=8 gain=1.0 offset=0
* SDO 0x3101.2: tx 1 2 can_id=0x102 param='temp3'(id=2005) pos=16 len=8 gain=1.0 offset=0
* SDO 0x3180.2: rx 0 2 can_id=0x202 param='soc'(id=5) pos=16 len=8 gain=1.0 offset=0
* SDO 0x3180.4: rx 0 4 can_id=0x202 param='soc'(id=5) pos=16 len=8 gain=1.0 offset=0
* SDO 0x3181.2: rx 1 2 can_id=0x203 param='maxcur'(id=19) pos=16 len=16 gain=1.0 offset=0
* SDO 0x3181.4: rx 1 4 can_id=0x203 param='maxpower'(id=17) pos=32 len=16 gain=1.0 offset=0
* SDO 0x3181.6: rx 1 6 can_id=0x203 param='lockpwm'(id=14) pos=48 len=8 gain=1.0 offset=0
* SDO 0x3182.2: rx 2 2 can_id=0x201 param='batvtg'(id=6) pos=48 len=8 gain=1.0 offset=0
