MQB Chargers
uhi22
Has thanked: 245 times
Been thanked: 685 times
Re: MQB Chargers
Post by uhi22 »
Just to avoid confusion: part number 1EA ... ... is MEB, not MQB.
m.art.y
Has thanked: 38 times
Re: MQB Chargers
Post by m.art.y »
Anybody had success making those chargers work? I'm particularly interested in 22kw versions or at least 11kw ones. Why do the 22 kwh versions have a second connector for what looks to be 3 phase charging?
o-de2bcf293224f2d29470f597c87b66da-porsche_taycan_9j1_kiti_valdymo_blokai_moduliai.jpg
m.art.y
Re: MEB Chargers
Post by m.art.y »
modellfan wrote: Wed Oct 23, 2024 7:46 am I won't say how I found out. VW id.3 Chargers and the other chargers discussed here don't have the same AC plug. The id.3 and propably also id.4 / enyaq have small deviders bentween the horizontal pins. The others don't. CCS HARNESS NOT COMPATIBLE!
Did you try getting the pictured charger working? How did it go?
RetroZero
Has thanked: 645 times
Been thanked: 64 times
Re: MQB Chargers
Post by RetroZero »
The charge flap error has really been getting to me. I ordered a Porsche ref - 7P5915651 and openned it up. It is identicle to the charge flap actuator on the GTE looms, however it has a 4 pin connector, so cutting out the original actuator on GTE loom, & fitting a plug, the actuator can be replaced. Only modification is that the white "locking" arm must be swapped as they have different lengths. Inside resistances are identicle.
However, I still have the stupid actator fault present, and yes I can just code it out.
I can make it lock via VCDS, but it doesn't return the lock signal, so stays blocked. I have tried to put a spacer, as there is mention of a load return signal (from one of Damiens previous posts), but no luck yet.
