New member from the Netherlands here
My project:
The recent period I've been searching for conversion solutions, most of the solutions keep using the original gearbox of the vehicle, I prefer not to use this. In my search I found the Toyota/Lexus MGR drive via this forum, the form factor and potential power output matches my project quit well. Normally the car weighs approx. 650 kg. My goal is to build a conversion that is capable of doing 110-120 kph with a range of 100 km.
Regarding the MGR drive unit; I prefer to use "off the shelf" parts to do the conversion. So, my idea was to rewind the MGR motor (inspired by the project Ustas is doing) to run on 108-144 Volts @ 400-500 amp (peak) and use a Curtis (or equivalent) motor controller to run it. And that is basically where my plans are. For the next step I need to find some answers, I tried to answer them for myself but I sort of got lost
- Curtis controllers can work with a sin/cos sensor input, see image below. From what I've seen in various photo's, the MGR resolver has 2 sensor revolutions (based on the shape of the resolver) per mechanical revolution while the Curtis controller seems to need only 1 sensor revolution per mechanical revolution. My question on this matter: is it possible to modify the MGR's resolver to be able to use a Curtis controller?
- I tried to find information on rewinding the motor to my needs, and found out that I don't really know where to start. If someone could point me in the right direction (or even better: is able to make the calculation for me) I will try to figure it all out.
At this moment I have no parts to start build yet, when I'm confident that I'm able to do a proper conversion for an acceptable amount of money I will start the build.
Thanks for reading and hopefully you can give me some useful tips and tricks!
Cheers
