OEM contactors/precharge relay units
RE3Rotor
Post by RE3Rotor »
Hi, I am wondering if there are values of using these "Battery Junction Boxes" that are off existing hybrids/EVs. What are the pros and cons?
Has thanked: 246 times
Been thanked: 469 times
Re: OEM contactors/precharge relay units
Of course. It’s pre made and test(under its designated conditions) saves on more wiring.
just make sure to use what ever box in spect of the components.
Kevin Sharpe
Been thanked: 10 times
Post by Kevin Sharpe »
RE3Rotor wrote: Mon Mar 02, 2020 9:36 pm What are the pros and cons?
The contactors may require an economiser circuit.
Dilbert
Post by Dilbert »
Kevin Sharpe wrote: Tue Mar 03, 2020 6:11 pm
What’s an economiser circuit?
Do the OEMs run these at coils at full duty or pwm them?
Dilbert wrote: Tue Mar 03, 2020 7:31 pm
It limits the amount of power the contractor coil draws so it doesn’t burn itself up. Some have them built in some don’t. That depends on the manufacture. Tesla’s contractors, for example, need an economiser. Most likely limiting them via pwm. There’s a thread post under fast charging on making a simple economiser for contractors.
Dilbert
Post by Dilbert »
In the past I’ve just coded this in the pwm routines, bastically a short hit at 100% for a second then drop back to < 50% pwm.
Dilbert
Post by Dilbert »
The GT86 seems to be using nissan leaf contactors / pre-charge.
Kevin Sharpe
Bratitude wrote: Tue Mar 03, 2020 8:05 am Of course. It’s pre made and test(under its designated conditions) saves on more wiring.
Dilbert wrote: Tue Mar 03, 2020 11:23 pm The GT86 seems to be using nissan leaf contactors / pre-charge.
The devil is in the detail... it's important to review all the contactor specifications before making a decision... look for break current in particular.
Kevin Sharpe
