Zoe 52Kwh Battery Storage
Topics concerning storage of renewable energy e.g. home battery systems
lawrence
Been thanked: 13 times
Post by lawrence »
I wanted to share the project I've been working on recently, to set up home battery storage using a Renault Zoe 52kwh pack from a scrapped car.
The battery pack came from EV Breakers in Northern Ireland. The DC is connected to a FOX ESS H1 6kw high-voltage hybrid inverter via a MCB. The communications cable is connected to a Raspberry Pi based interface. This handle the can bus communications, the relays for 12v/precharge and the MOSFET to control the main contactor.
The Pi acts like a canbus bridge, communicating with the battery, and with the fox, so that they can talk to each other. It also handles Modbus to communicate with the inverter and the meters.
In the photos, you can also see a 12V battery backup power supply to maintain power to the control equipment in the case of a power failure so that the battery can still operate. There is also a small consumer unit for the essential power supply
This is only possible thanks to some code that woleg/rand12345 put on github showing the can bus protocol for both the Fox battery and the Zoe PH2 battery. Unfortunately it looks like that has since been removed, but there are some useful links I've pasted below
Fox Modbus:
https://github.com/StealthChesnut/HA-Fo ... usUSB.yaml
https://github.com/nathanmarlor/foxess_ ... ns.py#L180
Zoe canbus:
https://github.com/fesch/CanZE/blob/mas ... Fields.csv
usus
Re: Zoe 52Kwh Battery Storage
Post by usus »
Are you sending Modbus messages to the inverter?
Can you share the code?
lawrence
Post by lawrence »
Yes I'm using Modbus for both Zoe and Inverter comms. My code is quiet specific to the environment I use, but it's based on wolegs CAN sniffing here https://github.com/rand12345/solax_can_bus
usus
Post by usus »
I am ok on can side. running without problem.
But on the Modbus i don't have any registry description.
Being in Sweden i need to charge when the price is lowest may be in the middle of the day or the entire weekend.
For this i need to be able to tel inverter when to charge.
Second variant is to use CAN msg 0x1872-charge_max and set the inverters to charge all the time but I don't allow battery to be charge unless I want.
BR.
usus
lawrence
Post by lawrence »
Ah sorry I got confused. I use CAN bus to talk to the Zoe and the Battery side of the inverter. Seperately Modbus to talk to the data side of the inverter. I've been controlling the charge from the CAN side, by setting the max charge amps to stop/start the charge. I only use the Modbus to read data from the inverter to check things are working.
I haven't yet implemented it, but I believe you can set the timed charge parameters via Modbus
If you set Time 1 to for example 01:00 to 02:00, with enabled off. The battery will go into standby at 01:00 to 02:00 and your house will use cheap grid power. If you set enabled to on, your battery will force charge up to the max charge limit set on the inverter settings. So you have to set Time 1 to have the same start/stop time to fully disable it.
I haven't implemented any of this yet as during the summer there is so much solar I haven't needed to use our cheap grid time which for us is 00:30 to 04:30.
usus
Post by usus »
I leave in Uk 2 years and is simple to import power. Plus in the north is no gas only electricity. in a month here i use like in a year in UK :).
In nordic counties power is like the stock market and the pay for transport fees. For example tomorrow (12.07.23) the cheapest hour in SE3 it is between 13:00-14:00.
https://www.nordpoolgroup.com/en/Market ... view=table
I was thinking that is not the best solution to enable charging via CAN by max charge on the battery but for the moment i will go that way.
Still why do you use 3 converter for Modbus? Ca not be all on the same bus with different ID?
lawrence
Post by lawrence »
Ah okay. I've been controlling charging via max_charge amps and it seems to work well, it's very quick to respond and can keep the battery at a specific charge level that way.
One modbus talks to Fox on the normal RS485, another is for my main Modbus network with multiple devices, and the other is on the Fox Meter Modbus. I intercept the fox meter modbus because if it's on the normal main modbus network, it wants to be the master. There can only be one master on Modbus so then I wouldn't be able to talk to anything else on the modbus network.
I could put the normal Fox RS485 on the main network, I just haven't tried it yet
yasko
Has thanked: 5 times
Been thanked: 18 times
Post by yasko »
lawrence wrote: Mon Jul 03, 2023 1:10 pm I wanted to share the project I've been working on recently, to set up home battery storage using a Renault Zoe 52kwh pack from a scrapped car.
Nice project!
Do you have a pinout of the LV battery connector? I'm unsure whether it is the same as previous models (22 and 41kWh).
The picture looks the same, but can you confirm that signals also correspond?
I'm on the way to doing a similar project, but I'm still researching.
lawrence
Post by lawrence »
The connector is the same 12 Pin 7282-8854-30 but the pinout is different, pinouts attached. These are from Renault "New Dialogys" which you can pay for, for just an hour, to get diagrams and pinouts. For the relays to work you'll need to connect that "HYBRID 3 Relayed" pin, but I can't remember if it needs -12 or +12v off the top of my head.
You can see canbus dumps from the HEV bus here https://github.com/ljames28/Zoe-PH2-EV- ... nformation . It only really needs to see 0x373 to wake up and then you can talk to it using https://github.com/fesch/CanZE/blob/mas ... Fields.csv
However, I've had the battery running since, and the delta between the minimum and maximum cell volages has been rising. It's now sitting around 120mv. There is at least one other person with the same issue. As far as we can tell, the battery is never balancing. Presumably there is some sort of signal or something on the canbus in a certain sequence that it is expecting to see. I've even dissambled most of the LBC controller code but haven't yet worked this out.
lawrence
Post by lawrence »
I believe the balancing issue is now solved by sending accurate time information to the pack via the canbus. There is more information about all the LBC can frames here https://github.com/ljames28/Renault-Zoe ... nformation
geamanug
Post by geamanug »
Hello. I am trying to sniff data out of a 27 kw Dacia Spring pack so I can complete integration with a Fronius hybrid inverter. So far I managed to build a data extension cable and also bought a can reader out of aliexpress in order to use it with busmaster or savvycan. I did some work with rs485 in the past but limited knowledge with can protocol. Any guidance would be greatly appreciated. New to this forum so please be kind with my mistakes.
Has thanked: 361 times
Been thanked: 1521 times
Hi, can you place the Dacia info into a new thread. Thanks!
TeslaCoilkV
Post by TeslaCoilkV »
Hello I want to make an OBD 2 battery health checker
It worked for my nissan leaf, but now I bought a Renault Zoe used and I want to check a used bigger kWh battery in order to swap
For nissan leaf, I connect12 V DC and the pins for the canbus and a female OBD2 ( soldering the right pins I find out details at nissan leaf repair manual and on Dalas Ev repair GitHub for the record ) that you connect an ELM327 Bluetooth or konnwei or what is working with you phone app (for my nissan leaf LedLink^2 worked better for the record) and easy to use
I saw that you said 12 pinouts for the hybrid
My question is for Renault Zoe is if the pins on the Zoe is the canbus pins on the battery connector 14 pins or 12 pins , because I want to buy it from AliExpress
Thank you
lawrence
Post by lawrence »
TeslaCoilkV wrote: Sat May 25, 2024 7:15 pm Hello I want to make an OBD 2 battery health checker
Thank you
You can see a diagram of the connector a few posts up that shows the amount of pins
TeslaCoilkV
Yeah but in the photo has got 14 pins and is not clear
I will have my used car in a month to see this better , for the battery I will have to fly to Germany or Norway so is not easy to find out for use how many is the pins , I just want to save time to fix my testing plug.
I order the 12 pins connectors female and male from AliExpress , is very cheap and may be I can connect the 12 pins on a 14 with some configuration , but I am not sure because of the photo.
Besides that he connector of 12 pins is for the hybrid , but yeah I only need the can L can H to connect it. Thanks for the reply but we need a better quality picture or a schematic from the ZOE to be here for the record to help others. Keep up-dating
lawrence
Post by lawrence »
TeslaCoilkV wrote: Sun May 26, 2024 12:33 am Yeah but in the photo has got 14 pins and is not clear
I believe Yaskos photo shows 12 pins. You can go on Renault ASOS/DIALOGYS to download diagrams of any Renault connectors
tomspappola
Post by tomspappola »
Do you know where i can buy connectors for the "can and high voltage" for the 52000wh zoe battery ?
Tom
lawrence
Post by lawrence »
You can get the LV connectors on Aliexpress. HV I don't know, I got mine with the battery from the scrapyard.
craig
Post by craig »
Hi Lawrence my name is Craig Smith.
I have the same inverter as your you, well the H1.5.0-E-G2 version, do you manage to fill the ev battery in one over night charge, also have you got a
wiring diagram of what you,ve carried out?
thanks in advance craig.
lawrence
Post by lawrence »
It would depend how depleted the battery was, and what tarriff you're on. In my case, almost always yes.
No wiring diagram. If you're looking to replicate this, there is a community built up around https://github.com/dalathegreat/Battery-Emulator
craig
Post by craig »
hi Lawrence ive been pricing up ev batteries so far not much joy.
Could i ask how much your battery was ,and where did you get it from
Thanks Craig.
