Can Simp BMS read the BMW S-Box current shunt?
or can Zombie inverter send a analogue signal out to the Simp BMS current input ?
- Has thanked: 207 times
- Been thanked: 571 times
Re: Can Simp BMS read the BMW S-Box current shun
SimpBMS has one CAN bus so you need to be careful what you put on the bus.
The SimpBMS code available on github does not support the BMW S-Box Shunt. What version are you looking to use?
SimpBMS V2.3 on a vw PASSAT GTE HIGH VOLTAGE HYBRID BATTERY 3Q0804842F 13kw
Why do you have two accounts? you have a VW pack but are going to use and BMW Sbox?
No idea if there would be CAN conflicts when using the VW modules and BMW Sbox on one CAN bus. Should be easy to code in to take the current off the CAN bus.
thanks
yes lost email address on this one Bigpie sorted it out so will use this one from now on
will update my project now as its on the MOT now
- Has thanked: 82 times
- Been thanked: 424 times
It was supposed to let you login to snelly again not snelly1
