Simp BMS
Re: Simp BMS
Hi All this is my first post on here.
I recently purchased A VW passat pack to upgrade my home battery / solar setup (this is a 360V 96s system if anyone is interested) and immediately ran into the teensy 3.2 shortage problem.
I have my own modified version of simpBMS which can send a JSON string via Wi-Fi to my home automation system via an ESP8266 of course.
I spotted that someone had kindly ported simp to the teensy4.0, the code worked and compiled as expected however many of the cell voltages were being missed. This appeared to be the first few cells on the first few modules.
After trying many different approaches I discovered the problem seems to be with the FlexCAN_T4 library, it seems that some packets are not received following a can send.
If I comment out the sendcommand() function call and send the 0x0BA command from linux via my can sniffer, I get all the voltages, proving the hypothesis. I did try converting simp over to an interrupt driven approach to receiving can messages but this had no effect, the messages were still lost unless send from and external source.
So a very long story short I moved the send command function call to
if (millis() - looptime1 > settings.chargerspd)
sendcommand();
looptime1 = millis();
if (settings.ESSmode == 1)
This effectively gives enough time for FlexCAN to get its act together before polling for messages.
I hope this helps someone
Cheers
sendcommand();
Cheers
- Has thanked: 215 times
- Been thanked: 600 times
Re: Simp BMS
Very strange would not expect that. All my new products currently use the Teensy 4.0 without any problems like you described it must be a sloppy port. I fully rewrote all my functions for my new firmware though.Gwizard wrote: ↑Tue Oct 24, 2023 12:46 pm After trying many different approaches I discovered the problem seems to be with the FlexCAN_T4 library, it seems that some packets are not received following a can send.
Re: Simp BMS
Hi Tom, I don't know but it's one to keep an eye on for anyone using the FlexCAN_T4 library in case it crops up in any other projects.
- Has thanked: 36 times
- Been thanked: 34 times
Re: Simp BMS
Hi, SimpBMS reports HV voltage on id 0x356 over two bytes (MSB and LSB). Could somebody help to combine those two bytes into a single hex voltage value for arduino Due board?
- EV_Builder
- Been thanked: 37 times
Re: Simp BMS
In the Arduino code?
Not sure what you upto.
But combineing 2 bytes into a 16BIT.
Int8 byte1 = 0;
Int8 byte2 = 0;
Int16 vint_16 = ( byte1 <<16 ) + byte2;
Int8 byte1 = 0;
Int8 byte2 = 0;
Re: Simp BMS
I am using an EVS BMS with VW MEB 12S modules. The BMS is working, but now I want to balance the cells (properly this will take weeks, but anyway).
The battery status shows "Balancing Active" and sometimes "Balancing Paused":
But I have the impression that it is not balancing (cell voltage did not change after 24hrs).
The contactors are OPEN when I am trying to get the cells balanced.
What does the "Bal: 0x0" mean?
BMS State: Ready || Balancing Active
Modules: 5 Cells: 60 Strings: 1 Voltage: 223.364V Avg Cell Voltage: 3.723V Low Cell Voltage: 3.471V High Cell Voltage: 4.130V Delta Voltage: 659mV Avg Temp: 8.200C
Current Limits - Discharge 285A Charge 2A || ChargePort 0A || Pack Volt : 0.000V Bus Volt : 0.000V Pack Current : 18mA Pack SOC : 100
Module #1 43.40V Cell 1: 3.62V Cell 2: 3.60V Cell 3: 3.62V Cell 4: 3.62V Cell 5: 3.62V Cell 6: 3.62V Cell 7: 3.62V Cell 8: 3.62V Cell 9: 3.62V Cell 10: 3.62V Cell 11: 3.62V Cell 12: 3.62V
Temp 1: 8.00C Temp 2: 0.00C Status: 0x0 Bal: 0x0
Module #5 49.23V Cell 13: 4.12V Cell 14: 4.12V Cell 15: 4.13V Cell 16: 4.13V Cell 17: 4.13V Cell 18: 4.13V Cell 19: 4.13V Cell 20: 4.13V Cell 21: 3.83V Cell 22: 4.13V Cell 23: 4.13V Cell 24: 4.12V
Module #6 43.31V Cell 25: 3.60V Cell 26: 3.62V Cell 27: 3.62V Cell 28: 3.60V Cell 29: 3.62V Cell 30: 3.62V Cell 31: 3.62V Cell 32: 3.54V Cell 33: 3.62V Cell 34: 3.62V Cell 35: 3.62V Cell 36: 3.62V
Temp 1: 8.50C Temp 2: 0.00C Status: 0x0 Bal: 0x0
Module #7 44.15V Cell 37: 3.68V Cell 38: 3.68V Cell 39: 3.68V Cell 40: 3.68V Cell 41: 3.68V Cell 42: 3.68V Cell 43: 3.68V Cell 44: 3.68V Cell 45: 3.68V Cell 46: 3.68V Cell 47: 3.68V Cell 48: 3.68V
Module #8 43.27V Cell 49: 3.62V Cell 50: 3.62V Cell 51: 3.62V Cell 52: 3.62V Cell 53: 3.62V Cell 54: 3.62V Cell 55: 3.62V Cell 56: 3.47V Cell 57: 3.62V Cell 58: 3.62V Cell 59: 3.62V Cell 60: 3.62V
Re: Simp BMS
I have sent you an PM with a request for some debug info. MEB Balance status is not fully interpreted at the moment.
- Has thanked: 71 times
- Been thanked: 29 times
Re: Simp BMS
Hello.
My first time upgrading the Tesla2BMSV2 firmware. Arduino IDE throws warning messages. Could somebody please confirm whether these can be disregarder? These look like mainly due converting\comparing variables of not matching types.
C:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\TeslaBMSV2\TeslaBMSV2.ino: In function 'void loadSettings()':
C:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\TeslaBMSV2\TeslaBMSV2.ino:217:19: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
217 | Logger::console("Resetting to factory defaults");
C:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\TeslaBMSV2\TeslaBMSV2.ino: In function 'void loop()':
C:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\TeslaBMSV2\TeslaBMSV2.ino:1020:28: warning: comparison of integer expressions of different signedness: 'uint32_t' {aka 'long unsigned int'} and 'int' [-Wsign-compare]
1020 | if (millis() - looptime1 > settings.chargerspd)
C:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\TeslaBMSV2\TeslaBMSV2.ino: In function 'void getcurrent()':
C:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\TeslaBMSV2\TeslaBMSV2.ino:1379:32: warning: comparison of integer expressions of different signedness: 'int' and 'long unsigned int' [-Wsign-compare]
1379 | if (value < 100 || value > (adc->adc0->getMaxValue() - 100))
C:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\TeslaBMSV2\TeslaBMSV2.ino: In function 'void canread()':
C:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\TeslaBMSV2\TeslaBMSV2.ino:3307:28: warning: ' ' flag used with '%X' gnu_printf format [-Wformat=]
3307 | sprintf(msgString, "Extended ID : 0x % .8lX DLC : % 1d Data : ", (inMsg.id & 0x1FFFFFFF), inMsg.len);
C:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\TeslaBMSV2\TeslaBMSV2.ino:3309:28: warning: ' ' flag used with '%X' gnu_printf format [-Wformat=]
3309 | sprintf(msgString, ", 0x % .3lX, false, % 1d", inMsg.id, inMsg.len);
C:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\TeslaBMSV2\TeslaBMSV2.ino:3318:30: warning: ' ' flag used with '%X' gnu_printf format [-Wformat=]
3318 | sprintf(msgString, ", 0x % .2X", inMsg.buf[i]);
C:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\TeslaBMSV2\TeslaBMSV2.ino: In function 'void CAB300()':
C:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\TeslaBMSV2\TeslaBMSV2.ino:3354:20: warning: comparison of integer expressions of different signedness: 'long int' and 'unsigned int' [-Wsign-compare]
3354 | if (CANmilliamps > 0x80000000)
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\SerialConsole.cpp: In member function 'void SerialConsole::printMenu()':
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\SerialConsole.cpp:58:21: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
58 | Logger::console("\n*************SYSTEM MENU *****************");
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\SerialConsole.cpp:59:21: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
59 | Logger::console("Enable line endings of some sort (LF, CR, CRLF)");
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\SerialConsole.cpp:60:21: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
60 | Logger::console("Most commands case sensitive\n");
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\SerialConsole.cpp:61:21: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
61 | Logger::console("GENERAL SYSTEM CONFIGURATION\n");
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\SerialConsole.cpp:62:21: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
62 | Logger::console(" h = help (displays this message)");
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\SerialConsole.cpp:63:21: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
63 | Logger::console(" S = Sleep all boards");
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\SerialConsole.cpp:64:21: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
64 | Logger::console(" W = Wake up all boards");
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\SerialConsole.cpp:65:21: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
65 | Logger::console(" C = Clear all board faults");
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\SerialConsole.cpp:66:21: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
66 | Logger::console(" F = Find all connected boards");
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\SerialConsole.cpp:67:21: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
67 | Logger::console(" R = Renumber connected boards in sequence");
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\SerialConsole.cpp:68:21: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
68 | Logger::console(" B = Attempt balancing for 5 seconds");
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\SerialConsole.cpp:69:21: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
69 | Logger::console(" p = Toggle output of pack summary every 3 seconds");
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\SerialConsole.cpp:70:21: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
70 | Logger::console(" d = Toggle output of pack details every 3 seconds");
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\SerialConsole.cpp:72:21: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
72 | Logger::console(" LOGLEVEL=%i - set log level (0=debug, 1=info, 2=warn, 3=error, 4=off)", Logger::getLogLevel());
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\SerialConsole.cpp:74:11: warning: unused variable 'OverVSetpoint' [-Wunused-variable]
74 | float OverVSetpoint;
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\SerialConsole.cpp:75:11: warning: unused variable 'UnderVSetpoint' [-Wunused-variable]
75 | float UnderVSetpoint;
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\SerialConsole.cpp:76:11: warning: unused variable 'OverTSetpoint' [-Wunused-variable]
76 | float OverTSetpoint;
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\SerialConsole.cpp:77:11: warning: unused variable 'UnderTSetpoint' [-Wunused-variable]
77 | float UnderTSetpoint;
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\SerialConsole.cpp:78:11: warning: unused variable 'balanceVoltage' [-Wunused-variable]
78 | float balanceVoltage;
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\SerialConsole.cpp:79:11: warning: unused variable 'balanceHyst' [-Wunused-variable]
79 | float balanceHyst;
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\SerialConsole.cpp: In member function 'void SerialConsole::handleShortCmd()':
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\SerialConsole.cpp:126:25: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
126 | Logger::console("Sleeping all connected boards");
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\SerialConsole.cpp:130:25: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
130 | Logger::console("Waking up all connected boards");
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\SerialConsole.cpp:134:25: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
134 | Logger::console("Clearing all faults");
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\SerialConsole.cpp:141:25: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
141 | Logger::console("Renumbering all boards.");
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\SerialConsole.cpp:154:33: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
154 | Logger::console("Enabling pack summary display, 5 second interval");
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\SerialConsole.cpp:158:33: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
158 | Logger::console("No longer displaying pack summary.");
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\SerialConsole.cpp:170:33: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
170 | Logger::console("Enabling pack details display, 5 second interval");
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\SerialConsole.cpp:174:33: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
174 | Logger::console("No longer displaying pack details.");
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\SerialConsole.cpp:116:13: warning: unused variable 'val' [-Wunused-variable]
116 | uint8_t val;
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\Logger.cpp: In static member function 'static void Logger::log(Logger::LogLevel, char*, va_list)':
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\Logger.cpp:154:10: warning: enumeration value 'Off' not handled in switch [-Wswitch]
154 | switch (level) {
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\Logger.cpp: In static member function 'static void Logger::logMessage(char*, va_list)':
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\Logger.cpp:202:24: warning: ISO C++17 does not allow 'register' storage class specifier [-Wregister]
202 | register char *s = (char *) va_arg( args, int );
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\BMSModule.cpp: In member function 'bool BMSModule::readModuleValues()':
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\BMSModule.cpp:152:17: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
152 | Logger::debug("Module %i alerts=%X faults=%X COV=%X CUV=%X", moduleAddress, alerts, faults, COVFaults, CUVFaults);
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\BMSModule.cpp:171:17: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
171 | Logger::debug("Sent CRC: %x Calculated CRC: %x", buff[21], calcCRC);
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\BMSModule.cpp:212:21: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
212 | Logger::debug("Got voltage and temperature readings");
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\BMSModule.cpp:218:19: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
218 | Logger::error("Invalid module response received for module %i len: %i crc: %i calc: %i",
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\BMSModuleManager.cpp: In member function 'void BMSModuleManager::setupBoards()':
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\BMSModuleManager.cpp:144:23: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
144 | Logger::debug("00 found");
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\BMSModuleManager.cpp:161:31: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
161 | Logger::debug("Address assigned");
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\BMSModuleManager.cpp: In member function 'void BMSModuleManager::getAllVoltTemp()':
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\BMSModuleManager.cpp:347:21: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
347 | Logger::debug("");
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\BMSModuleManager.cpp:348:21: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
348 | Logger::debug("Module %i exists. Reading voltage and temperature values", x);
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\BMSModuleManager.cpp:350:21: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
350 | Logger::debug("Module voltage: %f", modules[x].getModuleVoltage());
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\BMSModuleManager.cpp:351:21: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
351 | Logger::debug("Lowest Cell V: %f Highest Cell V: %f", modules[x].getLowCellV(), modules[x].getHighCellV());
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\BMSModuleManager.cpp:352:21: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
352 | Logger::debug("Temp1: %f Temp2: %f", modules[x].getTemperature(0), modules[x].getTemperature(1));
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\BMSModuleManager.cpp:364:35: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
364 | if (!isFaulted) Logger::error("One or more BMS modules have entered the fault state!");
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\BMSModuleManager.cpp:369:33: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
369 | if (isFaulted) Logger::info("All modules have exited a faulted state");
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\BMSModuleManager.cpp: In member function 'void BMSModuleManager::printPackSummary()':
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\BMSModuleManager.cpp:509:19: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
509 | Logger::console("");
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\BMSModuleManager.cpp:510:19: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
510 | Logger::console("");
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\BMSModuleManager.cpp:511:19: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
511 | Logger::console("");
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\BMSModuleManager.cpp:512:19: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
512 | Logger::console("Modules: %i Voltage: %fV Avg Cell Voltage: %fV Avg Temp: %fC ", numFoundModules,
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\BMSModuleManager.cpp:514:19: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
514 | Logger::console("");
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\BMSModuleManager.cpp:524:23: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
524 | Logger::console(" Module #%i", y);
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\BMSModuleManager.cpp:526:23: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
526 | Logger::console(" Voltage: %fV (%fV-%fV) Temperatures: (%fC-%fC)", modules[y].getModuleVoltage(),
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\BMSModuleManager.cpp:530:25: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
530 | Logger::console(" MODULE IS FAULTED:");
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\BMSModuleManager.cpp:559:27: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
559 | Logger::console(" CRC error in received packet");
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\BMSModuleManager.cpp:563:27: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
563 | Logger::console(" Power on reset has occurred");
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\BMSModuleManager.cpp:567:27: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
567 | Logger::console(" Test fault active");
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\BMSModuleManager.cpp:571:27: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
571 | Logger::console(" Internal registers inconsistent");
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\BMSModuleManager.cpp:576:25: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
576 | Logger::console(" MODULE HAS ALERTS:");
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\BMSModuleManager.cpp:579:27: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
579 | Logger::console(" Over temperature on TS1");
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\BMSModuleManager.cpp:583:27: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
583 | Logger::console(" Over temperature on TS2");
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\BMSModuleManager.cpp:587:27: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
587 | Logger::console(" Sleep mode active");
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\BMSModuleManager.cpp:591:27: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
591 | Logger::console(" Thermal shutdown active");
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\BMSModuleManager.cpp:595:27: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
595 | Logger::console(" Test Alert");
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\BMSModuleManager.cpp:599:27: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
599 | Logger::console(" OTP EPROM Uncorrectable Error");
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\BMSModuleManager.cpp:603:27: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
603 | Logger::console(" GROUP3 Regs Invalid");
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\BMSModuleManager.cpp:607:27: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
607 | Logger::console(" Address not registered");
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\BMSModuleManager.cpp: In member function 'void BMSModuleManager::printPackDetails(int)':
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\BMSModuleManager.cpp:623:19: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
623 | Logger::console("");
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\BMSModuleManager.cpp:624:19: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
624 | Logger::console("");
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\BMSModuleManager.cpp:625:19: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
625 | Logger::console("");
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\BMSModuleManager.cpp:626:19: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
626 | Logger::console("Modules: %i Cells: %i Strings: %i Voltage: %fV Avg Cell Voltage: %fV Low Cell Voltage: %fV High Cell Voltage: %fV Delta Voltage: %zmV Avg Temp: %fC ", numFoundModules, seriescells(),
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\BMSModuleManager.cpp:628:19: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
628 | Logger::console("");
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\BMSModuleManager.cpp:617:11: warning: variable 'faults' set but not used [-Wunused-but-set-variable]
617 | uint8_t faults;
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\BMSModuleManager.cpp:618:11: warning: variable 'alerts' set but not used [-Wunused-but-set-variable]
618 | uint8_t alerts;
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\BMSModuleManager.cpp:619:11: warning: variable 'COV' set but not used [-Wunused-but-set-variable]
619 | uint8_t COV;
c:\Users\alexbeatle\Documents\Arduino\libraries\TeslaBMSV2-master\BMSModuleManager.cpp:620:11: warning: variable 'CUV' set but not used [-Wunused-but-set-variable]
620 | uint8_t CUV;
c:\Users\alexbeatle\Documents\Arduino\libraries\Filters-master\src\FilterDerivative.cpp: In function 'void testFilterDerivative()':
c:\Users\alexbeatle\Documents\Arduino\libraries\Filters-master\src\FilterDerivative.cpp:9:22: warning: 'der.FilterDerivative::LastInput' may be used uninitialized in this function [-Wmaybe-uninitialized]
9 | Derivative = (inVal-LastInput) / dt;
c:\Users\alexbeatle\Documents\Arduino\libraries\Filters-master\src\FilterDerivative.cpp:18:20: note: 'der.FilterDerivative::LastInput' was declared here
18 | FilterDerivative der;
c:\Users\alexbeatle\Documents\Arduino\libraries\Filters-master\src\FilterDerivative.cpp:6:32: warning: 'der.FilterDerivative::LastUS' may be used uninitialized in this function [-Wmaybe-uninitialized]
6 | float dt = 1e-6*float(thisUS - LastUS); // cast to float here, for math
c:\Users\alexbeatle\Documents\Arduino\libraries\Filters-master\src\FilterDerivative.cpp:18:20: note: 'der.FilterDerivative::LastUS' was declared here
c:\Users\alexbeatle\Documents\Arduino\libraries\Filters-master\src\FilterOnePole.cpp: In member function 'void FilterOnePoleCascade::test()':
c:\Users\alexbeatle\Documents\Arduino\libraries\Filters-master\src\FilterOnePole.cpp:207:9: warning: unused variable 'lastFilterVal' [-Wunused-variable]
207 | float lastFilterVal = 0;
c:\Users\alexbeatle\Documents\Arduino\libraries\Serial_CAN_Module_TeensyS2\Serial_CAN_Module_TeensyS2.cpp: In member function 'unsigned char Serial_CAN::send(long unsigned int, unsigned char, unsigned char, unsigned char, const unsigned char*)':
c:\Users\alexbeatle\Documents\Arduino\libraries\Serial_CAN_Module_TeensyS2\Serial_CAN_Module_TeensyS2.cpp:38:1: warning: no return statement in function returning non-void [-Wreturn-type]
38 | }
c:\Users\alexbeatle\Documents\Arduino\libraries\Serial_CAN_Module_TeensyS2\Serial_CAN_Module_TeensyS2.cpp: In member function 'unsigned char Serial_CAN::exitSettingMode()':
c:\Users\alexbeatle\Documents\Arduino\libraries\Serial_CAN_Module_TeensyS2\Serial_CAN_Module_TeensyS2.cpp:175:21: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
175 | int ret = cmdOk("AT+Q\r\n");
c:\Users\alexbeatle\Documents\Arduino\libraries\Serial_CAN_Module_TeensyS2\Serial_CAN_Module_TeensyS2.cpp: In member function 'unsigned char Serial_CAN::setMask(long unsigned int*)':
c:\Users\alexbeatle\Documents\Arduino\libraries\Serial_CAN_Module_TeensyS2\Serial_CAN_Module_TeensyS2.cpp:210:38: warning: format '%d' expects argument of type 'int', but argument 4 has type 'long unsigned int' [-Wformat=]
210 | sprintf(str_tmp, "AT+M=[%d][%d][", i, dta[2*i]);
| int long unsigned int
| %ld
c:\Users\alexbeatle\Documents\Arduino\libraries\Serial_CAN_Module_TeensyS2\Serial_CAN_Module_TeensyS2.cpp: In member function 'unsigned char Serial_CAN::setFilt(long unsigned int*)':
c:\Users\alexbeatle\Documents\Arduino\libraries\Serial_CAN_Module_TeensyS2\Serial_CAN_Module_TeensyS2.cpp:247:38: warning: format '%d' expects argument of type 'int', but argument 4 has type 'long unsigned int' [-Wformat=]
247 | sprintf(str_tmp, "AT+F=[%d][%d][", i, dta[2*i]);
| %ld
c:\Users\alexbeatle\Documents\Arduino\libraries\Serial_CAN_Module_TeensyS2\Serial_CAN_Module_TeensyS2.cpp: In member function 'unsigned char Serial_CAN::factorySetting()':
c:\Users\alexbeatle\Documents\Arduino\libraries\Serial_CAN_Module_TeensyS2\Serial_CAN_Module_TeensyS2.cpp:289:18: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
289 | if(cmdOk("AT\r\n"))
Opening Teensy Loader...
Sketch uses 98260 bytes (37%) of program storage space. Maximum is 262144 bytes.
Global variables use 15848 bytes (24%) of dynamic memory, leaving 49688 bytes for local variables. Maximum is 65536 bytes.
Re: Simp BMS
Why are you compiling? There is a .hex you can upload. If you compile your own versions then giving support on any issues is not really possible due to library changes ect.alexbeatle wrote: ↑Thu Apr 04, 2024 2:42 am Hello.
Re: Simp BMS
ok. Learned something new. I'll try the .hex file. Is it the most up-to-date? Shows a month difference between the project and the .hex.
Re: Simp BMS
Yes it is, only gotten something in it someone wanted to do. Specific to their usecase, it is not an update from me. The .HEX is from me.
Re: Simp BMS
I'd like to verify something, please.
I have 14 Tesla MS batteries in series - 5.3kWh, 232Ah each. None in parallel.
When it comes to setting the battery pack capacity the firmware defaults to 100Ah. Is that a precautionary value since diy batteries aren't new so this to be left as-is or changing to 232Ah is safe?
Another question - simpBMS + LIM.
LIM needs battery capacity in Wh with 0.1 scale.
So confirming this is the correct way to calculate it.
These are available from the simpBMS CAN messaging:
Ah= 0x379 byte[0] and byte [1];
Max. Pack Charge Voltage aka. Charge Vsetpoint = 0x351 byte[0] and byte [1]
Wh = Ah * Max. Pack Charge Voltage
msg.id = 0x379; //Installed capacity
msg.len = 8;
msg.buf[0] = lowByte(uint16_t(settings.Pstrings * settings.CAP));
msg.buf[1] = highByte(uint16_t(settings.Pstrings * settings.CAP));
void VEcan() //communication with Victron system over CAN
msg.id = 0x351;
msg.len = 8;
if (storagemode == 0)
msg.buf[0] = lowByte(uint16_t((settings.ChargeVsetpoint * settings.Scells ) * 10));
msg.buf[1] = highByte(uint16_t((settings.ChargeVsetpoint * settings.Scells ) * 10));
else
msg.buf[0] = lowByte(uint16_t((settings.StoreVsetpoint * settings.Scells ) * 10));
msg.buf[1] = highByte(uint16_t((settings.StoreVsetpoint * settings.Scells ) * 10));
Re: Simp BMS
The standard settings are just "random" you need to set the capacity yourself to what ever works. You can start at name plate and adjust when needed.
Yes that calc works, not 100% required to be accurate not all CCS chargers do anything with the info.
- mane2
- Has thanked: 40 times
- Been thanked: 41 times
Re: Simp BMS
There seems to be many forks and copies of Simpbms git repo for different Arduino platforms (eg teensy 4, esp32) and chargers that are not supported by the official software. I plan to use my Teensy 4.0 (as 3.2 is no longer available) with X5 pack and Outlander charger. I've seen outlander support on some repos, but not sure which one to use. Any recommendations?
I was also thinking of using BMW Safetybox for precharge, contactor control and maybe for current sensor if possible. This way I wouldn't need anything else than added can transceiver.
Not sure if any of those simpbms forks support that combo, teensy 4 & outlander charger & safetybox?
- rstevens81
- Has thanked: 29 times
- Been thanked: 111 times
Re: Simp BMS
these forks are not affiliated with simp or tom, we are doing out own thing, unless you know what you are doing i would recommend buying either a real simp bms or the newer evs-bms from toms suppliers.
Although its fun developing a board for your own purposes and porting code the time spent will be questionable against just buying the simp bms. (i know because im the idiot that designed the spaceballs (esp32) pcb and wouldn't go as far to recommend it it to someone [due to the esp32 can bug & the beta nature of the code]).
in terms of sbox prob best go with zombie for that as thats known to work
- Has thanked: 427 times
- Been thanked: 123 times
Re: Simp BMS
Correct me if I'm wrong but simpbms is not for sale anywhere as far as I can tell.rstevens81 wrote: ↑Wed Apr 24, 2024 8:31 am i would recommend buying either a real simp bms or the newer evs-bms from toms suppliers.
- mane2
Re: Simp BMS
Yeah, well aware of that. Though, I would probably buy that evs-bms (or discontinued simpbms) if it would support that combo.rstevens81 wrote: ↑Wed Apr 24, 2024 8:31 am these forks are not affiliated with simp or tom, we are doing out own thing, unless you know what you are doing i would recommend buying either a real simp bms or the newer evs-bms from toms suppliers.
ESP32 is less than half price of Teensy 4, but was there some other advantages using ESP32 instead of Teensy 4?rstevens81 wrote: ↑Wed Apr 24, 2024 8:31 am Although its fun developing a board for your own purposes and porting code the time spent will be questionable against just buying the simp bms. (i know because im the idiot that designed the spaceballs (esp32) pcb and wouldn't go as far to recommend it it to someone [due to the esp32 can bug & the beta nature of the code]).
I could have a stab doing that port myself. I'd like to have only one Arduino doing all this stuff. Less wiring and less devices communicating with each other = less problems. BMW Safetybox sources/info seems to be here https://github.com/damienmaguire/BMW_SBoxrstevens81 wrote: ↑Wed Apr 24, 2024 8:31 am in terms of sbox prob best go with zombie for that as thats known to work
Found this BMW PHEV & Outlander charger repo https://github.com/aot93/BMWPhevBMS-OutlanderCharger
Would be great if there would be BMWPhevBMS repo with Teensy 4 support. Maybe there is?
Re: Simp BMS
I can look at adding the saftey box into the EVS-BMS supported ones. Yes I do not know if the Sbox can live on the same bus as the battery modules and still work. Luckily the EVS-BMS has two CAN busses.
- Has thanked: 22 times
- Been thanked: 133 times
Re: Simp BMS
I tested this last year. Battery modules and Sbox clash on id 0x100 so can not share the same bus.
Re: Simp BMS
I spun the wheels of my car with the full pack today for the first time. After 10mins or so, BMS went into "error" claiming series connection fault. Even after the motor stopped spinning.
Never had this before previously- when motor stationary or running at half-pack sometime ago. After rebooting, BMS went into ready, but still "series fault", though then recovered.
I have 2 packs. 1st pack - modules #1-5, 2nd pack - modules 6-14.
Any clue what could cause this?
21:20:06.758 -> 0
21:20:06.758 -> BMS Status : 5 Error 84
21:20:06.758 -> Out:0000 Cont:0000 In:0000 Charge Current Limit : 0 A DisCharge Current Limit : 0 A
21:20:06.758 ->
21:20:06.758 ->
21:20:06.758 -> Modules: 14 Cells: 0 Strings: 1 Voltage: 0.000V Avg Cell Voltage: nanV Low Cell Voltage: 5.000V High Cell Voltage: 0.000V Delta Voltage: -5000mV Avg Temp: 0.000C
21:20:06.758 ->
21:20:06.758 -> Module #1 0.00V Cell0: 0.00V Cell1: 0.00V Cell2: 0.00V Cell3: 0.00V Cell4: 0.00V Cell5: 0.00V Neg Term Temp: 0.00C Pos Term Temp: 0.00C
21:20:06.758 -> Module #2 0.00V Cell6: 0.00V Cell7: 0.00V Cell8: 0.00V Cell9: 0.00V Cell10: 0.00V Cell11: 0.00V Neg Term Temp: 0.00C Pos Term Temp: 0.00C
21:20:06.758 -> Module #3 0.00V Cell12: 0.00V Cell13: 0.00V Cell14: 0.00V Cell15: 0.00V Cell16: 0.00V Cell17: 0.00V Neg Term Temp: 0.00C Pos Term Temp: 0.00C
21:20:06.758 -> Module #4 0.00V Cell18: 0.00V Cell19: 0.00V Cell20: 0.00V Cell21: 0.00V Cell22: 0.00V Cell23: 0.00V Neg Term Temp: 0.00C Pos Term Temp: 0.00C
21:20:06.758 -> Module #5 0.00V Cell24: 0.00V Cell25: 0.00V Cell26: 0.00V Cell27: 0.00V Cell28: 0.00V Cell29: 0.00V Neg Term Temp: 0.00C Pos Term Temp: 0.00C
21:20:06.758 -> Module #6 0.00V Cell30: 0.00V Cell31: 0.00V Cell32: 0.00V Cell33: 0.00V Cell34: 0.00V Cell35: 0.00V Neg Term Temp: 0.00C Pos Term Temp: 0.00C
21:20:06.758 -> Module #7 0.00V Cell36: 0.00V Cell37: 0.00V Cell38: 0.00V Cell39: 0.00V Cell40: 0.00V Cell41: 0.00V Neg Term Temp: 0.00C Pos Term Temp: 0.00C
21:20:06.758 -> Module #8 0.00V Cell42: 0.00V Cell43: 0.00V Cell44: 0.00V Cell45: 0.00V Cell46: 0.00V Cell47: 0.00V Neg Term Temp: 0.00C Pos Term Temp: 0.00C
21:20:06.759 -> Module #9 0.00V Cell48: 0.00V Cell49: 0.00V Cell50: 0.00V Cell51: 0.00V Cell52: 0.00V Cell53: 0.00V Neg Term Temp: 0.00C Pos Term Temp: 0.00C
21:20:06.759 -> Module #10 0.00V Cell54: 0.00V Cell55: 0.00V Cell56: 0.00V Cell57: 0.00V Cell58: 0.00V Cell59: 0.00V Neg Term Temp: 0.00C Pos Term Temp: 0.00C
21:20:06.759 -> Module #11 0.00V Cell60: 0.00V Cell61: 0.00V Cell62: 0.00V Cell63: 0.00V Cell64: 0.00V Cell65: 0.00V Neg Term Temp: 0.00C Pos Term Temp: 0.00C
21:20:06.759 -> Module #12 0.00V Cell66: 0.00V Cell67: 0.00V Cell68: 0.00V Cell69: 0.00V Cell70: 0.00V Cell71: 0.00V Neg Term Temp: 0.00C Pos Term Temp: 0.00C
21:20:06.759 -> Module #13 0.00V Cell72: 0.00V Cell73: 0.00V Cell74: 0.00V Cell75: 0.00V Cell76: 0.00V Cell77: 0.00V Neg Term Temp: 0.00C Pos Term Temp: 0.00C
21:20:06.759 -> Module #14 0.00V Cell78: 0.00V Cell79: 0.00V Cell80: 0.00V Cell81: 0.00V Cell82: 0.00V Cell83: 0.00V Neg Term Temp: 0.00C Pos Term Temp: 0.00C
21:20:06.759 -> CANbus 1216488320.00mA 100% SOC 210000.00mAh
21:20:06.759 -> !!! Series Cells Fault !!!
21:20:22.938 -> Starting up!
21:20:22.938 -> SimpBMS V2 Tesla
21:20:22.938 ->
21:20:22.938 -> Reason for last Reset:
21:20:22.938 -> Power-on Reset
21:20:22.938 -> Low-voltage Detect Reset
21:20:22.938 ->
21:20:22.938 -> Started serial interface to BMS.
21:20:24.639 -> Recovery SOC:
21:20:24.639 -> 100
21:20:25.135 ->
21:20:24.639 -> 100
21:20:25.135 ->
21:20:25.135 -> 0
21:20:25.135 -> BMS Status : 1 Ready 0
21:20:25.135 -> Out:0000 Cont:0000 In:0000 Charge Current Limit : 0 A DisCharge Current Limit : 0 A
21:20:25.135 ->
21:20:25.135 ->
21:20:25.135 -> Modules: 14 Cells: 0 Strings: 1 Voltage: 324.503V Avg Cell Voltage: 3.863V Low Cell Voltage: 3.848V High Cell Voltage: 3.867V Delta Voltage: 19mV Avg Temp: 22.626C
21:20:25.135 ->
21:20:25.135 -> Module #1 23.16V Cell0: 3.86V Cell1: 3.86V Cell2: 3.86V Cell3: 3.86V Cell4: 3.86V Cell5: 3.85V Neg Term Temp: 22.12C Pos Term Temp: 21.35C
21:20:25.135 -> Module #2 23.17V Cell6: 3.86V Cell7: 3.86V Cell8: 3.86V Cell9: 3.86V Cell10: 3.86V Cell11: 3.86V Neg Term Temp: 22.74C Pos Term Temp: 21.69C
21:20:25.135 -> Module #3 23.18V Cell12: 3.86V Cell13: 3.86V Cell14: 3.86V Cell15: 3.86V Cell16: 3.86V Cell17: 3.86V Neg Term Temp: 22.58C Pos Term Temp: 21.98C
21:20:25.135 -> Module #4 23.18V Cell18: 3.86V Cell19: 3.86V Cell20: 3.86V Cell21: 3.86V Cell22: 3.86V Cell23: 3.86V Neg Term Temp: 22.67C Pos Term Temp: 22.06C
21:20:25.135 -> Module #5 23.18V Cell24: 3.86V Cell25: 3.86V Cell26: 3.87V Cell27: 3.86V Cell28: 3.86V Cell29: 3.86V Neg Term Temp: 22.72C Pos Term Temp: 22.26C
21:20:25.135 -> Module #6 23.18V Cell30: 3.86V Cell31: 3.86V Cell32: 3.86V Cell33: 3.87V Cell34: 3.86V Cell35: 3.86V Neg Term Temp: 23.15C Pos Term Temp: 22.52C
21:20:25.135 -> Module #7 23.18V Cell36: 3.86V Cell37: 3.86V Cell38: 3.86V Cell39: 3.86V Cell40: 3.86V Cell41: 3.86V Neg Term Temp: 23.65C Pos Term Temp: 22.82C
21:20:25.135 -> Module #8 23.18V Cell42: 3.86V Cell43: 3.86V Cell44: 3.86V Cell45: 3.86V Cell46: 3.86V Cell47: 3.86V Neg Term Temp: 23.13C Pos Term Temp: 22.20C
21:20:25.135 -> Module #9 23.17V Cell48: 3.86V Cell49: 3.86V Cell50: 3.86V Cell51: 3.86V Cell52: 3.86V Cell53: 3.86V Neg Term Temp: 22.87C Pos Term Temp: 22.40C
21:20:25.135 -> Module #10 23.18V Cell54: 3.86V Cell55: 3.86V Cell56: 3.86V Cell57: 3.86V Cell58: 3.86V Cell59: 3.86V Neg Term Temp: 23.34C Pos Term Temp: 22.77C
21:20:25.135 -> Module #11 23.18V Cell60: 3.86V Cell61: 3.86V Cell62: 3.86V Cell63: 3.86V Cell64: 3.86V Cell65: 3.86V Neg Term Temp: 22.99C Pos Term Temp: 22.29C
21:20:25.135 -> Module #12 23.19V Cell66: 3.86V Cell67: 3.87V Cell68: 3.87V Cell69: 3.87V Cell70: 3.87V Cell71: 3.86V Neg Term Temp: 23.09C Pos Term Temp: 22.40C
21:20:25.135 -> Module #13 23.19V Cell72: 3.86V Cell73: 3.87V Cell74: 3.87V Cell75: 3.87V Cell76: 3.87V Cell77: 3.86V Neg Term Temp: 23.42C Pos Term Temp: 22.63C
21:20:25.135 -> Module #14 23.18V Cell78: 3.86V Cell79: 3.87V Cell80: 3.86V Cell81: 3.86V Cell82: 3.86V Cell83: 3.86V Neg Term Temp: 23.21C Pos Term Temp: 22.47C
21:20:25.135 -> CANbus 0.00mA 70% SOC 147000.00mAh
21:20:25.135 -> !!! Series Cells Fault !!!
21:20:25.648 ->
21:20:25.648 ->
21:20:25.648 -> 0
21:20:25.648 -> BMS Status : 1 Ready 0
21:20:25.648 -> Out:0000 Cont:0000 In:0000 Charge Current Limit : 30 A DisCharge Current Limit : 30 A
21:20:25.648 ->
21:20:25.648 ->
21:20:25.648 -> Modules: 14 Cells: 0 Strings: 1 Voltage: 324.490V Avg Cell Voltage: 3.863V Low Cell Voltage: 3.848V High Cell Voltage: 3.866V Delta Voltage: 18mV Avg Temp: 22.577C
21:20:25.648 -> 21:20:25.648 -> Module #1 23.16V Cell0: 3.86V Cell1: 3.86V Cell2: 3.86V Cell3: 3.86V Cell4: 3.86V Cell5: 3.85V Neg Term Temp: 22.07C Pos Term Temp: 21.30C
21:20:25.648 -> Module #2 23.17V Cell6: 3.86V Cell7: 3.86V Cell8: 3.86V Cell9: 3.86V Cell10: 3.86V Cell11: 3.86V Neg Term Temp: 22.69C Pos Term Temp: 21.64C
21:20:25.648 -> Module #3 23.18V Cell12: 3.86V Cell13: 3.86V Cell14: 3.86V Cell15: 3.86V Cell16: 3.86V Cell17: 3.86V Neg Term Temp: 22.53C Pos Term Temp: 21.92C
21:20:25.648 -> Module #4 23.18V Cell18: 3.86V Cell19: 3.86V Cell20: 3.86V Cell21: 3.86V Cell22: 3.86V Cell23: 3.86V Neg Term Temp: 22.62C Pos Term Temp: 22.00C
21:20:25.648 -> Module #5 23.18V Cell24: 3.86V Cell25: 3.86V Cell26: 3.86V Cell27: 3.86V Cell28: 3.86V Cell29: 3.86V Neg Term Temp: 22.67C Pos Term Temp: 22.22C
21:20:25.648 -> Module #6 23.18V Cell30: 3.86V Cell31: 3.86V Cell32: 3.86V Cell33: 3.87V Cell34: 3.86V Cell35: 3.86V Neg Term Temp: 23.13C Pos Term Temp: 22.49C
21:20:25.648 -> Module #7 23.18V Cell36: 3.86V Cell37: 3.86V Cell38: 3.86V Cell39: 3.86V Cell40: 3.86V Cell41: 3.86V Neg Term Temp: 23.61C Pos Term Temp: 22.78C
21:20:25.648 -> Module #8 23.18V Cell42: 3.86V Cell43: 3.86V Cell44: 3.86V Cell45: 3.86V Cell46: 3.86V Cell47: 3.86V Neg Term Temp: 23.09C Pos Term Temp: 22.14C
21:20:25.648 -> Module #9 23.16V Cell48: 3.86V Cell49: 3.86V Cell50: 3.86V Cell51: 3.86V Cell52: 3.86V Cell53: 3.86V Neg Term Temp: 22.82C Pos Term Temp: 22.35C
21:20:25.648 -> Module #10 23.18V Cell54: 3.86V Cell55: 3.86V Cell56: 3.86V Cell57: 3.86V Cell58: 3.86V Cell59: 3.86V Neg Term Temp: 23.29C Pos Term Temp: 22.72C
21:20:25.648 -> Module #11 23.18V Cell60: 3.86V Cell61: 3.86V Cell62: 3.86V Cell63: 3.86V Cell64: 3.86V Cell65: 3.86V Neg Term Temp: 22.94C Pos Term Temp: 22.22C
21:20:25.648 -> Module #12 23.19V Cell66: 3.86V Cell67: 3.87V Cell68: 3.87V Cell69: 3.87V Cell70: 3.87V Cell71: 3.86V Neg Term Temp: 23.04C Pos Term Temp: 22.35C
21:20:25.648 -> Module #13 23.19V Cell72: 3.86V Cell73: 3.87V Cell74: 3.87V Cell75: 3.87V Cell76: 3.87V Cell77: 3.86V Neg Term Temp: 23.36C Pos Term Temp: 22.58C
21:20:25.648 -> Module #14 23.18V Cell78: 3.86V Cell79: 3.87V Cell80: 3.86V Cell81: 3.86V Cell82: 3.86V Cell83: 3.86V Neg Term Temp: 23.17C Pos Term Temp: 22.43C
21:20:25.648 ->
21:20:25.648 -> //////////////////////////////////////// SOC SET ////////////////////////////////////////
21:20:25.648 -> CANbus 0.00mA 70% SOC 147000.00mAh
21:20:26.104 ->
21:20:26.104 -> 0
21:20:26.104 -> BMS Status : 1 Ready 0
21:20:26.104 -> Out:0000 Cont:0000 In:0000 Charge Current Limit : 30 A DisCharge Current Limit : 30 A
21:20:26.104 ->
21:20:26.104 ->
21:20:26.104 -> Modules: 14 Cells: 0 Strings: 1 Voltage: 324.493V Avg Cell Voltage: 3.863V Low Cell Voltage: 3.848V High Cell Voltage: 3.866V Delta Voltage: 18mV Avg Temp: 22.590C
21:20:26.104 ->
21:20:26.104 -> Module #1 23.16V Cell0: 3.86V Cell1: 3.86V Cell2: 3.86V Cell3: 3.86V Cell4: 3.86V Cell5: 3.85V Neg Term Temp: 22.08C Pos Term Temp: 21.30C
21:20:26.104 -> Module #2 23.17V Cell6: 3.86V Cell7: 3.86V Cell8: 3.86V Cell9: 3.86V Cell10: 3.86V Cell11: 3.86V Neg Term Temp: 22.71C Pos Term Temp: 21.66C
21:20:26.104 -> Module #3 23.18V Cell12: 3.86V Cell13: 3.86V Cell14: 3.86V Cell15: 3.86V Cell16: 3.86V Cell17: 3.86V Neg Term Temp: 22.55C Pos Term Temp: 21.94C
21:20:26.104 -> Module #4 23.18V Cell18: 3.86V Cell19: 3.86V Cell20: 3.86V Cell21: 3.87V Cell22: 3.86V Cell23: 3.86V Neg Term Temp: 22.63C Pos Term Temp: 22.02C
21:20:26.104 -> Module #5 23.18V Cell24: 3.86V Cell25: 3.86V Cell26: 3.86V Cell27: 3.86V Cell28: 3.86V Cell29: 3.86V Neg Term Temp: 22.69C Pos Term Temp: 22.24C
21:20:26.104 -> Module #6 23.18V Cell30: 3.86V Cell31: 3.86V Cell32: 3.86V Cell33: 3.87V Cell34: 3.86V Cell35: 3.86V Neg Term Temp: 23.13C Pos Term Temp: 22.50C
21:20:26.104 -> Module #7 23.18V Cell36: 3.86V Cell37: 3.86V Cell38: 3.86V Cell39: 3.86V Cell40: 3.86V Cell41: 3.86V Neg Term Temp: 23.63C Pos Term Temp: 22.79C
21:20:26.104 -> Module #8 23.18V Cell42: 3.86V Cell43: 3.86V Cell44: 3.86V Cell45: 3.86V Cell46: 3.86V Cell47: 3.86V Neg Term Temp: 23.10C Pos Term Temp: 22.15C
21:20:26.104 -> Module #9 23.16V Cell48: 3.86V Cell49: 3.86V Cell50: 3.86V Cell51: 3.86V Cell52: 3.86V Cell53: 3.86V Neg Term Temp: 22.83C Pos Term Temp: 22.37C
21:20:26.104 -> Module #10 23.18V Cell54: 3.86V Cell55: 3.86V Cell56: 3.86V Cell57: 3.86V Cell58: 3.86V Cell59: 3.86V Neg Term Temp: 23.30C Pos Term Temp: 22.73C
21:20:26.104 -> Module #11 23.18V Cell60: 3.86V Cell61: 3.86V Cell62: 3.86V Cell63: 3.86V Cell64: 3.86V Cell65: 3.86V Neg Term Temp: 22.95C Pos Term Temp: 22.23C
21:20:26.104 -> Module #12 23.19V Cell66: 3.86V Cell67: 3.87V Cell68: 3.87V Cell69: 3.87V Cell70: 3.87V Cell71: 3.86V Neg Term Temp: 23.06C Pos Term Temp: 22.36C
21:20:26.104 -> Module #13 23.19V Cell72: 3.86V Cell73: 3.87V Cell74: 3.87V Cell75: 3.87V Cell76: 3.87V Cell77: 3.86V Neg Term Temp: 23.38C Pos Term Temp: 22.60C
21:20:26.104 -> Module #14 23.18V Cell78: 3.86V Cell79: 3.87V Cell80: 3.86V Cell81: 3.86V Cell82: 3.86V Cell83: 3.86V Neg Term Temp: 23.18C Pos Term Temp: 22.44C
21:20:26.104 -> CANbus 0.00mA 70% SOC 147000.00mAh
21:20:26.606 ->
21:20:26.606 -> 0
21:20:26.606 -> BMS Status : 1 Ready 0
21:20:26.606 -> Out:0000 Cont:0000 In:0000 Charge Current Limit : 30 A DisCharge Current Limit : 30 A
21:20:26.606 ->
21:20:26.606 ->
21:20:26.606 -> Modules: 14 Cells: 0 Strings: 1 Voltage: 324.489V Avg Cell Voltage: 3.863V Low Cell Voltage: 3.848V High Cell Voltage: 3.867V Delta Voltage: 19mV Avg Temp: 22.599C
21:20:26.606 ->
21:20:26.606 -> Module #1 23.16V Cell0: 3.86V Cell1: 3.86V Cell2: 3.86V Cell3: 3.86V Cell4: 3.86V Cell5: 3.85V Neg Term Temp: 22.10C Pos Term Temp: 21.31C
21:20:26.606 -> Module #2 23.17V Cell6: 3.86V Cell7: 3.86V Cell8: 3.86V Cell9: 3.86V Cell10: 3.86V Cell11: 3.86V Neg Term Temp: 22.71C Pos Term Temp: 21.66C
21:20:26.606 -> Module #3 23.18V Cell12: 3.86V Cell13: 3.86V Cell14: 3.86V Cell15: 3.86V Cell16: 3.86V Cell17: 3.86V Neg Term Temp: 22.55C Pos Term Temp: 21.95C
21:20:26.606 -> Module #4 23.18V Cell18: 3.86V Cell19: 3.86V Cell20: 3.86V Cell21: 3.86V Cell22: 3.86V Cell23: 3.86V Neg Term Temp: 22.64C Pos Term Temp: 22.03C
21:20:26.606 -> Module #5 23.18V Cell24: 3.86V Cell25: 3.86V Cell26: 3.86V Cell27: 3.86V Cell28: 3.86V Cell29: 3.86V Neg Term Temp: 22.70C Pos Term Temp: 22.25C
21:20:26.606 -> Module #6 23.18V Cell30: 3.86V Cell31: 3.86V Cell32: 3.86V Cell33: 3.87V Cell34: 3.86V Cell35: 3.86V Neg Term Temp: 23.13C Pos Term Temp: 22.51C
21:20:26.606 -> Module #7 23.18V Cell36: 3.86V Cell37: 3.86V Cell38: 3.86V Cell39: 3.86V Cell40: 3.86V Cell41: 3.86V Neg Term Temp: 23.64C Pos Term Temp: 22.80C
21:20:26.606 -> Module #8 23.17V Cell42: 3.86V Cell43: 3.86V Cell44: 3.86V Cell45: 3.86V Cell46: 3.86V Cell47: 3.86V Neg Term Temp: 23.11C Pos Term Temp: 22.16C
21:20:26.606 -> Module #9 23.17V Cell48: 3.86V Cell49: 3.86V Cell50: 3.86V Cell51: 3.86V Cell52: 3.86V Cell53: 3.86V Neg Term Temp: 22.84C Pos Term Temp: 22.38C
21:20:26.606 -> Module #10 23.18V Cell54: 3.86V Cell55: 3.86V Cell56: 3.86V Cell57: 3.86V Cell58: 3.86V Cell59: 3.86V Neg Term Temp: 23.30C Pos Term Temp: 22.74C
21:20:26.606 -> Module #11 23.18V Cell60: 3.86V Cell61: 3.86V Cell62: 3.86V Cell63: 3.86V Cell64: 3.86V Cell65: 3.86V Neg Term Temp: 22.95C Pos Term Temp: 22.24C
21:20:26.606 -> Module #12 23.19V Cell66: 3.86V Cell67: 3.87V Cell68: 3.87V Cell69: 3.87V Cell70: 3.87V Cell71: 3.86V Neg Term Temp: 23.07C Pos Term Temp: 22.37C
21:20:26.606 -> Module #13 23.19V Cell72: 3.86V Cell73: 3.87V Cell74: 3.87V Cell75: 3.87V Cell76: 3.87V Cell77: 3.86V Neg Term Temp: 23.40C Pos Term Temp: 22.61C
21:20:26.606 -> Module #14 23.18V Cell78: 3.86V Cell79: 3.87V Cell80: 3.86V Cell81: 3.87V Cell82: 3.86V Cell83: 3.86V Neg Term Temp: 23.19C Pos Term Temp: 22.44C
21:20:26.606 -> CANbus 0.00mA 70% SOC 147000.00mAh
21:20:27.171 ->
21:20:27.171 -> 0
21:20:27.171 -> BMS Status : 1 Ready 84
21:20:27.171 -> Out:0000 Cont:0000 In:0000 Charge Current Limit : 30 A DisCharge Current Limit : 30 A
21:20:27.171 ->
21:20:27.171 ->
21:20:26.606 ->
Re: Simp BMS
Yes, that would be the only difference between a not turning and a turning motor. The HV current created EMI.
Re: Simp BMS
Hmm. now every time I start the BMS it says Series fault, but then recovers. Powering BMS via USB. Nothing else powered on.
15:00:56.452 -> Starting up!
15:00:56.452 -> SimpBMS V2 Tesla
15:00:56.452 ->
15:00:56.452 -> Reason for last Reset:
15:00:56.452 -> Power-on Reset
15:00:56.452 -> Low-voltage Detect Reset
15:00:56.452 ->
15:00:56.452 -> Started serial interface to BMS.
15:00:58.226 -> Recovery SOC:
15:00:58.226 -> 70
15:00:58.645 ->
15:00:58.645 -> 0
15:00:58.645 -> BMS Status : 1 Ready 0
15:00:58.645 -> Out:0000 Cont:0000 In:0000 Charge Current Limit : 0 A DisCharge Current Limit : 0 A
15:00:58.645 ->
15:00:58.645 ->
15:00:58.645 -> Modules: 14 Cells: 0 Strings: 1 Voltage: 324.469V Avg Cell Voltage: 3.863V Low Cell Voltage: 3.847V High Cell Voltage: 3.867V Delta Voltage: 19mV Avg Temp: 20.080C
15:00:58.645 ->
15:00:58.645 -> Module #1 23.15V Cell0: 3.86V Cell1: 3.86V Cell2: 3.86V Cell3: 3.86V Cell4: 3.86V Cell5: 3.85V Neg Term Temp: 20.92C Pos Term Temp: 20.01C
15:00:58.645 -> Module #2 23.17V Cell6: 3.86V Cell7: 3.86V Cell8: 3.86V Cell9: 3.86V Cell10: 3.86V Cell11: 3.86V Neg Term Temp: 19.27C Pos Term Temp: 18.73C
15:00:58.645 -> Module #3 23.18V Cell12: 3.86V Cell13: 3.86V Cell14: 3.86V Cell15: 3.86V Cell16: 3.86V Cell17: 3.86V Neg Term Temp: 18.97C Pos Term Temp: 18.87C
15:00:58.645 -> Module #4 23.18V Cell18: 3.86V Cell19: 3.86V Cell20: 3.86V Cell21: 3.86V Cell22: 3.86V Cell23: 3.86V Neg Term Temp: 19.14C Pos Term Temp: 18.94C
15:00:58.645 -> Module #5 23.18V Cell24: 3.86V Cell25: 3.86V Cell26: 3.86V Cell27: 3.86V Cell28: 3.86V Cell29: 3.86V Neg Term Temp: 20.00C Pos Term Temp: 19.54C
15:00:58.645 -> Module #6 23.18V Cell30: 3.86V Cell31: 3.86V Cell32: 3.86V Cell33: 3.87V Cell34: 3.86V Cell35: 3.86V Neg Term Temp: 21.70C Pos Term Temp: 21.75C
15:00:58.645 -> Module #7 23.18V Cell36: 3.86V Cell37: 3.86V Cell38: 3.86V Cell39: 3.86V Cell40: 3.86V Cell41: 3.86V Neg Term Temp: 19.65C Pos Term Temp: 19.73C
15:00:58.645 -> Module #8 23.17V Cell42: 3.86V Cell43: 3.86V Cell44: 3.86V Cell45: 3.86V Cell46: 3.86V Cell47: 3.86V Neg Term Temp: 20.30C Pos Term Temp: 20.68C
15:00:58.645 -> Module #9 23.16V Cell48: 3.86V Cell49: 3.86V Cell50: 3.86V Cell51: 3.86V Cell52: 3.86V Cell53: 3.86V Neg Term Temp: 22.42C Pos Term Temp: 21.28C
15:00:58.645 -> Module #10 23.18V Cell54: 3.86V Cell55: 3.86V Cell56: 3.86V Cell57: 3.86V Cell58: 3.86V Cell59: 3.86V Neg Term Temp: 20.29C Pos Term Temp: 19.40C
15:00:58.645 -> Module #11 23.17V Cell60: 3.86V Cell61: 3.86V Cell62: 3.86V Cell63: 3.86V Cell64: 3.86V Cell65: 3.86V Neg Term Temp: 21.22C Pos Term Temp: 20.54C
15:00:58.645 -> Module #12 23.19V Cell66: 3.86V Cell67: 3.87V Cell68: 3.87V Cell69: 3.87V Cell70: 3.87V Cell71: 3.86V Neg Term Temp: 20.63C Pos Term Temp: 20.07C
15:00:58.645 -> Module #13 23.19V Cell72: 3.86V Cell73: 3.87V Cell74: 3.87V Cell75: 3.87V Cell76: 3.86V Cell77: 3.86V Neg Term Temp: 19.37C Pos Term Temp: 19.02C
15:00:58.645 -> Module #14 23.18V Cell78: 3.86V Cell79: 3.87V Cell80: 3.86V Cell81: 3.86V Cell82: 3.86V Cell83: 3.86V Neg Term Temp: 19.78C Pos Term Temp: 20.02C
15:00:58.645 -> CANbus 0.00mA 70% SOC 147000.00mAh
15:00:58.678 -> !!! Series Cells Fault !!!
15:00:59.160 ->
15:00:59.160 ->
15:00:59.160 -> 0
15:00:59.160 -> BMS Status : 1 Ready 0
15:00:59.160 -> Out:0000 Cont:0000 In:0000 Charge Current Limit : 30 A DisCharge Current Limit : 30 A
15:00:59.160 ->
15:00:59.160 ->
15:00:59.160 -> Modules: 14 Cells: 0 Strings: 1 Voltage: 324.461V Avg Cell Voltage: 3.863V Low Cell Voltage: 3.847V High Cell Voltage: 3.866V Delta Voltage: 19mV Avg Temp: 20.022C
15:00:59.160 ->
15:00:59.160 -> Module #1 23.15V Cell0: 3.86V Cell1: 3.86V Cell2: 3.86V Cell3: 3.86V Cell4: 3.86V Cell5: 3.85V Neg Term Temp: 20.87C Pos Term Temp: 19.96C
15:00:59.160 -> Module #2 23.17V Cell6: 3.86V Cell7: 3.86V Cell8: 3.86V Cell9: 3.86V Cell10: 3.86V Cell11: 3.86V Neg Term Temp: 19.20C Pos Term Temp: 18.66C
15:00:59.160 -> Module #3 23.17V Cell12: 3.86V Cell13: 3.86V Cell14: 3.86V Cell15: 3.86V Cell16: 3.86V Cell17: 3.86V Neg Term Temp: 18.93C Pos Term Temp: 18.82C
15:00:59.160 -> Module #4 23.18V Cell18: 3.86V Cell19: 3.86V Cell20: 3.86V Cell21: 3.86V Cell22: 3.86V Cell23: 3.86V Neg Term Temp: 19.08C Pos Term Temp: 18.87C
15:00:59.160 -> Module #5 23.18V Cell24: 3.86V Cell25: 3.86V Cell26: 3.86V Cell27: 3.86V Cell28: 3.86V Cell29: 3.86V Neg Term Temp: 19.93C Pos Term Temp: 19.48C
15:00:59.160 -> Module #6 23.18V Cell30: 3.86V Cell31: 3.86V Cell32: 3.86V Cell33: 3.87V Cell34: 3.86V Cell35: 3.86V Neg Term Temp: 21.65C Pos Term Temp: 21.70C
15:00:59.160 -> Module #7 23.18V Cell36: 3.86V Cell37: 3.86V Cell38: 3.86V Cell39: 3.86V Cell40: 3.86V Cell41: 3.86V Neg Term Temp: 19.59C Pos Term Temp: 19.68C
15:00:59.160 -> Module #8 23.17V Cell42: 3.86V Cell43: 3.86V Cell44: 3.86V Cell45: 3.86V Cell46: 3.86V Cell47: 3.86V Neg Term Temp: 20.24C Pos Term Temp: 20.62C
15:00:59.160 -> Module #9 23.16V Cell48: 3.86V Cell49: 3.86V Cell50: 3.86V Cell51: 3.86V Cell52: 3.86V Cell53: 3.86V Neg Term Temp: 22.36C Pos Term Temp: 21.22C
15:00:59.160 -> Module #10 23.18V Cell54: 3.86V Cell55: 3.86V Cell56: 3.86V Cell57: 3.86V Cell58: 3.86V Cell59: 3.86V Neg Term Temp: 20.23C Pos Term Temp: 19.34C
15:00:59.160 -> Module #11 23.18V Cell60: 3.86V Cell61: 3.86V Cell62: 3.86V Cell63: 3.86V Cell64: 3.86V Cell65: 3.86V Neg Term Temp: 21.16C Pos Term Temp: 20.48C
15:00:59.160 -> Module #12 23.19V Cell66: 3.86V Cell67: 3.87V Cell68: 3.87V Cell69: 3.87V Cell70: 3.86V Cell71: 3.86V Neg Term Temp: 20.57C Pos Term Temp: 20.01C
15:00:59.160 -> Module #13 23.19V Cell72: 3.86V Cell73: 3.87V Cell74: 3.87V Cell75: 3.87V Cell76: 3.86V Cell77: 3.86V Neg Term Temp: 19.32C Pos Term Temp: 18.97C
15:00:59.160 -> Module #14 23.18V Cell78: 3.86V Cell79: 3.87V Cell80: 3.86V Cell81: 3.87V Cell82: 3.86V Cell83: 3.86V Neg Term Temp: 19.73C Pos Term Temp: 19.97C
15:00:59.160 ->
15:00:59.160 -> //////////////////////////////////////// SOC SET ////////////////////////////////////////
15:00:59.160 -> CANbus 0.00mA 70% SOC 147000.00mAh
15:00:59.672 ->
15:00:59.672 -> 0
15:00:59.672 -> BMS Status : 1 Ready 0
15:00:59.672 -> Out:0000 Cont:0000 In:0000 Charge Current Limit : 30 A DisCharge Current Limit : 30 A
15:00:59.672 ->
15:00:59.672 ->
15:00:59.672 -> Modules: 14 Cells: 0 Strings: 1 Voltage: 324.464V Avg Cell Voltage: 3.863V Low Cell Voltage: 3.847V High Cell Voltage: 3.866V Delta Voltage: 19mV Avg Temp: 20.034C
15:00:59.672 ->
15:00:59.672 -> Module #1 23.15V Cell0: 3.86V Cell1: 3.86V Cell2: 3.86V Cell3: 3.86V Cell4: 3.86V Cell5: 3.85V Neg Term Temp: 20.88C Pos Term Temp: 19.96C
15:00:59.672 -> Module #2 23.17V Cell6: 3.86V Cell7: 3.86V Cell8: 3.86V Cell9: 3.86V Cell10: 3.86V Cell11: 3.86V Neg Term Temp: 19.22C Pos Term Temp: 18.68C
15:00:59.672 -> Module #3 23.17V Cell12: 3.86V Cell13: 3.86V Cell14: 3.86V Cell15: 3.86V Cell16: 3.86V Cell17: 3.86V Neg Term Temp: 18.92C Pos Term Temp: 18.82C
15:00:59.672 -> Module #4 23.18V Cell18: 3.86V Cell19: 3.86V Cell20: 3.86V Cell21: 3.86V Cell22: 3.86V Cell23: 3.86V Neg Term Temp: 19.10C Pos Term Temp: 18.89C
15:00:59.672 -> Module #5 23.18V Cell24: 3.86V Cell25: 3.86V Cell26: 3.86V Cell27: 3.86V Cell28: 3.86V Cell29: 3.86V Neg Term Temp: 19.95C Pos Term Temp: 19.49C
15:00:59.672 -> Module #6 23.18V Cell30: 3.86V Cell31: 3.86V Cell32: 3.86V Cell33: 3.87V Cell34: 3.86V Cell35: 3.86V Neg Term Temp: 21.66C Pos Term Temp: 21.71C
15:00:59.672 -> Module #7 23.18V Cell36: 3.86V Cell37: 3.86V Cell38: 3.86V Cell39: 3.86V Cell40: 3.86V Cell41: 3.86V Neg Term Temp: 19.60C Pos Term Temp: 19.69C
15:00:59.672 -> Module #8 23.17V Cell42: 3.86V Cell43: 3.86V Cell44: 3.86V Cell45: 3.86V Cell46: 3.86V Cell47: 3.86V Neg Term Temp: 20.24C Pos Term Temp: 20.63C
15:00:59.672 -> Module #9 23.17V Cell48: 3.86V Cell49: 3.86V Cell50: 3.86V Cell51: 3.86V Cell52: 3.86V Cell53: 3.86V Neg Term Temp: 22.38C Pos Term Temp: 21.24C
15:00:59.672 -> Module #10 23.18V Cell54: 3.86V Cell55: 3.86V Cell56: 3.86V Cell57: 3.86V Cell58: 3.86V Cell59: 3.86V Neg Term Temp: 20.24C Pos Term Temp: 19.35C
15:00:59.672 -> Module #11 23.17V Cell60: 3.86V Cell61: 3.86V Cell62: 3.86V Cell63: 3.86V Cell64: 3.86V Cell65: 3.86V Neg Term Temp: 21.18C Pos Term Temp: 20.49C
15:00:59.672 -> Module #12 23.19V Cell66: 3.86V Cell67: 3.87V Cell68: 3.87V Cell69: 3.87V Cell70: 3.86V Cell71: 3.86V Neg Term Temp: 20.59C Pos Term Temp: 20.02C
15:00:59.672 -> Module #13 23.19V Cell72: 3.86V Cell73: 3.86V Cell74: 3.87V Cell75: 3.87V Cell76: 3.86V Cell77: 3.86V Neg Term Temp: 19.32C Pos Term Temp: 18.97C
15:00:59.672 -> Module #14 23.18V Cell78: 3.86V Cell79: 3.87V Cell80: 3.86V Cell81: 3.86V Cell82: 3.86V Cell83: 3.86V Neg Term Temp: 19.75C Pos Term Temp: 19.98C
15:00:59.672 -> CANbus 0.00mA 70% SOC 147000.00mAh
15:01:00.181 ->
15:01:00.181 -> 0
15:01:00.181 -> BMS Status : 1 Ready 0
15:01:00.181 -> Out:0000 Cont:0000 In:0000 Charge Current Limit : 30 A DisCharge Current Limit : 30 A
15:01:00.181 ->
15:01:00.181 ->
15:01:00.181 -> Modules: 14 Cells: 0 Strings: 1 Voltage: 324.459V Avg Cell Voltage: 3.863V Low Cell Voltage: 3.847V High Cell Voltage: 3.866V Delta Voltage: 19mV Avg Temp: 20.040C
15:01:00.181 ->
15:01:00.181 -> Module #1 23.15V Cell0: 3.86V Cell1: 3.86V Cell2: 3.86V Cell3: 3.86V Cell4: 3.86V Cell5: 3.85V Neg Term Temp: 20.89C Pos Term Temp: 19.97C
15:01:00.181 -> Module #2 23.17V Cell6: 3.86V Cell7: 3.86V Cell8: 3.86V Cell9: 3.86V Cell10: 3.86V Cell11: 3.86V Neg Term Temp: 19.23C Pos Term Temp: 18.69C
15:01:00.181 -> Module #3 23.17V Cell12: 3.86V Cell13: 3.86V Cell14: 3.86V Cell15: 3.86V Cell16: 3.86V Cell17: 3.86V Neg Term Temp: 18.93C Pos Term Temp: 18.82C
15:01:00.181 -> Module #4 23.18V Cell18: 3.86V Cell19: 3.86V Cell20: 3.86V Cell21: 3.86V Cell22: 3.86V Cell23: 3.86V Neg Term Temp: 19.11C Pos Term Temp: 18.91C
15:01:00.181 -> Module #5 23.18V Cell24: 3.86V Cell25: 3.86V Cell26: 3.86V Cell27: 3.86V Cell28: 3.86V Cell29: 3.86V Neg Term Temp: 19.95C Pos Term Temp: 19.49C
15:01:00.181 -> Module #6 23.18V Cell30: 3.86V Cell31: 3.86V Cell32: 3.86V Cell33: 3.87V Cell34: 3.86V Cell35: 3.86V Neg Term Temp: 21.66C Pos Term Temp: 21.72C
15:01:00.181 -> Module #7 23.18V Cell36: 3.86V Cell37: 3.86V Cell38: 3.86V Cell39: 3.86V Cell40: 3.86V Cell41: 3.86V Neg Term Temp: 19.61C Pos Term Temp: 19.70C
15:01:00.181 -> Module #8 23.17V Cell42: 3.86V Cell43: 3.86V Cell44: 3.86V Cell45: 3.86V Cell46: 3.86V Cell47: 3.86V Neg Term Temp: 20.24C Pos Term Temp: 20.64C
15:01:00.181 -> Module #9 23.16V Cell48: 3.86V Cell49: 3.86V Cell50: 3.86V Cell51: 3.86V Cell52: 3.86V Cell53: 3.86V Neg Term Temp: 22.38C Pos Term Temp: 21.25C
15:01:00.181 -> Module #10 23.18V Cell54: 3.86V Cell55: 3.86V Cell56: 3.86V Cell57: 3.86V Cell58: 3.86V Cell59: 3.86V Neg Term Temp: 20.24C Pos Term Temp: 19.36C
15:01:00.181 -> Module #11 23.17V Cell60: 3.86V Cell61: 3.86V Cell62: 3.86V Cell63: 3.86V Cell64: 3.86V Cell65: 3.86V Neg Term Temp: 21.18C Pos Term Temp: 20.50C
15:01:00.181 -> Module #12 23.19V Cell66: 3.86V Cell67: 3.87V Cell68: 3.87V Cell69: 3.87V Cell70: 3.86V Cell71: 3.86V Neg Term Temp: 20.60C Pos Term Temp: 20.04C
15:01:00.181 -> Module #13 23.19V Cell72: 3.86V Cell73: 3.86V Cell74: 3.87V Cell75: 3.87V Cell76: 3.87V Cell77: 3.86V Neg Term Temp: 19.33C Pos Term Temp: 18.98C
15:01:00.181 -> Module #14 23.18V Cell78: 3.86V Cell79: 3.87V Cell80: 3.86V Cell81: 3.86V Cell82: 3.86V Cell83: 3.86V Neg Term Temp: 19.74C Pos Term Temp: 19.98C
15:01:00.181 -> CANbus 0.00mA 70% SOC 147000.00mAh
15:01:00.646 ->
15:01:00.646 -> 0
Re: Simp BMS
Impressive, what happens when you power the board via 12V? as your usb might be power limited and you are running 14 modules with not short cable runs.
Also is the code unmodified?
