zombieverter firmware with working charging (Leaf PDM) Topic is solved
Hello,
zombieverter firmware version 2.17A not allowing nissan leaf pdm to charge , i request for github repo with zombieverter firmware that allows pdm to charge .
Thank you
Thank you
- Been thanked: 1913 times
Re: zombieverter firmware with working charging (Leaf PDM)
Please read the forum rules viewtopic.php?t=5714 especially #1
- Has thanked: 328 times
- Been thanked: 847 times
Hello Tom91,
Thank you for your reply.
I’m using a 2015 Nissan Leaf (EM57 motor, inverter, and 3.6kW PDM) along with a Zombieverter running the latest release (2.17A). The motor, inverter, and DC-to-DC converter are all functioning properly. However, I’m encountering an issue when trying to charge the battery.
The PP and CP lines are correctly connected. When I plug in the Type 1 charging cable, the contactors click, and the VCU switches to charge mode. However, when I measure the current going to the battery, it only shows 0.05A, indicating that no power is being delivered by the PDM.
Below are screen shots of the parameters of the vcu, incase you need more please let me know
Better than screenshot is this (Download Parameter File):
or the result of http://192.168.4.1/cmd?cmd=json as a text file attachment
Fix is incoming with the next release that is currently undertest. Turned out there was a message missing in charge mode.
here is the full parameters file
- params.json
- (1.96 KiB) Downloaded 101 times
Thank you!
Do you have any insights on when the next release is expected or what the estimated timeframe might be?
All I can say Damien is testing right now.
Release 2.20A has proven to resolve this issue.
https://github.com/damienmaguire/Stm32- ... /tag/2.20a
tom91 wrote: ↑Thu Dec 05, 2024 10:25 am Release 2.20A has proven to resolve this issue.
Thank you
