Zombieverter 2.22A Release
Topics relating to the ZombieVerter VCU
Has thanked: 208 times
Been thanked: 572 times
https://github.com/damienmaguire/Stm32- ... /tag/2.22a
Please Note: when upgrading from earlier versions you must reselect your inverter type and save params. This is due to the inverter sequence numbering in the param database being updated in this version. Also as the hardware timer configurations have changed, a reboot/power cycle of the VCU must be done after software upgrade.
Lexus IS300h Inverter fix
LIN bus fix for VW coolant heater
Nissan leaf improvement for Gen3 PDM operation
Other small fixes.
Tested in all 4 currently running EVBMW vehicles and Gen3 Prius test bench. See parameter files for more info.
If you find any issues please report back here.
medo
Re: Zombieverter 2.22A Release
Post by medo »
selection point 89, disappeared?
Not sure why this changed. Will review it, possibly the web interface has issues displaying it.
This has not changed so should still work for the option of TachoOut or GS450hOil
medo
Post by medo »
Something else, accelerator pedal is sent over can to the ldu as before, but not the drive direction
No shit. This update does not contain all the fixes in the Testing branch, the updated changes are laid out.
We/Damien test a firmware version for a few weeks and he been busy so it took longer. All changes after he started are not included and will be at a later date.
medo wrote: Sun Mar 23, 2025 4:03 pm selection point 89, disappeared?
You probably had a value for the parameter that is out of range. You are switching from a Testing and upstream branch to the release so you are going backwards.
