zombieverter universal wiring interface + 3d printed case
Has thanked: 175 times
Been thanked: 359 times
i use the zombie for all sorts of projects, and generally recommend it to customers. the zombie wiring is 95% the same across the board...so why am i making custom wiring harnesses for every project?..... and some customers are overwelled(ironically by wiring in a EV conversion).
why not just make a "universal" harness?
what i need is a box with everything:
zombie, dedicated connectors, pre-fused, powered, and mounted.
but needs to be flexible enough for adding more connectors or devices to the zombie...without having to rewire everything...
which has resulted in this:
features:
-OBD-ii port
-little fuse PDM
-deutsch DT connectors
-dedicated power deutsch DTP connector
each connector will be pre wired with the necessary can, power, signals, etc so just plug in throttle, inverter, start/run/direction, contactors, etc and you have a up and running ev system.
also found the alibaba case kinda sucks, as half the time you dont get a seal and they dont have great mounting tabs.
so designed a 3d printable case:
Has thanked: 404 times
Been thanked: 116 times
Re: zombieverter universal wiring interface + 3d printed case
Post by Jacobsmess »
This is great, look forward to seeing some end results
damien sent over the original case drawing
Jo56-1.pdf
(41.9 KiB) Downloaded 436 times
heres files for a 3D printable zombie case and the header.
it works for now, still lots to clean up, but if you need a case here ya go!
ZOM_CASE_2.zip
(6.88 MiB) Downloaded 442 times
