Can Simp BMS read the BMW S-Box current shun
snelly
Been thanked: 12 times
Post by snelly »
Can Simp BMS read the BMW S-Box current shunt?
or can Zombie inverter send a analogue signal out to the Simp BMS current input ?
Has thanked: 264 times
Been thanked: 717 times
Re: Can Simp BMS read the BMW S-Box current shun
SimpBMS has one CAN bus so you need to be careful what you put on the bus.
The SimpBMS code available on github does not support the BMW S-Box Shunt. What version are you looking to use?
snelly1
Post by snelly1 »
SimpBMS V2.3 on a vw PASSAT GTE HIGH VOLTAGE HYBRID BATTERY 3Q0804842F 13kw
snelly1 wrote: Sun Aug 25, 2024 5:18 pm SimpBMS V2.3 on a vw PASSAT GTE HIGH VOLTAGE HYBRID BATTERY 3Q0804842F 13kw
Why do you have two accounts? you have a VW pack but are going to use and BMW Sbox?
No idea if there would be CAN conflicts when using the VW modules and BMW Sbox on one CAN bus. Should be easy to code in to take the current off the CAN bus.
snelly1
Post by snelly1 »
thanks
yes lost email address on this one Bigpie sorted it out so will use this one from now on
will update my project now as its on the MOT now
Has thanked: 89 times
Been thanked: 481 times
It was supposed to let you login to snelly again not snelly1
snelly
Post by snelly »
sorry my bad had to many windows open, can you kill the snelly1 one thanks
Ruudi S
Has thanked: 55 times
Been thanked: 32 times
Post by Ruudi S »
How did it work out for you?
