OEM contactors/precharge relay units
Hi, I am wondering if there are values of using these "Battery Junction Boxes" that are off existing hybrids/EVs. What are the pros and cons?
- Bratitude
- Has thanked: 246 times
- Been thanked: 469 times
Re: OEM contactors/precharge relay units
Of course. It’s pre made and test(under its designated conditions) saves on more wiring.
just make sure to use what ever box in spect of the components.
- Kevin Sharpe
- Been thanked: 10 times
The contactors may require an economiser circuit.
What’s an economiser circuit?
Do the OEMs run these at coils at full duty or pwm them?
- Bratitude
It limits the amount of power the contractor coil draws so it doesn’t burn itself up. Some have them built in some don’t. That depends on the manufacture. Tesla’s contractors, for example, need an economiser. Most likely limiting them via pwm. There’s a thread post under fast charging on making a simple economiser for contractors.
In the past I’ve just coded this in the pwm routines, bastically a short hit at 100% for a second then drop back to < 50% pwm.
The GT86 seems to be using nissan leaf contactors / pre-charge.
- Kevin Sharpe
The devil is in the detail... it's important to review all the contactor specifications before making a decision... look for break current in particular.
- Kevin Sharpe
