SINCOFS SETTINGS blocked through PRECHARGE warning
DIETZENBACH
Has thanked: 22 times
Post by DIETZENBACH »
When trying to set SINCOFS settings , I am receiving in the Plot-Window the message PRECHARGE,and the motor motion get blocked.
At inital start there is no Precharge message and the motor is slowly turning in jittering mode. When halted an restarted again ,the Precharge message pop up and the motor rest silent.
What kind of resistor or device should I use to elminate the precharge and let the motor run.
manny
Has thanked: 59 times
Been thanked: 159 times
Re: SINCOFS SETTINGS blocked through PRECHARGE warning
Post by manny »
The error is because your voltage is below (udcsw) setting. So the precharge is not "finished"
If you are using a power supply for testing you can set the (udcsw) to 0. If you are using a battery and contactors set is to a reasonable value.
  • PSA battery (50kWh)
  • Zombie VCU
DIETZENBACH
Hi Manny,
Thanks for the advice.I am setting always the udcsw to the proper voltage I`m using-battery and power supply. Will retry it again
manny
Post by manny »
Do you have UDC in the web interface?
  • Zombie VCU
DIETZENBACH
some test performed as follows :
1 test with brake and start reles/contactor off:
UDC = 0 or 200V
manual run
lasterr-none,
status -none
different manualID -values set,but motor do not move.
2.Test -- Inverter HALTED
angel graf ON
motor cliks but no run
opmode - =RUN
3. Test INVERTER ON
no angel graf available
no more motor clicks
opmode -= run
UDCSW - =0 or 200v
manual ID different -values set,but motor do not move.
lasterr -none
status -none
manny
Post by manny »
What motor and inverter are you using?
  • Zombie VCU
DIETZENBACH
SEIKOSH
SEIKOSHA  motor
SEIKOSHA motor
MOTORA japanes motor and PRIUS GEN 2 inverter.
manny
Post by manny »
When the inverter is in Run mode. With Id and Iq 0A. Can you graf the motor angle while spinning the motor by hand?
Can you post the output from http://192.168.4.1/cmd?cmd=json on the inverter
  • Zombie VCU
DIETZENBACH
The graf angle in run mode is going by itself.turning the motor by hand is not changing the graf pattern.
Here is the JSON file for refference.{
"curkp": {"unit":"","value":32.00,"isparam":true,"minimum":0.00,"maximum":20000.00,"default":32.00,"category":"Motor","i":0},
"curki": {"unit":"","value":20000.00,"isparam":true,"minimum":0.00,"maximum":100000.00,"default":20000.00,"category":"Motor","i":1},
"curkifrqgain": {"unit":"dig/Hz","value":50.00,"isparam":true,"minimum":0.00,"maximum":1000.00,"default":50.00,"category":"Motor","i":2},
"fwkp": {"unit":"","value":-100.00,"isparam":true,"minimum":-10000.00,"maximum":0.00,"default":-100.00,"category":"Motor","i":3},
"dmargin": {"unit":"Hz","value":-2000.00,"isparam":true,"minimum":-10000.00,"maximum":0.00,"default":-2000.00,"category":"Motor","i":4},
"syncofs": {"unit":"dig","value":0.00,"isparam":true,"minimum":0.00,"maximum":65535.00,"default":0.00,"category":"Motor","i":5},
"polepairs": {"unit":"","value":4.00,"isparam":true,"minimum":1.00,"maximum":16.00,"default":2.00,"category":"Motor","i":6},
"respolepairs": {"unit":"","value":2.00,"isparam":true,"minimum":1.00,"maximum":16.00,"default":1.00,"category":"Motor","i":7},
"encmode": {"unit":"0=Single, 1=AB, 2=ABZ, 3=SPI, 4=Resolver, 5=SinCos","value":4.00,"isparam":true,"minimum":0.00,"maximum":5.00,"default":0.00,"category":"Motor","i":8},
"fmax": {"unit":"Hz","value":200.00,"isparam":true,"minimum":21.00,"maximum":1000.00,"default":200.00,"category":"Motor","i":9},
"numimp": {"unit":"ppr","value":64.00,"isparam":true,"minimum":8.00,"maximum":8192.00,"default":60.00,"category":"Motor","i":10},
"dirchrpm": {"unit":"rpm","value":100.00,"isparam":true,"minimum":0.00,"maximum":20000.00,"default":100.00,"category":"Motor","i":11},
"dirmode": {"unit":"0=Button, 1=Switch, 2=ButtonReversed, 3=SwitchReversed, 4=DefaultForward","value":4.00,"isparam":true,"minimum":0.00,"maximum":4.00,"default":1.00,"category":"Motor","i":12},
"snsm": {"unit":"12=KTY83-110, 13=KTY84-130, 14=Leaf, 15=KTY81-110, 16=Toyota","value":13.00,"isparam":true,"minimum":12.00,"maximum":16.00,"default":12.00,"category":"Motor","i":13},
"pwmfrq": {"unit":"0=17.6kHz, 1=8.8kHz, 2=4.4KHz","value":2.00,"isparam":true,"minimum":0.00,"maximum":2.00,"default":1.00,"category":"Inverter","i":14},
"il1gain": {"unit":"dig/A","value":3.18,"isparam":true,"minimum":-100.00,"maximum":100.00,"default":4.68,"category":"Inverter","i":18},
"il2gain": {"unit":"dig/A","value":3.18,"isparam":true,"minimum":-100.00,"maximum":100.00,"default":4.68,"category":"Inverter","i":19},
"udcgain": {"unit":"dig/V","value":3.78,"isparam":true,"minimum":0.00,"maximum":4095.00,"default":6.15,"category":"Inverter","i":20},
"udcofs": {"unit":"dig","value":327.00,"isparam":true,"minimum":0.00,"maximum":4095.00,"default":0.00,"category":"Inverter","i":21},
"udclim": {"unit":"V","value":540.00,"isparam":true,"minimum":0.00,"maximum":1000.00,"default":540.00,"category":"Inverter","i":22},
"snshs": {"unit":"0=JCurve, 1=Semikron, 2=MBB600, 3=KTY81, 4=PT1000, 5=NTCK45_2k2, 6=Leaf","value":0.00,"isparam":true,"minimum":0.00,"maximum":6.00,"default":0.00,"category":"Inverter","i":23},
"pinswap": {"unit":"0=None, 1=Currents12, 2=SinCos, 4=PWMOutput13, 8=PWMOutput23","value":4.00,"isparam":true,"minimum":0.00,"maximum":15.00,"default":0.00,"category":"Inverter","i":24},
"bmslimhigh": {"unit":"%","value":50.00,"isparam":true,"minimum":0.00,"maximum":100.00,"default":50.00,"category":"Derating","i":25},
"bmslimlow": {"unit":"%","value":-1.00,"isparam":true,"minimum":-100.00,"maximum":0.00,"default":-1.00,"category":"Derating","i":26},
"udcmin": {"unit":"V","value":45.00,"isparam":true,"minimum":0.00,"maximum":1000.00,"default":450.00,"category":"Derating","i":27},
"udcmax": {"unit":"V","value":520.00,"isparam":true,"minimum":0.00,"maximum":1000.00,"default":520.00,"category":"Derating","i":28},
"idcmax": {"unit":"A","value":5000.00,"isparam":true,"minimum":0.00,"maximum":5000.00,"default":5000.00,"category":"Derating","i":29},
"idcmin": {"unit":"A","value":-5000.00,"isparam":true,"minimum":-5000.00,"maximum":0.00,"default":-5000.00,"category":"Derating","i":30},
"tmphsmax": {"unit":"°C","value":150.00,"isparam":true,"minimum":50.00,"maximum":150.00,"default":85.00,"category":"Derating","i":31},
"tmpmmax": {"unit":"°C","value":300.00,"isparam":true,"minimum":70.00,"maximum":300.00,"default":300.00,"category":"Derating","i":32},
"throtmax": {"unit":"%","value":100.00,"isparam":true,"minimum":0.00,"maximum":100.00,"default":100.00,"category":"Derating","i":33},
"throtmin": {"unit":"%","value":-100.00,"isparam":true,"minimum":-100.00,"maximum":0.00,"default":-100.00,"category":"Derating","i":34},
"chargemode": {"unit":"0=Off, 3=Boost, 4=Buck","value":0.00,"isparam":true,"minimum":0.00,"maximum":4.00,"default":0.00,"category":"Charger","i":35},
"chargecur": {"unit":"A","value":0.00,"isparam":true,"minimum":0.00,"maximum":50.00,"default":0.00,"category":"Charger","i":36},
"chargekp": {"unit":"dig","value":80.00,"isparam":true,"minimum":0.00,"maximum":100.00,"default":80.00,"category":"Charger","i":37},
"chargeki": {"unit":"dig","value":10.00,"isparam":true,"minimum":0.00,"maximum":100.00,"default":10.00,"category":"Charger","i":38},
"chargeflt": {"unit":"dig","value":8.00,"isparam":true,"minimum":0.00,"maximum":10.00,"default":8.00,"category":"Charger","i":39},
"chargepwmin": {"unit":"%","value":0.00,"isparam":true,"minimum":0.00,"maximum":99.00,"default":0.00,"category":"Charger","i":40},
"chargepwmax": {"unit":"%","value":90.00,"isparam":true,"minimum":0.00,"maximum":99.00,"default":90.00,"category":"Charger","i":41},
"potmin": {"unit":"dig","value":0.00,"isparam":true,"minimum":0.00,"maximum":4095.00,"default":0.00,"category":"Throttle","i":42},
"potmax": {"unit":"dig","value":4095.00,"isparam":true,"minimum":0.00,"maximum":4095.00,"default":4095.00,"category":"Throttle","i":43},
"pot2min": {"unit":"dig","value":4095.00,"isparam":true,"minimum":0.00,"maximum":4095.00,"default":4095.00,"category":"Throttle","i":44},
"pot2max": {"unit":"dig","value":4095.00,"isparam":true,"minimum":0.00,"maximum":4095.00,"default":4095.00,"category":"Throttle","i":45},
"potmode": {"unit":"0=SingleRegen, 1=DualChannel, 2=CAN","value":0.00,"isparam":true,"minimum":0.00,"maximum":2.00,"default":0.00,"category":"Throttle","i":46},
"throtramp": {"unit":"%/10ms","value":100.00,"isparam":true,"minimum":0.09,"maximum":100.00,"default":100.00,"category":"Throttle","i":47},
"throtramprpm": {"unit":"rpm","value":20000.00,"isparam":true,"minimum":0.00,"maximum":20000.00,"default":20000.00,"category":"Throttle","i":48},
"throtcur": {"unit":"A/%","value":1.00,"isparam":true,"minimum":0.00,"maximum":10.00,"default":1.00,"category":"Throttle","i":49},
"brknompedal": {"unit":"%","value":-50.00,"isparam":true,"minimum":-100.00,"maximum":0.00,"default":-50.00,"category":"Regen","i":50},
"regenramp": {"unit":"%/10ms","value":100.00,"isparam":true,"minimum":0.09,"maximum":100.00,"default":100.00,"category":"Regen","i":51},
"brknom": {"unit":"%","value":30.00,"isparam":true,"minimum":0.00,"maximum":100.00,"default":30.00,"category":"Regen","i":52},
"brkmax": {"unit":"%","value":-30.00,"isparam":true,"minimum":-100.00,"maximum":0.00,"default":-30.00,"category":"Regen","i":53},
"brkcruise": {"unit":"%","value":-30.00,"isparam":true,"minimum":-100.00,"maximum":0.00,"default":-30.00,"category":"Regen","i":54},
"brkrampstr": {"unit":"Hz","value":10.00,"isparam":true,"minimum":0.00,"maximum":400.00,"default":10.00,"category":"Regen","i":55},
"brkout": {"unit":"%","value":-50.00,"isparam":true,"minimum":-100.00,"maximum":-1.00,"default":-50.00,"category":"Regen","i":56},
"idlespeed": {"unit":"rpm","value":-100.00,"isparam":true,"minimum":-100.00,"maximum":10000.00,"default":-100.00,"category":"Automation","i":57},
"idlethrotlim": {"unit":"%","value":50.00,"isparam":true,"minimum":0.00,"maximum":100.00,"default":50.00,"category":"Automation","i":58},
"idlemode": {"unit":"0=always, 1=nobrake, 2=cruise, 3=off","value":0.00,"isparam":true,"minimum":0.00,"maximum":3.00,"default":0.00,"category":"Automation","i":59},
"speedkp": {"unit":"","value":0.25,"isparam":true,"minimum":0.00,"maximum":100.00,"default":0.25,"category":"Automation","i":60},
"speedflt": {"unit":"","value":5.00,"isparam":true,"minimum":0.00,"maximum":16.00,"default":5.00,"category":"Automation","i":61},
"cruisemode": {"unit":"0=Button, 1=Switch, 2=CAN","value":0.00,"isparam":true,"minimum":0.00,"maximum":2.00,"default":0.00,"category":"Automation","i":62},
"udcsw": {"unit":"V","value":24.00,"isparam":true,"minimum":0.00,"maximum":1000.00,"default":330.00,"category":"Contactor Control","i":63},
"udcswbuck": {"unit":"V","value":540.00,"isparam":true,"minimum":0.00,"maximum":1000.00,"default":540.00,"category":"Contactor Control","i":64},
"tripmode": {"unit":"0=AllOff, 1=DcSwOn, 2=PrechargeOn, 3=AutoResume","value":0.00,"isparam":true,"minimum":0.00,"maximum":3.00,"default":0.00,"category":"Contactor Control","i":65},
"pwmfunc": {"unit":"0=tmpm, 1=tmphs, 2=speed, 3=speedfrq","value":0.00,"isparam":true,"minimum":0.00,"maximum":3.00,"default":0.00,"category":"Aux PWM","i":66},
"pwmgain": {"unit":"","value":100.00,"isparam":true,"minimum":-100000.00,"maximum":100000.00,"default":100.00,"category":"Aux PWM","i":67},
"pwmofs": {"unit":"dig","value":0.00,"isparam":true,"minimum":-65535.00,"maximum":65535.00,"default":0.00,"category":"Aux PWM","i":68},
"canspeed": {"unit":"0=250k, 1=500k, 2=800k, 3=1M","value":1.00,"isparam":true,"minimum":0.00,"maximum":3.00,"default":1.00,"category":"Communication","i":69},
"canperiod": {"unit":"0=100ms, 1=10ms","value":0.00,"isparam":true,"minimum":0.00,"maximum":1.00,"default":0.00,"category":"Communication","i":70},
"manualiq": {"unit":"A","value":0.00,"isparam":true,"minimum":-400.00,"maximum":400.00,"default":0.00,"category":"Testing","i":71},
"manualid": {"unit":"A","value":0.00,"isparam":true,"minimum":-400.00,"maximum":400.00,"default":0.00,"category":"Testing","i":72},
"version": {"unit":"4=4.97.R-foc","value":4.00,"isparam":false},
"hwver": {"unit":"0=Rev1, 1=Rev2, 2=Rev3, 3=Tesla, 4=TeslaM3, 5=BluePill, 6=Prius, 7=PriusMG1","value":6.00,"isparam":false},
"opmode": {"unit":"0=Off, 1=Run, 2=ManualRun, 3=Boost, 4=Buck, 5=Sine, 6=AcHeat","value":0.00,"isparam":false},
"lasterr": {"unit":"0=NONE, 1=OVERCURRENT, 2=THROTTLE1, 3=THROTTLE2, 4=CANTIMEOUT, 5=EMCYSTOP, 6=MPROT, 7=DESAT, 8=OVERVOLTAGE, 9=ENCODER, 10=PRECHARGE, 11=TMPHSMAX, 12=CURRENTLIMIT, 13=PWMSTUCK, 14=HICUROFS1, 15=HICUROFS2, 16=HIRESOFS, 17=LORESAMP, 18=TMPMMAX,","value":10.00,"isparam":false},
"status": {"unit":"0=None, 1=UdcLow, 2=UdcHigh, 4=UdcBelowUdcSw, 8=UdcLim, 16=EmcyStop, 32=MProt, 64=PotPressed, 128=TmpHs, 256=WaitStart","value":4.00,"isparam":false},
"udc": {"unit":"V","value":-2.37,"isparam":false},
"idc": {"unit":"A","value":0.00,"isparam":false},
"il1": {"unit":"A","value":0.00,"isparam":false},
"il2": {"unit":"A","value":0.00,"isparam":false},
"id": {"unit":"A","value":0.00,"isparam":false},
"iq": {"unit":"A","value":0.00,"isparam":false},
"ud": {"unit":"dig","value":0.00,"isparam":false},
"uq": {"unit":"dig","value":0.00,"isparam":false},
"heatcur": {"unit":"A","value":0.00,"isparam":false},
"fstat": {"unit":"Hz","value":0.00,"isparam":false},
"speed": {"unit":"rpm","value":0.00,"isparam":false},
"cruisespeed": {"unit":"rpm","value":-1.00,"isparam":false},
"turns": {"unit":"","value":0.00,"isparam":false},
"amp": {"unit":"dig","value":0.00,"isparam":false},
"angle": {"unit":"°","value":0.00,"isparam":false},
"pot": {"unit":"dig","value":1069.00,"isparam":false},
"pot2": {"unit":"dig","value":39.00,"isparam":false},
"potnom": {"unit":"%","value":0.00,"isparam":false},
"dir": {"unit":"-1=Reverse, 0=Neutral, 1=Forward","value":1.00,"isparam":false},
"tmphs": {"unit":"°C","value":31.53,"isparam":false},
"tmpm": {"unit":"°C","value":300.00,"isparam":false},
"uaux": {"unit":"V","value":12.15,"isparam":false},
"pwmio": {"unit":"","value":40960.00,"isparam":false},
"canio": {"unit":"1=Cruise, 2=Start, 4=Brake, 8=Fwd, 16=Rev, 32=Bms","value":0.00,"isparam":false},
"din_cruise": {"unit":"0=Off, 1=On, 2=na","value":0.00,"isparam":false},
"din_start": {"unit":"0=Off, 1=On, 2=na","value":1.00,"isparam":false},
"din_brake": {"unit":"0=Off, 1=On, 2=na","value":0.00,"isparam":false},
"din_mprot": {"unit":"0=Error, 1=Ok, 2=na","value":1.00,"isparam":false},
"din_forward": {"unit":"0=Off, 1=On, 2=na","value":0.00,"isparam":false},
"din_reverse": {"unit":"0=Off, 1=On, 2=na","value":0.00,"isparam":false},
"din_emcystop": {"unit":"0=Error, 1=Ok, 2=na","value":1.00,"isparam":false},
"din_ocur": {"unit":"0=Error, 1=Ok, 2=na","value":1.00,"isparam":false},
"din_desat": {"unit":"0=Error, 1=Ok, 2=na","value":1.00,"isparam":false},
"din_bms": {"unit":"0=Off, 1=On, 2=na","value":0.00,"isparam":false},
"cpuload": {"unit":"%","value":0.00,"isparam":false}
manny
Post by manny »
if the angle graf is not responding to the motor rotating there is something wrong with the wiring of the resolver.
https://openinverter.org/wiki/Using_FOC_Software
  • Zombie VCU
DIETZENBACH
I run the motor successfuly in previous tests,and made some video clips. I think there should be some other fault,causing the problem.
Now the motor is turning very slowly in jittering motions ,but in mode : INVERTER HALTED, when pressed INVERTER STARTED the motor stops rumbling and turning.
It is somthing like reversed position of the commands.Now the reles/contactors are set to NO position, may be they cause some problem?
uhi22
Has thanked: 245 times
Been thanked: 685 times
Post by uhi22 »
As manny wrote: Care for the correct resolver functionality first, so that you get valid angle measurements when rotating by hand. Having random position measurement just leads to random results, even if on first look "yeah, it spins" feels good, it is not, as long as the angle measurement does not work.
