Tesla Model 3 Battery Hacking
Been thanked: 1117 times
Setting up a thread to document the reverse engineering of the Model 3 battery. The specimen is from a European 2019 car with just over 20k km on the clock. We have the full guts of the battery minus the casing. First task will be putting it back together so we can begin discovering how the bms communicates with the cell modules. This will also provide a way to get some much needed info on the PCS communications with the hv controller.
Edit : 01/08/20 : MCU used on the HVC is : https://www.nxp.com/part/SPC5746CSK1AMKU6#/
11/10/20: New breakout board for the "batman" chip available as a kit from the webshop but DOES NOT INCLUDE BATMAN CHIP!
https://www.evbmw.com/index.php/evbmw-w ... bms-batman
Has thanked: 328 times
Been thanked: 847 times
Re: Tesla Model 3 Battery Hacking
The battery modules communicate via a variant of the ISO-SPI from LTC.
I have struggled myself trying to get it to work with the available dev kits from LTC, had no real luck getting it working.
Thanks Tom. Should be an interesting adventure:)
I would say it be of great benefit if you pull it off. Wish I could help but almost started pulling my hair out after 8+ hours of trying to get communications.
Kevin Sharpe
Been thanked: 10 times
Post by Kevin Sharpe »
Kevin Sharpe
tom91 wrote: Fri Feb 28, 2020 5:21 pm I have struggled myself trying to get it to work with the available dev kits from LTC, had no real luck getting it working.
Is this what you were using Tom?
https://www.analog.com/en/design-center ... b-overview
Kevin Sharpe wrote: Fri Feb 28, 2020 8:47 pm
DCA2617A with an LTC6820 on it. I have found some others who tried the same as myself and just found it too much of a struggle to get working.
I would almost think Tesla has taken the ISO-SPI and gave it their own spin, like they done with the Model S battery slaves.
Kevin Sharpe
Battery module 3D CAD models 8-)
viewtopic.php?f=10&t=123#p3644
Some info on this thread :
https://www.diyelectriccar.com/forums/s ... 99509.html
Of course the github rerpo is now empty. Guy must have retired to Lanzarote after selling the ip.
and then we get this : https://teslaownersonline.com/threads/d ... ost-269950
Oh well, let's see what a nice new Keysight deep memory scope makes of this.
This little board may prove to be a way in :
https://www.maleetronic.com/boardsproje ... pi-module/
JaniK
Has thanked: 101 times
Been thanked: 15 times
Post by JaniK »
The latest EVTV video explains how they managed to query the individual cell voltages from the packs.
Gooood stuff.
JaniK wrote: Mon Mar 02, 2020 7:10 pm The latest EVTV video explains how they managed to query the individual cell voltages from the packs.
Gooood stuff.
Where is that explained?
JaniK
Post by JaniK »
Quickly go to exactly 27minutes and play it forward for 90seconds.
"Identified by ID type request"
"UDS request over CAN to the high voltage controller." They were able to retrieve individual cell data.
Little longer on video:
"Time between these messages to get the cell data is 3ms"
They wrote a program to do that. I have no idea how to replicate that, but that is the principle of how it works.
Hope this helps.
muehlpower
Been thanked: 186 times
Post by muehlpower »
I have a complete Model3 battery in US version that I want to use for my project and an additional EU charger. If that can help somehow.
Thanks will be great to compare notes. My first plan is to get the pcs (charger and dcdc) running in the E46 touring then go at the weird iso-spi comms between the battery modules and the hv controller.
Kevin Sharpe
Let's see what this baby makes of Elon's weird bms comms ...
cloudy
Been thanked: 7 times
Post by cloudy »
A little overkill perhaps?! That's a rather nice (and expensive) scope! : :D
Bentto
Post by Bentto »
WTF that's a serious badboy.
Only the best for Mr.Musk:)
clanger9
Post by clanger9 »
Crikey, where did you steal acquire that from??
Let's see if we can figure out what Batbrain and the Boy blunder are at.......
Kevin Sharpe
clanger9 wrote: Thu Mar 26, 2020 8:05 pm Crikey, where did you steal acquire that from??
https://twitter.com/EvBmw/status/124319 ... 47526?s=20
Datasheet for the isolation transformer used on the bms comms.
XFBMC29DNC-BA09-A.pdf
(51.25 KiB) Downloaded 1196 times
