Hey,
Today I've doing some measurements on the BMW battery modules and how I could fit the in the buggy. Initially I was thinking about a split battery pack, so 4 modules in the front and 2 in the back for space an weight distribution. But it comes with additional complexity and costs so I skipped that idea.
The plan for now is to place the modules on theire side back to back (or original bottom to original bottom) and instal a heat exchanger in between them. Like so:
This will fit nicely right above the rear torsion bars. Other configurations of all modules in a single pack doesn't fit. I do need to find a solution to connect the modules in series, maybe I can find a way to make som bus bars instead of using the original cables.
Then for the battery box, as I would like to keep the weight down as much as possible, my idea now is to build a carbon fiber (CF) battery box. Does anyone have experience with carbons fiber battery boxes? I've seen manufacturers use CF as battery box, in addition, some existing boxes have plastic covers, so the use of some sort of plastic or polymer is not new.
The idea for my box is to incorporate stainless steel mounting points for the heat exchangers and battery modules into the CF.
Any ideas on this matter?
Thanks!
