1. upgrading existing toyota/lexus hybrids from NIMH to lithium and increasing the usage of the electric system for high MPG in mixed use mode.
2. enabling 30 to 50 miles( or more depending on the battery installed) of pure electric driving.
3. swap the hybrid motor and trans into other chassis, and keeping the hybrid system functional( this is the one i am most concerned with)
We know that the protocol is CSI and we can use a denso chip to communicate
if no one has the ability to setup logic sniffer on the bth line, i would like to know which logic sniffer will work best for this?
green x that Damien has seem to be the minimum?> but i only need 1 channel..
I have an stm bluebill, and a Arduino Due on the way... also i have a zombie inverter i purchased a month ago. my test bests are 07 Prius and 07 gs450h ( have both full cars, gs450h down for headgasket/studs. )
i have images of wiring diagrams but cant seem to upload yet. probably too fresh of a member
i plan to put the whole v6 and gs450h trans.... into my..... RV with a 116kwh lithium. we currently live in it on a 48v 15kwh battery and 3kw of solar on the rv and 3kw array on land next to it.
i could use 120 cells of lifepo4 6 cells per block would be 22v, so a step down or voltage clamp to bring the block voltages down to 18.5, and i may try this method on the prius... but this will keep the dc to dc and limit the electrical output to 30kw,,, from what i have read... will still be ok for increasing the overall MPG but doesnt allow for full electric travel....
the blue pill spitting data to the Hybrid CPU would possiblely over come these if the dc to dc converter is also by passed, but i dont think the toyota logic will like that? but it seems to work with zombie vcu that way?
Thoughts?
after I can upload imagines will make a separate thread.
