zombieverter firmware with working charging (Leaf PDM) Topic is solved
Hello,
zombieverter firmware version 2.17A not allowing nissan leaf pdm to charge , i request for github repo with zombieverter firmware that allows pdm to charge .
Thank you
Thank you
- Has thanked: 383 times
- Been thanked: 1580 times
Re: zombieverter firmware with working charging (Leaf PDM)
Please read the forum rules viewtopic.php?t=5714 especially #1
- Has thanked: 211 times
- Been thanked: 588 times
Hello Tom91,
Thank you for your reply.
I’m using a 2015 Nissan Leaf (EM57 motor, inverter, and 3.6kW PDM) along with a Zombieverter running the latest release (2.17A). The motor, inverter, and DC-to-DC converter are all functioning properly. However, I’m encountering an issue when trying to charge the battery.
The PP and CP lines are correctly connected. When I plug in the Type 1 charging cable, the contactors click, and the VCU switches to charge mode. However, when I measure the current going to the battery, it only shows 0.05A, indicating that no power is being delivered by the PDM.
Below are screen shots of the parameters of the vcu, incase you need more please let me know
Better than screenshot is this (Download Parameter File):
http://192.168.4.1/cmd?cmd=json as a text file attachment
or the result of Support R/D and forum on Patreon: https://patreon.com/openinverter - Subscribe on odysee: https://odysee.com/@openinverter:9
Fix is incoming with the next release that is currently undertest. Turned out there was a message missing in charge mode.
here is the full parameters file
- params.json
- (1.96 KiB) Downloaded 94 times
Thank you!
Do you have any insights on when the next release is expected or what the estimated timeframe might be?
All I can say Damien is testing right now.
Release 2.20A has proven to resolve this issue.
https://github.com/damienmaguire/Stm32- ... /tag/2.20a
tom91 wrote: ↑Thu Dec 05, 2024 10:25 am Release 2.20A has proven to resolve this issue.
Thank you
