Same thing, only 3 chargers. By the way, please share your fuel cards.arber333 wrote: ↑Wed May 22, 2024 12:00 pm Done that
https://leafdriveblog.wordpress.com/202 ... -parallel/
https://leafdriveblog.wordpress.com/202 ... e-control/
https://leafdriveblog.wordpress.com/202 ... l-part-ii/
Outlander VCU - Rear inverter, Charger and BMS
- midway
- Has thanked: 14 times
- Been thanked: 14 times
Re: Outlander VCU - Rear inverter, Charger and BMS
- Has thanked: 134 times
- Been thanked: 339 times
Fuel cards? You mean what i use for SOC calculation?
- midway
Yes, i only use "sport" mode and "Normal" mode. To toggle between them i use the sport switch. I reversed the intention of sport mode so that it is the default state. Normal mode is used when weather conditions are not favourable and regen torque could cause slip. I dont use map2 at all.
With sport mode i use two regen states during pedal positions. This will give me "sort of" single pedal driving experience. Later with pedal position torque increases as you rearly need so much power, but when needed you need it quick. Value 24 is total overkill which i inserted to test if inverter would give more than 75kW or 200Nm. Sadly i wasnt able to get this even though i tried to increase HV voltage to 96S.
In the future i may smooth out the starting part of the curve so that i keep value at 3 for longer time. I noticed i need precise throttle movement only at really low speed such as congested traffic or at stop light.
Max speed with 10000rpm seems to be at 160km/h which is my calculation for 15in wheels.
const int pedal_map_one[21][22] = {
// Normal
// map 1..
/*250*/ {0, 3, 3, 4, 4, 8, 8, 8, 8, 8, 8, 9, 9, 10, 10, 10, 10, 12, 12, 14, 16},
/*500*/ {0, 3, 3, 4, 4, 8, 8, 8, 8, 8, 8, 9, 9, 10, 10, 10, 10, 12, 12, 14, 16},
/*625*/ {0, 3, 3, 4, 4, 8, 8, 8, 8, 8, 8, 9, 9, 10, 10, 10, 10, 12, 12, 14, 16},
/*750*/ {0, 3, 3, 4, 4, 8, 8, 8, 8, 8, 8, 9, 9, 10, 10, 10, 10, 12, 12, 14, 16},
/*1000*/ {0, 3, 3, 4, 4, 8, 8, 8, 8, 8, 8, 9, 9, 10, 10, 10, 10, 12, 12, 14, 16},
/*1250*/ {0, 3, 3, 4, 4, 8, 8, 8, 8, 8, 8, 9, 9, 10, 10, 10, 10, 12, 12, 14, 16},
/*1500*/ {0, 3, 3, 4, 4, 8, 8, 8, 8, 8, 8, 9, 9, 10, 10, 10, 10, 12, 12, 14, 16},
/*2000*/ {0, 3, 3, 4, 4, 8, 8, 8, 8, 8, 8, 9, 9, 10, 10, 10, 10, 12, 12, 14, 14},
/*2500*/ {0, 3, 3, 4, 4, 8, 8, 8, 8, 8, 8, 9, 9, 10, 10, 10, 10, 12, 12, 14, 14},
/*3000*/ {0, 3, 3, 4, 4, 8, 8, 8, 8, 8, 8, 9, 9, 10, 10, 10, 10, 12, 12, 14, 14},
/*3500*/ {0, 3, 3, 4, 4, 8, 8, 8, 8, 8, 8, 9, 9, 10, 10, 10, 10, 12, 12, 14, 14},
/*4000*/ {0, 3, 3, 4, 4, 8, 8, 8, 8, 8, 8, 8, 9, 10, 10, 10, 10, 12, 12, 14, 14},
/*4500*/ {0, 3, 3, 4, 4, 8, 8, 8, 8, 8, 8, 8, 8, 10, 10, 10, 10, 12, 12, 14, 14},
/*5000*/ {0, 3, 3, 4, 5, 6, 8, 8, 8, 8, 8, 8, 8, 10, 10, 10, 10, 12, 12, 14, 14},
/*5500*/ {0, 3, 3, 4, 5, 6, 8, 8, 8, 8, 8, 8, 8, 10, 10, 10, 10, 12, 12, 14, 14},
/*6000*/ {0, 3, 3, 4, 5, 6, 8, 8, 8, 8, 8, 8, 8, 10, 10, 10, 10, 12, 12, 14, 14},
/*6500*/ {0, 3, 3, 4, 5, 6, 8, 8, 8, 8, 8, 8, 8, 10, 10, 10, 10, 12, 12, 14, 14},
/*7000*/ {0, 3, 3, 4, 5, 6, 8, 8, 8, 8, 8, 8, 8, 10, 10, 10, 10, 12, 12, 14, 14},
/*7500*/ {0, 3, 3, 4, 5, 6, 8, 8, 8, 8, 8, 8, 8, 10, 10, 10, 10, 12, 12, 14, 14},
/*8000*/ {0, 3, 3, 4, 5, 5, 8, 8, 8, 8, 8, 8, 8, 10, 10, 10, 10, 12, 12, 14, 14},
/*10000*/ {0, 3, 3, 4, 5, 5, 8, 8, 8, 8, 8, 8, 8, 10, 10, 10, 10, 12, 12, 14, 14},
const int pedal_map_two[21][22] = {
// Backup
// map 2..
/*250*/ {0, 0, 3, 4, 8, 10, 12, 8, 8, 8, 8, 9, 9, 10, 10, 10, 10, 12, 12, 14, 16},
/*500*/ {-60, 0, 3, 4, 8, 10, 12, 8, 8, 8, 8, 9, 9, 10, 10, 10, 10, 12, 12, 14, 16},
/*625*/ {-60, 0, 3, 4, 8, 12, 12, 8, 8, 8, 8, 9, 9, 10, 10, 10, 10, 12, 12, 14, 16},
/*750*/ {-60, 0, 3, 4, 8, 12, 12, 8, 8, 8, 8, 9, 9, 10, 10, 10, 10, 12, 12, 14, 16},
/*1000*/ {-90, 0, 3, 4, 8, 12, 12, 8, 8, 8, 8, 9, 9, 10, 10, 10, 10, 12, 12, 14, 16},
/*1250*/ {-90, 0, 3, 4, 8, 12, 12, 8, 8, 8, 8, 9, 9, 10, 10, 10, 10, 12, 12, 14, 16},
/*1500*/ {-110, 0, 3, 4, 8, 12, 12, 8, 8, 8, 8, 9, 9, 10, 10, 10, 10, 12, 12, 14, 16},
/*2000*/ {-110, 0, 3, 4, 8, 12, 10, 8, 8, 8, 8, 9, 9, 10, 10, 10, 10, 12, 12, 14, 14},
/*2500*/ {-130, 0, 3, 4, 8, 12, 10, 8, 8, 8, 8, 9, 9, 10, 10, 10, 10, 12, 12, 14, 14},
/*3000*/ {-130, 0, 3, 4, 8, 12, 10, 8, 8, 8, 8, 9, 9, 10, 10, 10, 10, 12, 12, 14, 14},
/*3500*/ {-150, 0, 3, 4, 8, 10, 10, 8, 8, 8, 8, 9, 9, 10, 10, 10, 10, 12, 12, 14, 14},
/*4000*/ {-150, 0, 3, 4, 8, 10, 10, 8, 8, 8, 8, 8, 9, 10, 10, 10, 10, 12, 12, 14, 14},
/*4500*/ {-150, 0, 3, 4, 6, 8, 8, 8, 8, 8, 8, 8, 8, 10, 10, 10, 10, 12, 12, 14, 14},
/*5000*/ {-160, 0, 3, 4, 5, 6, 8, 8, 8, 8, 8, 8, 8, 10, 10, 10, 10, 12, 12, 12, 14},
/*5500*/ {-160, 0, 3, 4, 5, 6, 8, 8, 8, 8, 8, 8, 8, 10, 10, 10, 10, 12, 12, 12, 12},
/*6000*/ {-160, 0, 3, 4, 5, 6, 8, 8, 8, 8, 8, 8, 8, 10, 10, 10, 10, 12, 12, 12, 12},
/*6500*/ {-160, 0, 3, 4, 5, 6, 8, 8, 8, 8, 8, 8, 8, 10, 10, 10, 10, 12, 12, 12, 12},
/*7000*/ {-160, 0, 3, 4, 5, 6, 8, 8, 8, 8, 8, 8, 8, 10, 10, 10, 10, 12, 12, 12, 12},
/*7500*/ {-160, 0, 3, 4, 5, 6, 8, 8, 8, 8, 8, 8, 8, 10, 10, 10, 10, 12, 12, 12, 12},
/*8000*/ {-160, 0, 3, 4, 5, 5, 8, 8, 8, 8, 8, 8, 8, 10, 10, 10, 10, 12, 12, 12, 12},
/*10000*/ {-160, 0, 3, 4, 5, 5, 8, 8, 8, 8, 8, 8, 8, 10, 10, 10, 10, 12, 12, 12, 12},
const int pedal_map_three[21][22] = {
// Sport
// map 3..
/*250*/ {0, 0, 0, 3, 3, 4, 6, 6, 8, 8, 8, 10, 12, 12, 16, 16, 18, 18, 20, 24, 24},
/*500*/ {-50, -30, 0, 3, 3, 4, 6, 6, 8, 8, 8, 10, 12, 12, 16, 16, 18, 18, 20, 24, 24},
/*625*/ {-90, -60, 0, 3, 3, 4, 6, 6, 8, 8, 8, 10, 12, 12, 16, 16, 18, 18, 20, 24, 24},
/*750*/ {-90, -60, 0, 3, 3, 4, 6, 6, 8, 8, 8, 10, 12, 12, 14, 16, 18, 18, 20, 24, 24},
/*1000*/ {-120, -90, 0, 3, 3, 4, 6, 6, 8, 8, 8, 10, 12, 12, 14, 14, 16, 16, 18, 22, 24},
/*1250*/ {-120, -90, 0, 3, 3, 4, 6, 6, 8, 8, 8, 10, 12, 12, 12, 14, 14, 16, 18, 22, 24},
/*1500*/ {-160, -90, 0, 3, 3, 4, 6, 6, 8, 8, 8, 10, 12, 12, 12, 14, 14, 16, 18, 22, 24},
/*2000*/ {-160, -90, 0, 3, 3, 4, 6, 6, 8, 8, 8, 10, 12, 12, 12, 14, 14, 16, 18, 22, 24},
/*2500*/ {-180, -90, 0, 3, 3, 4, 6, 6, 8, 8, 8, 9, 10, 12, 12, 14, 14, 16, 18, 22, 24},
/*3000*/ {-180, -90, 0, 3, 3, 4, 6, 6, 8, 8, 9, 9, 10, 12, 12, 12, 14, 16, 16, 18, 24},
/*3500*/ {-180, -90, 0, 3, 3, 4, 6, 6, 8, 8, 9, 9, 9, 10, 12, 12, 14, 16, 16, 18, 24},
/*4000*/ {-180, -90, 0, 3, 3, 4, 6, 6, 8, 8, 9, 9, 9, 10, 12, 12, 14, 14, 16, 18, 24},
/*4500*/ {-230, -120, 0, 3, 3, 4, 6, 6, 8, 8, 9, 9, 9, 10, 12, 12, 14, 14, 14, 18, 24},
/*5000*/ {-230, -120, 0, 3, 3, 4, 6, 6, 8, 8, 9, 9, 9, 10, 12, 12, 14, 14, 14, 18, 24},
/*5500*/ {-230, -120, 0, 3, 3, 4, 6, 6, 8, 8, 9, 9, 9, 10, 12, 12, 14, 14, 14, 18, 24},
/*6000*/ {-230, -120, 0, 3, 3, 4, 6, 6, 8, 8, 9, 9, 9, 10, 12, 12, 14, 14, 14, 18, 24},
/*6500*/ {-230, -120, 0, 3, 3, 4, 6, 6, 8, 8, 9, 9, 9, 10, 12, 12, 12, 14, 14, 18, 24},
/*7000*/ {-230, -120, 0, 3, 3, 4, 6, 6, 8, 8, 9, 9, 9, 10, 10, 12, 12, 12, 14, 18, 20},
/*7500*/ {-260, -120, 0, 3, 3, 4, 6, 6, 8, 8, 8, 8, 8, 10, 10, 12, 12, 12, 14, 16, 18},
/*8000*/ {-260, -120, 0, 3, 3, 4, 4, 6, 6, 8, 8, 8, 8, 10, 10, 10, 12, 12, 14, 16, 18},
/*10000*/ {-260, -120, 0, 3, 3, 4, 4, 6, 6, 8, 8, 8, 8, 10, 10, 10, 10, 12, 14, 16, 18},
- midway
Thank you, the tests were successful. I was especially pleased with the sport mode. Acceleration from 100 km/h in 9.6 seconds.
I managed to get 8.7s at one time but i cant repeat this anymore. I dont know what i did.
Did you notice the slow start almost like a rubber band? I guess this takes at least 0.5s from you....
Also i must reseal all the moving parts of chassis. There is so much chatter in the undercarriage my teeth are rattling
- marcexec
- Has thanked: 777 times
- Been thanked: 74 times
Did you have a chance to test this again? Also, what year is your Outlander Rear Inverter? I.e. is it a 50 or 60kW unit originally?arber333 wrote: ↑Fri Mar 08, 2024 10:16 pm It looks like Outlander inverter has a power limiter! Not amp limiter, but power limiter. When i had 84S battery inverter would let 230A go through which at 320V means 73kW. In the video i show steady acceleration and max current draw of 192A at 360V which makes about 70kW power from Outlander RWD motor. This means i will have to try to up the torque by software but the power will probably remain constant
My Suzuki RF400 build @ES
Honda IMA & Lebowski howto
- midway
I have a good response to the gas pedal, today I completed a trip of 160 km, the acceleration suits me. Only in sports mode did the limitation in the inverter work several times. Regarding the suspension, I had to change the arms and stabilizer struts, while the car was gasoline, I did not notice the suspension working.arber333 wrote: ↑Thu May 23, 2024 6:57 pm I managed to get 8.7s at one time but i cant repeat this anymore. I dont know what i did.
Also i must reseal all the moving parts of chassis. There is so much chatter in the undercarriage my teeth are rattling.
- Has thanked: 77 times
- Been thanked: 220 times
I've noticed this with the outlander motor as well. Always felt like it had more torque once you were moving than off the line. Noticed this running it on my own VCU and also on zombieverter. So I would probably say it could be another inbuilt inverter limit.
Thanks very much for sharing your work
aot93 and arber333
Would you still have any of the PCBs available?
I’m looking forward to testing all this out!
C.
aot93 and arber333
aot93 wrote: ↑Wed Aug 17, 2022 1:15 pm Good news is the teensy 4.1 seems to be back in general stock.
Bad news is the 3.x ones are still a way off by the looks of things, which makes the BMS side of things tricky.
If there is interest I can order do an order for some vcu boards from JLCpcb will take a few weeks on cheap shipping
Many thanks
C.
- midway
teensy 4.0 is a full replacement for teensy 3.6. The pin layout is completely the same, only the processor is more powerfulBad news is the 3.x ones are still a way off by the looks of things, which makes the BMS side of things tricky.
- aot93
- Has thanked: 8 times
- Been thanked: 48 times
Sadly whilst the pins might be in the same place what they do is quite diffrent between the 3.x and the 4.x
Beside this some of the libraries used by simp are not compatible with the 4.x (try compiling with target board set to a 4.x to see which ones)
- aot93
I just checked there are a few left.
With outlander in Zombie now I won't be doing any more work on this, better to concentrate efforts on a common platform I think.
It just went to -1degC here... i can see heating coolant to 50deg as being rather inadequate.
When i have a bit of time i intend to add an option in aot93 VCU code for serial menu. A parameter for heater_temp.
My idea is to have a temperature setting that is terminal and inside that function is equasion to drop power the last 5 deg before reaching heater_temp. Now this is set to 55degC whereas at 50deg heater goes from 4kW to 1kW power for the last 5deg.
I will let you know...
EDIT:
//Add new definition
//Define slot in EEPROM
uint8_t Heater_temp = EEPROM.read(7);
//Ad new variable to Serial menu
Serial.println("8 - Set Heater Temp");
//Add new case
case '8': {
int value = Serial.parseInt();
if (value > 80)
value = 80;
Heater_temp = value;
Serial.print("Heater Set to: ");
Serial.println(value);
menuLoad = 0;
break; }
// Correct heater function
void HeaterComms()
if (timer100_2.check() == 1)
msg.id = 0x188;
msg.len = 8;
if (digitalRead(ISO_IN5) == LOW)
msg.buf[0] = 0x03; // byte0 status command Heater pin is on
else {
msg.buf[0] = 0x00; // Heater pin is off
msg.buf[1] = 0x50; // byte1 20 to 50 works
if (Heatertemp >= Heater_temp) {
msg.buf[2] = 0x00; //Heater off when at 65deg
else if (Heatertemp > (Heater_temp - 5)) {
msg.buf[2] = 0x32; //Heater at 1/2 when at 60deg
else {
msg.buf[2] = 0xA2; //Heater on at full power (dec/10)
msg.buf[3] = 0x36; // byte3 30 to 40 works
msg.buf[4] = 0;
msg.buf[5] = 0;
msg.buf[6] = 0;
msg.buf[7] = 0;
Can2.write(msg);
// Serial data display
Serial.print("Set Heater Temperature: ");
Serial.print(Heater_temp);
// Add to default values
Heater_temp = 65; // default heater temp
// Add to EEPROM save menu
EEPROM.update(7, Heater_temp);
EDIT:
//Add new case
case '8': {
if (value > 80)
value = 80;
menuLoad = 0;
break; }
void HeaterComms()
msg.id = 0x188;
msg.len = 8;
else {
else {
msg.buf[4] = 0;
msg.buf[5] = 0;
msg.buf[6] = 0;
msg.buf[7] = 0;
Can2.write(msg);
If i may ask here...
I intend to connect Tesla Gen2 charger directly to Outlander rear inverter. It would NOT be a permanent connection to DC link but rather connected inside inverter when PP signal would start the precharge and stabilize DC link in about 2s?
Did anyone tried a connection in such a way?
I am asking because i see some chargers like Eltek dont have reverse diode but work in LLC resonant way. It is not a good idea to connect it directly with voltage spikes...
Because my build uses both Outlander AND Tesla components and i guess for personal reasons people that may contribute to knowledge may come from either or one of both options. Satisfying enough for you mr. forum policeman?
- Has thanked: 209 times
- Been thanked: 577 times
You copy paste a post I ask why.
The questions is about the required precharge time for a Tesla Charger. There is no direct refence to the use of this vcu or a modified version of it.
Is the precharge purely time based or does it also use a voltage feedback or current measurement to "finish"?
Ah excellent idea! I will implement the voltage report from inverter (0x289 B4+B5 = HV report = ((H*256+L))).tom91 wrote: ↑Tue Feb 25, 2025 3:18 pm You copy paste a post I ask why.
The only caveat is i need to turn on the inverter 12V logic before charger is online...
Until first Torque command is received then it changes into another value.
This VCU could have just used the charger HV DC feedback however you are looking to use a different charger so that wont work.
Good to know. I use this with Outlander OBC but i want 3phase charging possibility as this should be 60kWh car with battery thermal control and everything.
Today i happened to involuntarily test a battery protection loop i built in my VCU code. It works and really effective...
Idea is to have oil light (or battery light) to turn on when battery voltage is below 310Vdc (3.3V per cell at 96S).
Alternatively when battery drops below 288Vdc (3.0V per cell) torque drops to 0Nm and VCU throws an error.
I thought it to be obvious if i would get error light (oil light) i would not drive very far after that and tried to connect to EVSE. Well i was stuborn and i drove on for quite some time and suddenly up one hill the car dropped torque and signaled error state!
I use chargerHVbattryVolts variable from 0x389 byte0 charger report telegram.
If anyone wants to use or develop this here is the code
case driveForward: //driving forward
if ((dir_FWD == 1) && (dir_REV == 1))
if (VCUstatusChangeCounter > VCUstatusChangeThreshold)
VCUstatusChangeCounter = 0;
VCUstatus = 3;
else
VCUstatusChangeCounter++;
if (fanState == 0)
digitalWrite(OUT6, HIGH);
fanState = 1;
readPedal();
BMS_keyOn = 1; // Key on for BMS
if (( chargerHVbattryVolts < 316) && (chargerHVbattryVolts > 288) ) { //if we are low on voltage we get warning light
digitalWrite(OUT11, LOW); // Voltage light
digitalWrite(OUT10, HIGH); // Error light on if HV too low
else if ( chargerHVbattryVolts <= 288) { //if we are seriously low on voltage inverter stops
inverterFunction = 0x00; // disable the inverter
VCUstatus = 7; //error status
else { //any other case
digitalWrite(OUT10, LOW); // Error light
@aot93; can you suggest how i would use previous code NOT to simply cut torque but to lower torque to like 1/10th of original requested, to put the car into "turtle mode"?
My proposition:
My proposition:
torqueRequest = throttlePosition / 10; // put inverter into turtle mode
VCUstatus = 7;
- aot93
Hi Arber,
Nice work, It's been a while since I've been in the code, but I could suggest 3 options for 'turtle' mode
In all cases you would need to set some kind of flag to say turtle mode is active
1. If you are using the maps, make a turtle mode mode one and for it to be active if turtle mode is true
2. Modify the BMS derating in inverterComms() to derate above some fixed value for max torque
3. Add another function in inverterComms() to catch the turtle mode flag and derate to some max value.
Cheers
if (BMS_discurrent < currentact) // Decrese tourque if we are over current - Crude needs work..
torqueRequest -= 20;
Serial.println("--!OVER CURRENT!--");
if (torqueRequest < 0)
torqueRequest = 0;
Cheers
I will try this over weekend thanks! I am inclined to try the first option.
But i am stuck with something... Can you also explain what does this line do?
torqueRequest = throttlePosition * 16;
